Question about Sony Handycam DCR-DVD201 DVD Camcorder
My (infrared?) focussing (and light meter) has suddenly stopped functioning, is this because of a setting, or has a component broken? If the letter can it readily be fixed?
  • Sony Master
  • 19,396 Answers
Hi.
The problem is rather unlikely caused by a setting. ensure that you are not in manual mode and reset the camcorder, both using the reset in camccorder setting menu, and then removing the battery for two minutes.
I do not think this will help.
If that does not help try first cleaning the sensor surface, on the front lower side of the camcorder.
If still no luck, then the sensor is defective. To get a quote on repair call Sony at the number listed on the user manual, or get a quote from a third party service here:Repair.
Regards.
Ginko.
Posted on Aug 26, 2010
Remote has stopped functioning properly. Menu button, exit, cc, return, nor information buttons. How can I resolve this?
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Dec 18, 2014 | Televison & Video
Fault finding
some of the older sigma 70 -500 lenses had a little rubber belt driving the focussing. you can access this by removing the mount ring, four screws and two on recessed on the side holding the contact also three screws holding the centre black cover. the belt used to stretch therefore no longer driving the focussing ring.
Aug 18, 2013 | Sigma Cameras
What is a laser meter?
A Laser Distance Meter sends out a finely focussed pulse of light to the target and detects the reflection. The meter
measures the time between those two events, and converts this to a distance. The formula is simple: Distance = A
(Speed x Time).
Jan 30, 2013 | Measuring Tools & Sensors
Pioneer vsx-32 won't turn on with remote
Hi, since both remotes suddenly fail, I am assuming the problem is more than likely with the received rather than the remotes.
If you do wish to check your remotes, then point your mobile phone camera at the remote's Infrared lens and press one the remote's buttons. Your mobile phone camera is able to detect Infrared light and in case you remotes are working properly, you should see light coming out of your remote's Infrared lens.
Make sure that no direct sun light is on your receiver because that can effectively block out the signals from your remote controls.
Try the following method to reset your receiver. Unplug your receiver mains cable from the mains wall socket; power your receiver on by pushing the on/off button (nothing will happen obviously) and leave it like that for say 30 minutes. By that time all capacitors in your receiver will have discharged. Plug your received mains cable in the mains wall socket.Push the receiver's on/off button and see if it know responds to your remote controls.
If the problem still persists, you may have a failed Infrared receiver LED. That component can be found inside your receiver. It will take some basic elelectronics skills to get this component replaced. A service manual can help you. You can download it for free from this website: http://elektrotanya.com/pioneer_vsx-32_33.pdf/download.html
Good luck.
Jan 20, 2013 | Pioneer Elite VSX-32
How do i reset the change oil light on a 1040 cub cadet 1000 series
The Service Monitor meter contains a service minder function that utilizes the 4-digit LCD display. The letters "CHG" will display followed by the letters "OIL" and then followed by the meter accumulated time. "CHG"/"OIL"/TIME will alternate on the display for five(5) minutes after the meter reaches 50 hours. The display will also flash as described above for five(5) minutes every time the tractor has been started during the maintenance time interval. The interval will occur every 50 hours and will be in effect for two(2) hours ( Example: this feature will display from 50-52 hrs., 100-102 hrs., 150-152 hrs etc...). While the LCD is displaying the "CHG"/"OIL"/TIME letters, the red LED "oil symbol" will also be flashing for the entire five(5) minutes. The meter display will return to normal function automatically after the reminder maintenance time interval of two(2) hours.There is no method of manually re-setting this Service Monitor gauge.
Aug 30, 2010 | Cub Cadet Street Sign- tractor lawn riding...
My remote control stopped working
try with simple test. with any camera (mobile) check for any light (infrared light is not visible, only cameras see the infrared light) in front remote control, while press a key, if a flashing light deteted the remote control is ok, and the problem maybe on remote function is selected, normaly using tv and select VCR or AUX, may occur this problem. or a defective receiver sensor.
Jan 02, 2010 | Televison & Video
Remote justs stops working....changed batteries and still does nothing
Test the remote using a camera on a mobile phone: access the camera function on the mobile phone, point the remote's transmitter (front end) towards the camera lens. Observe the mobile's display while pressing buttons on the remote.
If the remote works, you should see a blinking spot on the display of the mobile phone each time you press a button on the remote - this is the light emitting diode inside the remote which can not be seen with our naked eyes because it is emitting infrared light, but the camera on the mobile phone is able to convert the infrared into visible light so you can see the flashes when you observe the remote emitter through the mobile's camera.
When you test the remote, you will probably notice one of the following types of behaviour:
1. the emitter blinks when you press ANY of the buttons on the remote that you normally use to control the unit - the remote is functional and there is a problem elsewhere
2. the emitter blinks only with some of the buttons that are normally being used - the buttons that should work, but do not, most probably have dirty or worn out contacts
3. the emitter does NOT blink no matter which button is pressed - there is a fault inside the remote
So, if you can see the flashes, the remote is functional, but the unit you control with it does not respond.
There can be several causes for that:
--- the remote is not programmed with the right code (only for universal remotes, if the remote is original and it came with the unit, then this most likely isn't the case).
--- there is a problem with the unit that is being controlled with the remote. Some possibilities are a bad infrared receiving sensor, bad solder joints on the sensor, a problem with the sensor decoder or other components associated to the decoder, bad power supply to the sensor or/and decoder, a problem elsewhere in the unit).
If you see flashes only with some butons pressed, but not with all of the buttons that are normally used, then some of the buttons may either have dirty contact points or the contact points are worn out.
This would require either cleaning the rubber keypad of the remote and the underlying circuit board with some alcohol and cottonwool, but if that doesn't do any good this means that the rubber pad contacts are worn out (they can be renewed with the remote repair liquid kit), an alternative is to replace the rubber keypad or the entire remote.
If there are no flashes whatsoever, no matter what button you press, then there is actually a problem with the remote. Some possible problems and solutions are:
- a dirty battery connector contact (clean the contact)
- a broken wire from the remote's battery connector to the circuit board, either at the connector side or at the circuit board (test with an ohm meter or a continuity tester, resolder or replace the wire or replace the connector, if and as necessary)
- a bad component on the remote's circuit board - there are not many, a capacitor, an IC (chip), a quartz resonator, an infrared emitting diode, maybe a few resistors and diodes (see or test if any components are damaged or burnt out and replace if necessary - this requires some knowledge about electronics and some measuring equipment, an universal multimeter for the least)
- a bad solder joint on any of the above mentioned components (resolder bad joints if you find any)
Anyway, the most common problems with remotes that i've encountered so far were: bad solder joints on the pins of the infrared emitter and sometimes on other components, broken connection wires and dirty or worn out button contacts. Rarely, if ever, do i recall seeing an actually burnt out or damaged component - this stuff operates on a battery voltage which is somewhere between 3 and 9 volts so it would take some serious short circuiting or battery spillage to damage the components (anyway, spilled battery liquid or other sour liquids can be able to do that and can also severely damage the circuit board leads but this often means that the remote is forever gone).
I must apologize for this lenghty disclosure, i hope it helps somewhat.
regards
Triarcuate
Sep 29, 2009 | Televison & Video
Speakercraft infrared system with AT-1.0 Amplified Terminator, IRC-1.0 Receiver, PS-1.0 Power Supply and IRE-3.0 Emitters. Not functioning - no light on the Receiver and no lights from the emitters when...
From the power supply. You can meter a power supply with a multi meter. As for the terminator; they rarely go bad. Chances are good that you have a bad receiver.
Jun 28, 2009 | SpeakerCraft 8" 150W In-Ceiling Speaker...
Is the Minolta Maxxum 7000 capable of using infrared film?
goneoutthewi,
once the shutter is closed or the shutter open and the mirror is up no light strikes the film except the image. don't forget to use the red markings on the lens as infra-red focuses on a different plane than visible light.
Mar 27, 2009 | Minolta Maxxum 7000 35mm SLR Camera
Sony Handycam DCR-DVD201 DVD Camcorder Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
