Question about GE Profile 23.3 Cu. Ft. Counter-Depth Side-by-Side Refrigerator - Stainless-Steel
REFRIGERATOR MODEL # GSC23KSTA SS THE SCREEN ON FRONT OF FRIDGE IS ALWAYS BLINKING, HOW DO I RESET?
ngafm
  • 166 Answers
SOURCE: GE side by side water dispencer area Leaking
1. How do I get repairs done under warranty?
* If your refrigerator is under warranty, you must use an Authorized Service Company.
An Authorized Service Company can be found by using our Service Locator. Enter your zip code on the Service Locator to get a listing of available service companies in your area.
* You can also schedule service by calling our toll free number:
800-374-4432 M-F 9:00am - 5:30pm.
Back
2. How do I order parts?
* Parts can be ordered through an Authorized Frigidaire Parts Distributor.
An Authorized Parts Distributor can be found by using our Parts Distributor Locator. Enter your zip code on the Parts Distributor Locator to get a listing of distributors in your area.
Back
3. Noises / Sounds.
* Dripping sound.
During the defrost, water draining from the freezer section will drip into the pan by your compressor in the back and bottom of your refrigerator.
* Air rushing or blowing.
There is a fan in the freezer section and in some models in the back and bottom of your refrigerator to circulate air. This is a normal sound.
* Louder when starting or coming on.
Compressor operates at a higher pressure when first starting and noise should disappear as refrigerator continues to run and balance pressures.
* Popping, crackling, or sizzling about once a day.
If your model is self-defrosting, the defrost system utilizes a heater to remove the ice and frost from the freezer coil. During this period you will hear some expansion noises as heat is applied to the coil and you may experience some sizzling sounds as the melting water drips on the heater.
* Running water.
If you have an ice maker equipped model, the ice maker will call for water as the old batch of cubes is ejected and the ice maker starts to make more cubes. This will last for about 10 seconds and is normal.
* Vibrating or rattling noises.
The following can be sources of these noises:
1. Dish vibrating on shelf - move dish slightly.
2. Floor is uneven or cannot adequately support refrigerator. Use shims or extra support.
3. Items on top of refrigerator are rocking. Place a pad under the item or remove.
4. Refrigerator is not level. Adjust leveling legs or rollers as needed. Add shims in the back if floor is not level from front to back.
5. Refrigerator is touching wall or cabinets. See your owner's manual for space requirements.
* Snapping or clicking sound.
If your refrigerator is equipped with an ice maker the water valve will snap on when the ice maker is calling for water. This is normal. In some cases you may not have the water connected to your ice maker and the sound will be greater. In these cases, pull the wire signal arm (bail arm) on the ice maker in the up position to turn your ice maker off until the water supply line is installed.
Back
4. Taste and odors.
* Ice or food has a bad taste or odor.
Ice and uncovered foods can pick up odors or taste from strong smelling foods in the refrigerator or freezer. Cover foods tightly and discard old ice.
* Ice tastes like plastic.
Plastic water lines will give off a taste when first used. It takes one or two containers of ice for plastic to stop leeching. Discard initial container of ice after installation.
Back
5. Ice maker - not making any ice.
* Freezer may not be cold enough.
Temperature must be 5 F. or colder to work properly.
* Water supply valve may be blocked or restricted.
Supply valve must have a 1/4" opening for water to fully supply ice maker. Many self-piercing valves do not have this big of an opening. Replace water supply valve with one that has a 1/4" opening.
* Water supply valve may not be open.
Find and open the supply valve.
* Wire signal arm on ice maker is in the up position.
This position shuts off the ice maker. Pull wire arm (bail arm) down to start ice making.
Back
Posted on Sep 05, 2008
SOURCE: fridge doesnt work both freezer and refrigerator part not making ice
TRY REPLACING OVERLOAD RELAY..PARTS #67005560....IT COST TO ORDER AT THE INTERNET AT $27.45..........REPAIR SERVICE WILL CHARGE YOU , AS WHAT THEY DID TO ME $69.43 PLUS $120.00 FOR LABOR....IT SUCKS.....FROM ALEX ESMENA ..NORTH LAS VEGAS NEVADA
Posted on Nov 09, 2008
SOURCE: GE GSH25JSTA SS side by side fridge not cooling/freezing
In most cases it is the Defrost timer circuit. One of three things the Defrost time (most likely) it allows the cooling for a 6 to 10 hour period and the defrosting for 10 to 30 minutes to remove ice buildup, ICE BUILDUP is the main problem as it restrict air flow, the cooling air circulation through the system. You see cool air only comes in the freezer side and passes through vents (pass ways) to the refrigerator side. Ice buildup in the freezer side inhibits cooling air to the refrigerator side. You think the freezer is working, but it is only cooler because there is ice in there that you can't see. The Terminator (a LIMIT switch) opens the defrost circuit if the defrost heater gets too hot (second likely) the next is the Heater which heats for those 10 to 30 minutes to melt the ice buildup (least likely) no matter the Unit you have they all have this circuit... Hope this helps, I'm Tango
Posted on Jan 16, 2009
MNTECH
  • 1543 Answers
SOURCE: GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Posted on Aug 04, 2009
  • 159 Answers
SOURCE: The center wall stays hot
its normal to do that
Posted on Oct 23, 2009
Ge profile bottom freezer model # PGSS5NFXA SS. Got up this morning and freezer thawing both fridge and freezer same
Not sure if the compressor is running. If not, you'll need a repair man. Since fans are running, most likely the thermistor. Also, if you haven't unplug from the wall, wait 10 seconds then plug back in; this may reset the control board. The link below may help. GE Refrigerator Not Cold Enough
Feb 03, 2015 | GE Refrigerators
We have a GE Profile refrigerator/freezer Model GSC23KSTA SS. The control panel will not light up. We tried to unplug the unit for a couple minutes but had no response. Now it is also making an annoying...
Three things. There's another board on the back of that fridge. Could be the display board or there's a wire harness down at the bottom of the freezer door. Pull the bottom grill off and check to see if there is any corrosion on that connector. GE's are notorious for that. If that checks clear then without looking at it I would say with 98% sure, it's the board in the back...about 189 dollars. Call GE (customer relations) chances are good that they will replace that part, but you would be responsible for any labor. It's a quick fix (20 minutes if that) so labor should not be that bad...hope this helps.
Apr 02, 2011 | Refrigerators
Refrigerator (Samsung RS2555SL) quit cooling on both sides. Front panel was blinking at set temperatures (34 fridge side/0 freezer side) but inside was warm. I unplugged for 5 min and ran self-diagnostic...
hello dont know if you have the same model
but this may be worht a look
samsung fridge freezer problems
http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01"> name="allowFullScreen" value="true">http://www.youtube.com/v/RP9XLji-gdw?fs=1&hl=en_GB&color1=0xe1600f&color2=0xfebd01" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344">
Sep 28, 2010 | Samsung RS2578BB Side by Side Refrigerator
My Samsung refrigerator model RM255LASH's screen keeps blinking 88 98 on the srenn where it is supposed to show temperature.
To reset hold the top 2 "buttons: Freezer and Fridge for 10 seconds. The panel will reset. Happened to us after a power failure.
Sep 17, 2010 | Samsung RM255LASH Side by Side...
Oct 19, 2009 | Refrigerators
Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Dash light on monitor no refrigerator temperatures shown on monitor how to reset
Hi there, I have the same problem with my samsung side by side the model no is- RSA 1Wtmh .
The light started blinking after a power cut and the elec came back on and the fridge light just blinks on panel instead of showing temp (the fridge and freezer are working)?
Jul 14, 2009 | Samsung Refrigerators
Zanussi ZFC 45/30 SS is hot at front between the doors..
This is normal. This is a defroster to keep moisture from condensation from freezing the doors shut.
Jun 30, 2009 | Refrigerators
MIELE KFN8762SDED (SS/fridge/freezer)
No problem just use the + and - buttons when you have chosen the temp. you want just let go and that is the temp the fridge or freezer will set at.
Aug 19, 2008 | Miele KFN8762SDED Bottom Freezer...
Zanussi electrolux frost-free
blinking is an error code of your fridge
I don't know the model of your fridge but try this it may help
IF THE CONTROL LOOK LIKE THIS
Jan 04, 2008 | Zanussi ZX97 / 5 Bottom Freezer...
GE Profile 23.3 Cu. Ft. Counter-Depth Side-by-Side Refrigerator - Stainless-Steel Logo
205 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
