Question about Toshiba Satellite L45-S4687 Notebook
The power cord for external speakers instead of the laptop power cord was plugged into the power jack on my laptop. That was undone and correct cord was plugged in however the unit will not power up now at all and the lights indicating the battery is charging does not come on. Could this be a battery issue or a motherboard issue?
  • 734 Answers
Hi There,
Your battery is almost surely just fine. But, your DC Power Jack has been damaged in at least one and possibly two ways.
1. The interior contacts or pins have been bent or broken.
2. The incorrect plug in caused a short on the motherboard and took out the cicuit paths for operation of both power and charging.
I am a pro laptop repair specialist and I use several different Power Jack repair vendors on eBay and have had only good experiences with all of them. While it's againt FixYa policy for me to recommend a specific vendor, you can go to eBay and in the search window type "Laptop DC Powerjack Repair". I suggest you compare pricing and ratings of the vendors by users and select an appropriate one.
If your laptop is still under warranty, contact Toshiba and they'll handle the replacement for you.
Good Luck
Posted on Aug 26, 2010
Can i connect juster speakers 675 to my dell laptop?
Plug the power transformer into the bottom jack on the back of the right-channel speaker. This is the speaker with the on/off knob on the front. 2 Plug the audio cable attached to the left-channel speaker into the audio jack on the back of the right-channel speaker. The jack is immediately above the jack for the power cord. 3 Plug the audio jack attached to the back of the right-channel speaker into the headphone jack on a laptop computer (usually located along the left edge), or to the audio output jack on the back of a desktop PC. 4 Plug the speaker transformer into a surge protector and the surge protector into a wall outlet. 5 Turn the on-off and volume control knob clockwise on the front of the right-channel Inspiron speaker to activate the stereo speakers and adjust the volume.
Aug 07, 2012 | Juster : SP-801 Twintower Speakers...
The speaker phone on our panasonic KX-T7633 dosn't go loud enough. We are trying to hook up an external speaker, but when we plug it into the headphone jack we just get a buzzing noise. Is there a...
There should be a way to do that. 1st make sure speaker jack is fully inserted. If you still have same problem try normal headphones and see if there still is foreign hum- then if headphones work, check the size of both the jacks to see if there the same- you might just have wrong size jack. If that is not the problem the Impedance(ohm symbol) is probably wrong and the phone doesn't have enough power to drive your speaker.. Use a speaker with same Impedance, you might have to use a speaker with its own power supply to get appropiate volume. You could try your PC external speaker. I hope this has been helpful.
Aug 25, 2011 | Panasonic KX-T7633 Corded Phone
I want to hook up my CD-BA2100 to my Inspiron 6000 laptop but i don't know how to hook it up or what to use.
The SHARP CD-BA2100 is a "stand-alone" cassette/CD/AM/FM player.
Its manual states that it can accept left/right stereo audio output, such as from your laptop, if you purchase the correct adapter cable (from "line-out" or "head-phones-out" on your laptop):
Video/Auxiliary (Audio signal) input
To listen to or record signals from external sources through this unit:
1 Use a separately available RCA cord to connect the desired external unit to the VIDEO/AUX jacks. (red ® right channel, white ® left channel) * When using video equipment (Laser Disc player or VCR), be sure to connect the audio output to this unit, and the video output to a television.
2 Press the ON/STAND-BY button to turn the power on.
3 Press the VIDEO/AUX button.
4 Operate the external unit.
5 To record the sound from the external unit ...
i.e., you can use it as the speakers for your laptop, instead of the laptop's tiny, built-in, speakers.
Mar 31, 2011 | Computers & Internet
Dell speaker connection color code needed
  • *Turn off your Dell laptop.
    *Connect speakers to the speaker control box. The speaker control box varies depending on the speaker system you have. Two-speaker systems will have a female jack on the back of one speaker that you plug the other into the second speaker. If your system has a sub-woofer, all of the other speakers will plug into it. The connecting cords are color-coded to the jacks on the back of the control box.
    *Plug an audio cable into the "Audio-In" port on the back of the control box. If the audio cable is color-coded, it will be green.
    *Plug the other end of the audio cable into the headphone jack on your laptop.
    *Plug the speakers' power cord into a surge protector to protect your system from power surges. *Plug the surge protector into a wall outlet.
    *Turn on your speakers and set the volume at a medium level. Be prepared to turn the volume up or down after you turn your laptop on.
    *Turn on your laptop and confirm that sound is coming from your speakers.
    Thanks for rating
    Good luck
  • Jan 25, 2011 | Dell Dimension 4600 PC Desktop
    Speaker volume
    This is a common complaint. The key to the diagnosis is that your MacBook is saying "Digital out, built-in output" instead of "Internal speakers, built-in output."
    The output jack on this model supports both traditional and optical plugs. A mechanical sensor inside the jack tells it which is inserted. The problem is that the jack is somewhat fragile, and some plugs can nudge the sensor out of position, in which case it thinks an optical plug is permanently inserted.
    If one has great repair skill, one can sometimes jiggle the connector back into position with a small pick (make sure the power is disconnected and the battery is out, if it is removable). Sometimes inserting a conventional plug into the jack several times will correct the condition. Otherwise, you should bring it in for repair and insist that it is a widely-encountered product defect.
    More information at forums.macrumors.com.
    May 14, 2010 | Apple MacBook Mac Notebook
    How can I connect my 4.1 creative speakers to HP Pavillion laptop? Is there are adapter that cnverts two wires from speakers to on thet can be pluged into laptop?
    Most external computer speakers have an input device that is like your standard headphone jack. Some have a cord built in for this, some don't.
    You should be able to plug these speakers into your standard headphone output on your laptop.
    Oct 26, 2009 | HP Smart Buy Notebook
    Built in speakers not working
    Are you using external speakers? or internal?
    EXTERNAL SPEAKERS: If your are plugging speakers into your headphone jack and they dont play, but you plug headphones into the same port and they work fine.. then it is the external speakers.
    INTERNAL SPEAKERS: But if you are using the speakers in the laptop, then your speakers are probably bad. Try some software settings, but probly just bad speakers. Could also be that the speaker cord inside the laptop came unplugged from the motherboard. In which case you would have to take the laptop apart and plug it back into the motherboard.
    Good Luck.
    Sep 08, 2009 | HP Compaq nx6115 Notebook
    No sound from speakers.
    Hi...
    On some stereo gear the headphone jack interrupts the speaker connection when the headphones are in. you "might" have something broken in the headphone jack which is keeping the speakers from turning on.
    Is there a MUTE switch on the unit?
    Or an "External speaker off" thingy in the menu?
    Sep 07, 2008 | JVC TH-M303 System
    Compaq C740TU speaker does not deactivates if external speakers are connetced
    The internal speakers should automatically be disconnected by inserting a 3.5mm jack plug in the audio out socket. It may be that your headphones or external speakers are using a 2.5mm jack which is too small to operate the switches in the audio out socket. Purchase a 3.5mm jack plug [cheap] and plug this in if it disconnects the laptops internal speakers then you need to connect accesories with the correct size plug.
    Mar 14, 2008 | Compaq Presario 700US Notebook
    Open Questions:
    Toshiba Satellite L45-S4687 Notebook Logo
    Top Toshiba Computers & Internet Experts
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
