I have an IBM Wheelwriter 3500 by Lexmark. The icon in the window shows a box with an upper left to lower right slash with the number 121. It turns on, beeps and will not allow anything to work. Help!
  • 1 more comment
  • lvnlawer Aug 26, 2010
    where do I find the connectors?
    when will I hear back? I checked the connections that I could see under the ribbon, disconnected the batteries, waited and I still have the problem. could the batteries create the problem?
    I have an IBM wheelwriter 3500 by Lexmark. When it turns on an icon of a box with an upper left to lower right slash along with 121 is shown. The machine beeps and stops. I was advised by another tec from your company to check the leads from the keyboard but I don't know where to find them. I checked under the ribbon, removed the batteries and left the machine off for 30 seconds. No help. any solution?
  • 19,396 Answers
Hi.
You can use the manual for the 2500 available here.
/121 is not reported as an error, try disconnecting power cord for 15/30 minutes to reset the typewriter.
Posted on Aug 26, 2010
  • 17,970 Answers
Error Code 121 means the keyboard is not recognized, check the connectors from the keyboard to be sure they are plugged in properly.
Try this turn it off remove the batteries, wait 30 sec. turn on all settings will go to default, memory will be cleared for any fault code stored.
Tell us news.
  • ZJ Limited
    ZJ Limited Aug 26, 2010
    Check if the battery are with the right charge.
HOW DO I CLEAR ALL TABS ON IBM WHEELWRITER 3500 BY LEXMARK TYPEWRITER
Tab all the way to the right, hold down the tab clear key, press return.
DickyO
Sep 19, 2014 | IBM Wheelwriter 3500 By Lexmark Electric...
How do I re-set the right margin for a IBM Wheelwriter 3500 Lexmark?
Go to the R. margin, press and release mar rel key, space to desired location press R. mar key.
DickyO
Mar 16, 2011 | Lexmark Wheelwriter 3500 Typewriter
How do I turn off the chirping sound on my IBM
If you hold down the "code" key and press the "S" key it will turn off the chirp.
Jun 03, 2010 | Lexmark Wheelwriter 3500 Typewriter
IBM Wheelwriter 1500
I may be mixing my models but I seem to remember that the power switch was located low on the right-hand side toward the rear.
Oct 10, 2008 | Lexmark Wheelwriter 1500 Typewriter
Wheelwriter 3500 KYBD 099
Check the ywo keyboard connectors to be sure they are plugged in fully, if they are then press & hold the code key, press & rel the "L" key type 001 then release the code key.
This will put you into the english keyboard mode. To cure the problem you need a keyboard.
DickyO
Oct 06, 2008 | Lexmark Wheelwriter 3500 Typewriter
Code 120
Tou can try pressing and holding the code key, press and hold the "L" key, release code type 001, release "L" key. Your keyboard may be bad this will select USA keyboard.
Good luck
DickyO
Mar 28, 2008 | Lexmark Wheelwriter 3500 Typewriter
IBM WheelWriter 3500
Try pressing and holding code key while pressing "L" release "L"
and type 001 release the code key. If this solves the trouble but it comes back on the next power up the keyboard is bad.
DickyO
Mar 25, 2008 | Lexmark Wheelwriter 3500 Typewriter
The wheelwriter 3500, don´t write, only (_ 121), what´s that? what can i do?
You may have the wrong keyboard selected. Try holding down the code key while pressing the L(lang) key.Release the L key and continue holding down the code key while you type the keyboard code number. USA keyboard is 001.
Feb 27, 2007 | Lexmark Wheelwriter 3500 Typewriter
jasbo
jasbo
