Question about Pentax PocketJet 3 Plus Thermal Printer
How do you put the pentax pocket jet 3 plus mobile printer into blue tooth discovery mode.
  • westyaa Aug 26, 2010
    Do not know exact model other than Pocket Jet 3 plus. and believe the plus is the blue tooth part of part #. Understand that I have had it blue tooth before my dongle just broke. Definitely Blue tooth capable
    I have a Pentax pocket jet 3 Plus model:PT-A4312. It is blue tooth capable and I had a blue tooth USB dongle that plugged into my laptop so I could print. This setup worked fine until I broke the USB dongle and I have purchased a new dongle. I need to get the printer into blue tooth "discovery" mode and do not know how to do it. So that I can get my new dongle communicating to my printer.
    President:
  • 4,070 Answers
Hi! I provided you a link that may help you. Hope this helps and thank you for using FixYa! Please click here http://www.education.brother.com/bluetooth/primer.html
Posted on Aug 26, 2010
    Top Expert:
  • Pentax Master
  • 77,169 Answers
Not all versions of this thermal printer are bluetooth ready, what is the exact model number, it would be listed in the user manual as well if it is bluetooth capable.
  • yadayada
    yadayada Aug 26, 2010
    I suggest u contact Pemntax customer support directly, we have no info on this printer and it sounds like you broke some part?
Cant connect bluethoot
If you are trying to hook up a blue tooth ear piece. You have to put the ear piece into discovery mode. See the instructions that came with the ear piece for how to do that. Then put your phone in discovery mode so they find each other. Then you will have to know a pass key and enter that into your phone. Most blue tooth pass keys are 0000 or 1111 or 1234. hope this helps FixYa up.
Aug 28, 2011 | Cell Phones
9xxPlantronics pass key to register bluetooth for PS3
to use the pass code for your blue tooth device you must first put the device into discovery mode then most blue tooth manufactures use a factory 4 digit pin pairing code they are as follows 0000,1234,1111,or 9999. i hope this helps
Feb 26, 2011 | Plantronics - Bluetooth Headset Plus Base...
Im just 13 so i cant pay anything but i'd appreciat help, I Would Like to pair my Plantronics 220 bluetooth with my Playstation 3 but i baught it used and do not have any instructions on how
ok first you must turn the blue tooth power to on in your games system menu,then you will have to turn your blue tooth device to discovery mode,to do that most blue tooth manufactures use the power button for this feature,by holding down the power button when turning on your headset for 6 to 10 seconds it should put your device into discovery mode,then you can add or search for the blue tooth device from your game system,once it finds it,it will ask you for a pin pairing code .most blue tooth manufactures use a factory 4 digit pin pairing code,they are as follows,try them from first one because i will put them in order from most common to least common,but one of them will work,they are 0000,1234,1111,or 9999, i hope this helps you have fun gaming
Feb 26, 2011 | Radio Communications
Can't remember how to pair my LG HBM-710 to my new phone - Samsung Fascinate. Can you help?
to pair a blue tooth device to a phone first you must turn the bt power on the phone to on,then you have to put your blue tooth device into discovery mode,now most manufactures use the power button for thisw feature.By holding down the power button on your device when turning it on for 6 to 10 seconds it usually puts the device into discovery mode.there should be a light that stays on on your blue tooth device.once you have the bt device into discovery mode you will be able to pair the device to your phone by search or add new device,once it pairs it will ask for a pin or pairing code.most manufactures of blue tooth devices use a 4 digit factory pin pairing code they aare as follows 0000,1234,9999,or 1111 once youve put tjhe pin code on they will pair ,i hope this helps
Feb 25, 2011 | LG HBM-710 Wireless Headset
Unable to put phone into pair mode motorola hs810 to a i phone 3g
Most blue tooth device manufactures use the power button to set your device to discovery mode,first you must turn the power to on for your blue tooth from your phone menu,then most manufactures use the power button to put the blue toooth device into discovery mode,by holding the power button down when you turn your device on holding it for 6 to 10 seconds,usually a solid light appears on your blue tooth device,it is now in discovery mode,on your phone menu there should be an add new or search devices,once you've clicked that it should discover your blue tooth device,then you will need a pin or pairing code,Most manufactures use a factory 4 digit pin pairing code the y are as follows 0000,1234,1111,or 9999, if you have done the steps correctly the menu will say connect,press conect and you should be connected..i hope this helps
Feb 22, 2011 | Motorola Mobility HS810 Consumer Headset
How to reset a bluetooth i.tech i.oval 303
Most manufactures have a factory 4 digit pin that once you have put it to discovery mode,usually blue tooth manufactures use the power button to reset the discovery mode,by holding the power button down while turning it on keep holding the power button for 6 to 10 seconds a light should appear on your device,thus the device is in discovery mode,once your blue tooth device has been put into discovery mode you should go into your phone menu and turn the blue tooth power on,then it should have an add new or seach for device,click that and it should pair with the phone,you will need a 4 digit pin pairing code,Most blue tooth manufatures use factory pairing pins they are as follows 0000,1234,1111,or 9999 try them in that order,i hope this helps you
Feb 22, 2011 | Itech i.Tech i.Oval 303 Bluetooth Headset
I turned my headset on and now the blue light is on and I cannot turn it off.
your blue tooth device is in discovery mode you must pair it with your phone again,it just you held the power button down to long turning it on ,most blue tooth manufactures use the power button for the discovery mode,in case you don't have the pairing pin code again most blue toooth manufactures use a 4 digit factory code,they are as follows 0000,1234,1111 or 9999 i hope this helps.And if your blue tooth drained the battery and you need to charge it before you proceed ,to put it into discovery mode hold the power button down for 6 to 10 seconds when turning your blue tooth device on.i hope this helps
Feb 18, 2011 | LG HBM-760 Bluetooth Headset
Driver for windows 7 of pentax pocket jet 3 plus
Every required driver can be downloaded by using this tool: Driver Update Software
I've used it many times, and it's awesome.
Cheers
Dennis
Jan 18, 2011 | Pentax PocketJet 3 Plus Thermal Printer
Pentax PocketJet 3 Plus Thermal Printer Logo
473 people viewed this question
Top Pentax Office Equipment & Supplies Experts
Johnny Massengill
Johnny Massengill
Abdul Mannan
Abdul Mannan
Are you a Pentax Office Equipment and Supply Expert? Answer questions, earn points and help others
