Question about Sceptre X7G Komodo II 17 in. Flat Panel LCD Monitor
Hello my sceptre was just turned on and the bottom half of the screen is a metallic gray. My regular screen saver can be seen on the top half with no problem. When I move the cursor it will go behind the bottom half gray portion. I have turned it on and off multiple time times, plus I disconnected the electricity and no change. We are unable to see the task bar as well. What does this sound like? What can we do to fix it?
5 Suggested Answers
SOURCE: Sceptre monitor will not return from idle.
The only workaround was to not use the DVI cable but to use the old VGA cable. You still get the same resolution.
I have a different ATI board, so I'm thinking it's an ATI+Sceptre on DVI input bug. Anyway, use the VGA cable, it'll work.
Posted on Aug 27, 2008
  • 11361 Answers
SOURCE: My sceptre 30
It can be the problem in the backlight inverter board or the power supply problem. You need to open it up and start looking for bad caps with bulging top first. Post back what you see inside. See example of failed monitors due to bad caps:
Posted on Mar 06, 2010
  • 11361 Answers
SOURCE: My Sceptre X9G Komodo IV 19 in. Flat Panel LCD
You have dying power supply due to bad DC filter caps, it will cause more damages if you do not start checking them out.
Basic LCD monitor troubleshooting guide:
Failed TV and Monitors:
Capacitors kit: he can make you a set of caps for you.
Please post back what you find.
Posted on Oct 08, 2010
  • 11361 Answers
SOURCE: Sceptre X9G Komodo II. When I turn it on, it shows
It does that when attached to another PC also? Need to narrow down the problem first.
Basic LCD monitor and TV troubleshooting guide:
Learn about bad caps:
Or just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Posted on Jan 12, 2011
How to turn off screen saver on an Acer Aspire v5
right click your desk top and select personalize
on the appearance and personalization page
at the bottom right corner is the screen saver click on it
screen saver drop down menu change it to none and press ok
Jun 03, 2014 | Computers & Internet
How to save power even you are still using old VGA Monitor
Older monitors(CRT type) are using complex circuit than LCD, It requires more power consumption than LCD, but you can still save power by 30% through this tip.
1.You must position or install your monitor in a dark area or position.
2.Adjust the brightness control to the level of the black part of the picture must be seen black not gray, or became white.
3. Adjust the contrast control at your most comfortable level.
4.Avoid using bright picture screen saver or blank screen saver.
5.Turn off your monitor manually if necessary.
on Jan 19, 2010 | Computers & Internet
Grey side bar on desk top screen
The picture or image you have chosen does not fit the screen. Go to your system preferences, Desktop &Screen Saver, click on the desktop tab and change the image to "fit the screen" or a variety of other options.
Nov 09, 2013 | Apple Computers & Internet
White screen
Do you always shut down and unplug the laptop when not in use? Has it been cleaned recently? Fan, Vents, heatsink? Has there been ANY damage? It sounds like your Graphics Adapter. screen, Inverter, is going? Have to say exactly. Does the Laptop Overheat?
May 12, 2013 | Dell Inspiron 1545 Notebook
How to trun of screen saver
Hello, to turn off the screen saver just follow these steps.
  • Open Screen Saver Settings by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Screen Saver.
  • To turn off all screen savers, under Screen Saver, click (None) in the drop-down list, and then click OK.
    - or -
    To turn on a screen saver, click a screen saver in the drop-down list, and then click OK.
    Hope this helps!
  • Apr 05, 2011 | Samsung N150 (36725723009) Netbook
    I can't figure out how to hook up hose attachment to dyson 07
    You have a reversible wand on the DC07. You have to separate the wand from the hose first, then turn it around and reconnect it. Once that is done you will be able to use the attachments on the end of the wand. You can also connect your attachments to the hose.
    To separate the wand:
    1) Take the wand off the back of the machine
    2) Place one hand on the Handle and one hand on the gray flexible hose.
    3) Push the flexible hose down. You will see a long metal rod appearing. Push until the hose clicks into place at the bottom of the metal rod.
    4) You'll see a half-moon shape button with a picture of a lock on the solid gray plastic part at the top of the hose - push it, this will separate the wand from the hose.
    5) Turn the wand around
    6) Push the purple wand cap with the holes in it back, it exposes a short dark gray pipe, about an inch in length
    7) Connect the hose to the short pipe
    8) Attach your tools to the top of the metal rod and have fun
    Jul 08, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
    Half of the screen turns black after 10 mins 46" Sceptre LCD TV
    Apr 10, 2009 | Sceptre X42GV-Naga 42 in. LCD Television
    Camera: Pentax S45 The top half of the screen is black with gray lines through it when turned on. When off the screen looks fine. Also turns off almost immediately after being turned on, despite...
    my camera has a gray screen and a black line at the bottom right corner and you can not see any thing you are looking at. what do i do!!!!!!!!!!!!!!!!!!!!!
    Apr 22, 2008 | Cameras
    Lap top screen problem
    your lcd screen was damged, this is seams to be a manufacture defect so call the manufacturer and ask him to replace if it is warrenty or otherwise throw it away, here after that is like a broken glass
    Mar 19, 2008 | Computers & Internet
    Sceptre X7g Monitor Flashing Red & Blue Lights. Blank Screen
    i fixed this problem by unplugging the monitor, unplugging the video cables. Then hold down the power button while plugging it back in. Release power button and then press power button for on. It worked then. I got the icon for no signal, i plugged back in my monitors. Sceptre X9W
    Sep 11, 2007 | Sceptre X7GNAGAV 17" LCD Monitor
    Sceptre X7G Komodo II 17 in. Flat Panel LCD Monitor Logo
    Top Sceptre Computers & Internet Experts
    Ricky Ostrom
    Ricky Ostrom
    Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
