Question about Fellowes PS70-2CD Shredder
Looking for a replacement paper bin that goes with our Fellowes PS70-2CD can I find such a thing?
3 Suggested Answers
butterfly910
  • 3 Answers
SOURCE: Fellowes Powershred 220 (1999)
Go to fellowes.com and go to contact us or about us and you should be able to find some info and how to get a replacement.
Posted on Jan 23, 2009
SOURCE: Fellowes S8-*5c
If this is actually an SB-15C I posted a solution elsewhere and will repeat it:
I called the toll free number for Fellowes Help Line, 800.955.0959, and spoke to John who was most familiar with the SB-15c. I indicated that the "bin full" LED was bad (actually the transmit bulb). After John ascertained that I had indeed cleaned the bulbs, he made available a replacement part, MasterCard or VISA required. Replacement of these bulbs is not for everyone. A level of technical ability and some tools will be required.
I have never had this level of technical support available on the first call. Kudos for Fellowes.
Posted on Jul 07, 2009
Where can I find the paper bin for fellowes ps80c-2 series
find a plastic waste basket that fits under it at Walmart
May 17, 2015 | Fellowes Office Equipment & Supplies
What causes the Fellowes Powershred SB-15C shredder to show that it's full when it isn't?
Check and make sure there is no paper or paper dust covering the Bin Full sensor. underneath the head.
Aug 03, 2014 | Fellowes Office Equipment & Supplies
Why is the fellowes blade still rotating even when there is no paper?
It is possible that a small shred of paper is lodged at the sensor underneath the cutting blade.
    • 1 Unplug the paper shredder. Empty the shreds from the collection bin. Pull as much stuck material as possible from the top and bottom of the shredder blades with pliers or use canned air and blow the edges of the blades.
    • 2 Place the paper shredder back on the collection bin base and plug the shredder back in. Rock the shredding direction back and forth between forward and reverse.
    • 3 Make two passes across the cutting blades while drizzling synthetic shredder oil. Switch the direction to forward to run continuously for one minute.
    • 4 Lower two sheets of clean paper into the shredder. The paper removes excess oil, metal fragments and debris from the cutting blades. Blast the blades with compressed air when you notice a build-up of small paper scraps that may cause a jam.
Sep 26, 2011 | Fellowes Intellishred PS-79Ci Shredder
We have a CR220 fellowes shredder. It will shred 1/2 of a peice of paper, then the basket full light comes on even tho the basket is empty.
you can try cleaning the "bin- full" sensors. they are located on the inside of cabinet, on the bottom of the shredder "head". one will be to the left side of basket and one to the right. they kind of look like little glass eyes mounted inside of black rubber casings. paper dust on these will do this sometimes. if that doesn't do it then it sounds like your "bin-full" sensors are bad. a known problem with these shredders. fellowes has come out with modified sensors. if it was purchased within 2 years, it should still be under warranty.
hth,
razors
Mar 10, 2011 | Fellowes Office Equipment & Supplies
No longer shreds. Probably overloaded. Looking
The punching holes/not shredding problem is caused by a collar that encapsulates the cutter shaft ends. Vibration causes the collar to fall off and the shafts to spread apart. The fix is to pull the paper bin out, remove the 5 screws holding the top assy., and pull off the top. You'll see the collar and the screws will be somewhere in the paper. Replace the collar and tighten all the screws at each end of the shredder assy.
Apr 05, 2010 | Fellowes DM15C Shredder
Full bin light is always on!
On most shredders the full bin sensor is actuated with a plate just under the cutter head. When the bin gets full the paper builds up and pushes the plate back.
Be sure to unplug main power before during any service.
Try wiggling the plate back and forth to clear out any backed up paper.
Jun 04, 2009 | Fellowes Manufacturing Powershred C-480C...
Fellowes S8-*5c
Feb 13, 2009 | Fellowes Powershred SB-85C Shredder
The "bin full" keeps on coming on
first off, fellowes has had problems with the bin full sensors that sometimes, can only be corrected by replacing them. however, there are two things to check. make sure it doesn't have a bunch of shredded paper hanging down from the cutters. that can trigger the bin light as the sensore are located under the head, but above basket. last, but not least, clean the sensors. they get paper dust on them after awhile causing same indication. if those two things don't fix it, it will have to have sensors replaced.
good luck,
razors
Jan 20, 2009 | Fellowes Manufacturing Powershred C-220...
Shredder Motor goes in reverse, but will not run or shred, or go forward
The first thing you want to check is the mechanical paper feed sensor. It is located in the center of the paper throat. A switch that gets pushed back when paper is inserted. Sometimes paper gets stuck behind it and you can jiggle the switch to work it loose. If that does not work try moving the basket around a little, this unit has a magnetic safety interlock switch located under center of basket. If niether of these help you please contact us at Fellowes Customer Service 800-945-4545.
Mar 01, 2008 | Fellowes 3011001 Shredder
Fellowes PS70-2CD Shredder Logo
137 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
