Question about Jandy Lite 2 Natural Gas Pilot Light Heater
I have a Jandy Lite 2 heater and I keep getting an error message FL 0. What can I do to get this heater working?
    Top Expert:
  • Jandy Master
  • 8,673 Answers
Check the copper line to the pressure switch if ok check pressure switch should have 24 volts ac both sides if ok check rest of safety circuit
Posted on Jan 30, 2016
5 Suggested Answers
  • 246 Answers
SOURCE: getting error code 188E on Jandy Model LT Lite 2
press the arrow key for 10 sec this will reset the heater. if code replace control board, if not enter time date and set temptures for pool and spa
Posted on Oct 16, 2009
  • 21 Answers
SOURCE: FL 4 error, Jandy Lite 2 pool heater
I believe you may have a draft restriction and this may stop the start up diagnostics. The draft detection switch is sometimes restricted or weak. Common problem. Tap the gas valve to see if the winter has caused the valve to seat heavily and stick.
Posted on Apr 25, 2010
john224
  • 1378 Answers
SOURCE: Jandy Lite 2 pool heater
Thank you for posting your question here on Fixya.com.
Page 34 and 35 of your manual, found here, describe FL0 as a flow issue most likely caused by dirty filters. Depending on the type of filter you have a good cleaning/backwash will usually remedy that. It is also possible the unit's pressure switch, which senses water flow and therefore reacts to dirty filters when present, may have failed, especially if you winterize the heater in a cold climate and leave water in the switch which can burst the diaphragm inside.
Start with cleaning the filter. If the heater still won't fire jump out the pressure switch while the pump is running to confirm the part is the problem. Assuming it is replacing it with a new pressure switch which should be under $75. The part number can be found in the rear of the manual.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Posted on Apr 29, 2011
john224
  • 1378 Answers
SOURCE: getting FL0 error message.
John
Posted on Jul 22, 2011
Fl 7
get pump working first see if you have 24 volts to pressure switch both sides if so check the rest of the safety circuit
May 25, 2014 | Jandy Lite 2 Natural Gas Pilot Light...
FL 0 code on my jandy lite 2
is there water dripping from copper tube if not clean out copper tube and poke into where goes into heat exchange they get calcium
Feb 10, 2014 | Jandy Pool & Spa
Jandy lite 2 pool heater will not stay lit.
I'm having the same issue as the above user with Jandy Lite 2 (which from what I can tell stands for the number of times that you can get this POS to work annually)!
The unit LIGHTS OFF, but WON'T STAY LIT! Igniter engages, gas valve opens, unit lights, burns for 10 seconds, and flames out. Error code FL 2, after third attempt, already replaced the flame sensor....
May 12, 2013 | Pool & Spa
Jandy lit 2 heater error fl 6
gas signal being sent to gas valve not by controller either stuck gas valve or bad control board
Apr 14, 2012 | Jandy Lite 2 Natural Gas Pilot Light...
JANDY LITE2 LJ HAS A FL-2 CODE WHEN HEATER STARTS
check gas flow, check for cobwebs in gas orfices also check if 24 volts ac to the brown gas lead if not check safety circuit if so bad gas valve
May 31, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
I am getting an FL 2 error code on my jandy lite2. I changed the flame sensor and still get same error message
Look at the list of codes inside the cover of the heater. Your owners manual should have a complete remede for all codes.
May 27, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
FL 4 code Hot surface igniter problem on Jandy Lite 2
fl 4 bad ignitor or bad fuses if fuses ok replace ignitor
Apr 01, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
Jul 29, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy Lite 2 Natural Gas Pilot Light Heater Logo
78 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
