Question about Kenmore 79383 Dual Fuel (Electric and Gas) Kitchen Range
OVEN WILL NOT HEAT, BOTTOM ELEMENT NOT WORKING
  • 3,037 Answers
Well, to ensure the element is bad, you can take an ohm meter to the contacts of it and measure the resistance. It should be around 20 ohms. If it is much greater or infinite, the element is bad. To get to the contacts you will need to unplug the oven, pull it away from the wall and remove the rear panel. Then disconnect the element wiring and touch the probes from the meter to the contacts on the element. You can order a new element locally or from repairclinic.com. Let me know what you find.
Benjamin
Posted on Nov 04, 2010
4 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Oven not heating up
can you see the bottom element?? if so usually , its obvious when the element goes bad, youll see the damage.TURN OFF POWER. 2 screws remove elemnet from the front 2 wires, plug in aa new one and your good
Posted on Mar 01, 2008
SOURCE: GE Spectra XL 44 Gas Oven Bottom Heating Element Faulty
How do you get to it? On my stove there is no access panel
Posted on Mar 06, 2008
  • 63 Answers
SOURCE: The heating element on the bottom of the oven does not work.
lots of those old elements are still out there...some come out with simple pull...or two screws holding the wires!.. take to appliance store (sometimes even lowes!)
Posted on Mar 16, 2009
Maytag oven won t heat up
the upper element only comes on when you broil or clean with selfcleaner. the bottom comes on when you are baking, it sounds like your bottom element is bad.
May 07, 2014 | Maytag Ovens
Kenmore electric oven bottom element not working
check thermostate control sensor its locate behind the heating element. check continuty .if its fail .replaced correct value.
GKM
Jan 07, 2014 | Ovens
Frigidale 10 years old stove bottom heating
Have 10 year old fridgidare elec.oven. Model no.FEF355ASE and both bake and broiler have stopped working have power and ohm's are good. Whats next ?
Jun 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven's bottom heating element does not heat
this should show you how to change it
You-Tube video "pEhRqdvpiJM" placeholder (do not delete)
The main fault when the oven is not heating is that the element has blown here is a video on how to change your fan oven element and the motor.
For all your fan oven element click here
Jan 07, 2010 | Frigidaire Ovens
The fan and oven light in bottom oven works but not heat.
The heating element is the likely culprit as they burn out and go open
circuit..(ie ...disconnected and will not heat up )
If you can use a multi-meter , then the element can be tested using the resistance range (with the oven SWITCHED OFF )
Aug 30, 2009 | Neff U1721 Double circotherm Electric Oven
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
The oven stopped working and heating up. The top range part works.
I suspect a heating element in the oven has burned out. Some ovens have 2 heating elements, one on the bottom for baking and one on the top for broiling. If this is the case, you can try setting the oven on broil and see if the top element gets hot. Usually the bottom element fails first because food gets dripped on it. In most cases you can unplug the old heating element by just pulling on it and plug the new one just as easily. You can check the resistance of the heating element with an ohm meter. If it's burned out the resistance will be very high, probably greater than a mega ohm. In some cases you will need to take the back off the oven to replace the heating element. Just make sure the oven is unplugged and cool when you start working on it.
May 11, 2009 | GE Ovens
GE range - oven stopped working after cleaning
If you bent the bottom element out list out of the way, you may have broken the actual heating element inside of the metal sheath. Or, it could have shorted to ground.
After tinkering with it more, you might have caused another short, and now both legs of 220 VAC have either a blown fuse or tripped breaker.
Reply what you find is the sondition, and I will help you troubleshoot more.
Jan 24, 2009 | Kitchen Ranges
Kenmore 79383 Dual Fuel (Electric and Gas) Kitchen Range Logo
422 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
