Question about Dell Computers & Internet
Where is the battery located on a dell desktop computer? When logging on, I keep getting a message that the battery is low, press f1 or f2
  • 395 Answers
Its a little watch battery on the motherboard, make sure the unit is unplugged when you remove and replace it, take the old one to walmart and they should cost around $3 each
Posted on Aug 26, 2010
I get this message when I boot my computer Strike F1 to retry boot . F2 for setup utility. What does this mean? and what can I do..F1 doesn't do anything and F2 everything looks correct? any assistance...
It means that something is wrong with your setup - my first guess is that your computer backup battery has gone bad, but it may be something else.
Press F1 to retry - if the computer starts, check the system date/time (usually in the right-hand corner of the toolbar - the opposite end of where the Start icon is located).
If the computer does not start, press F2 - you will be entering the BIOS (Basic Input/Output System) and you really should not change anythig unless you are familiar with what the terms mean. BUT - it will do no harm to change the date and/or time if they are incorrect.
Exit out and the computer should now boot automatically.
If it DOES boot, then the battery is weak or dead. You will have to shut down the computer, open the case and replace the quarter-sized battery - usually 3volts.
While you are in there, blow out any accumulated dust - and don't forget the power supply.
Close the case and reboot. You will still get the error, but this time, once you reset the date/time the computer will "remember" the settings and you will be good to go for a few more years.
Dec 24, 2010 | Dell OptiPlex GX200 PC Desktop
On the Boot-up screen I get the message: "Diskette
I think you should press F2 to go to the setup page.
There, you should change the order of your boot device.
set the first boot device to hard disk
set the second boot device to cd rom
and the third to floppy.
follow the instructions and click save and continue
Dec 22, 2010 | Dell Inspiron 530 Desktop Computer
Have a Dell XPS 600 problem. I am getting a message when I turn on the computer, "Keyboard Failure Alert! System battery voltage is low. Strike the F1 key to continue, F2 to run setup utility." What should...
If you have another keyboard try swapping it out and see if it reads the new one. Also a stuck key could possibly cause this error. System battery message probably means you need a new battery for the motherboard. If you replace the battery get the new one before removing the old one. If you leave it out too long you can clear the CMOS
Oct 14, 2010 | Dell XPS 600 PC Desktop
My Desktop Dell Optiplex GX200 computer says Alert! Cover was previously removed. Strike F1 to retry boot . F2 for setup utility. I never opened my computer and when I click F1 it doesn't do anything but...
If it is not keeping time then you need to replace the computers clock battery. The battery is a cr2032 battery usually.
follow the below link for instructions on how to do that.
http://support.dell.com/support/edocs/systems/opgx200/en/sm/index.htm
Sep 01, 2010 | Dell OptiPlex GX200 PC Desktop
Computer that keeps saying F1 to reboot F2 for setup utility
what is the message you getting?
if it is to press F1 key to contiune then u need to replace ur cmos battery. you will find the battery on ur mother board, if there is no battery then you need to buy a new battery .
good day
Jun 05, 2010 | Dell Dimension 4600 PC Desktop
OptiPlex GX110 PC Desktop: Hello.. I'm having Dell Optiplex machine.When I t...
Generally an indication that the Hard Drive isn't detected
Things to check, go to BIOS F2, reset defaults and reboot, see if the HDD is seen. If it is, the battery on the motherboard is likely dead and needs replacement (Watch battery at Walmart, 3 dollars)
If the HDD doesn't detect after resetting the BIOS, then most likely a Hard Drive failure
May 18, 2010 | Dell OptiPlex GX110 PC Desktop
After post screen system ask to press f1 or f2
Is there another message besides the F1 or F2 prompt?
Does it happen to mention CMOS settings at all? Usually this will happen if your CMOS battery has died, and will be fixed upon replacement. It is normally a CR2032 lithium battery, easily obtained at radio shack, walmart, etc. and super easy to replace.
Jun 22, 2009 | Dell Dimension C521 PC Desktop
Computers & Internet Logo
100 people viewed this question
Alun Cox
