Question about Haier HRF14 Top Freezer Refrigerator
My refrigator door rubber is gone - Haier HRF14 Top Freezer Refrigerator
  • Haier Master
  • 43,501 Answers
Yes, that is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Aug 28, 2010
Refrig door does not seem to close as tight as it used too. Do I change rubber gasket? Will that help Frig is not very old.
look for door hinge problem as the door seal may be bad but i think the hinge cams have failed .. mm
Aug 09, 2010 | Maytag MZD2766GES Side by Side...
How do I remove the door on a dometic 1292 RV
peel back the rubbers and you will see screws undo then and the plastic door ligning will come of with the seal taske of old put on new and replace in reverse
May 15, 2010 | Dometic NDR 1292 Refrigerator
On the top back of the fridge is a unit that seems to be connected to the freezer. It leaks intermittently into the refrigerator and pools under the crisper baskets as well as wetting food that is on the...
Looks like you have a clogged drip tray channel. Unplug the refrige ,leave freezer and food compartment doors open for at least 12 hours. After that look under behind the refrige for a plastic-rubber tubing ending in the drain pan under the refrige.That is clogged, get a 2 feet hose 1/2 inch diameter. Attach end to the drain tubing then blow through this will clear the way.. and your done.
Dec 31, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Hot strip between doors
First , remove the bottom kick plate , and vacuum the coils . They have to be clean of dust , lint , pet hair , etc . Then pull the refrig out , and remove the lower panel , to expose the compressor and cooling fan . This fan HAS to be working , to cool the compressor AND the coils . If not running ( fan ) , check for an obstruction of paper , insulation , etc , and remove the cause . If not being obstructed , and not running , replace the fan motor . Afterwards , be sure to reinstall the back panel , as this panel , helps pull the airflow across the coils , and compressor . The strip between the doors , has part of the coils behind it , and will get hot , if the coils in front are dirty , or , the fan behind the refrig is not working .
Dec 04, 2009 | Whirlpool Refrigerators
Freezer door pops open when fridge door is closed.
well u need to check the rubber of ur freezer ;s door .some damaging in the rubber is causing the problem.
May 26, 2009 | Amana ARSE66MB Side by Side Refrigerator
Refrig door hits cabinet
If you change the hinge you will void warranty on the unit. Really just be careful when you open the door.
Mar 23, 2009 | U-Line Origins 1175R Refrigerator
Refrigerator rubber door handle
no fix
any paint you use will wear off and any chrome paint you use will wear off also
GE spares may still have the items as spare parts so call them
Nov 03, 2017 | Refrigerators
On electronic control panel and water/ice despensor the ice cube door keeps opening and closing and the buttons on the panel do not respond tempratures of fridg and freezer keep flashing. Tried unplugging...
you have a maytag ice and water in door 3 door refrig???? if so you needs a new high voltage board, its gone bad. locatdon back wall behind the refrig. only resolution is to replace the board..
Mar 16, 2008 | Refrigerators
Haier HRF14 Top Freezer Refrigerator Logo
51 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
geob91
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
