Question about KDS Valiant 681XH PC Notebook
I am from Argentina and I have a problem with my intel III KDS notebook when I get an error I turn blue in this technical description: 0x000000ED (0x80e2cd8, 0xc0000006, 0x00000000, 0x00000000) ... and after a few seconds I get a tiny graphic that says "warning" and has a drawing of a thermometer from now ... thank you very much and please brindenme na solution because I'm desperate ... thanks again
UN MOUNTABLE BOOT VOLUME ERROR - BLUE SCREEN on a dell latitude D505 laptop
try to boot to safe mode using F8 key on boot and then recover system or reinstall OS
Nov 13, 2012 | Dell Latitude D505 Notebook
When I switched on my Dell computer - bright blue
this error usually is for hard drive issue. if an operating system reinstallation wont work, a hard drive replacement should resolve this problem.
May 26, 2010 | Dell Dimension 4600 PC Desktop
Possible hardware crash??!!
Need to know your operating system ... Windows 7, 8, 8.1, 10?
0x000000ED suggests a hard drive problem. It may be mechanically failing or it's file system is corrupt. To fix corruption, you need to start your computer from a CD or DVD, or thumb drive which has utilities for fixing hard disk file corruption. Such a disk/thumb drive can be found, downloaded, created from the Internet but you will need a working computer to create the utility media.
Probably
Ultimate Boot CD Overview
will help you deal with this.
Dec 14, 2017 | Maxdata Pro 650T Notebook
Stop code 0X000000ED (0X832DC230,0XC0000006,X0X0000000,0X00000000
This might help you out --> http://support.microsoft.com/kb/315403
It basically says that you have to go into the Recovery Console and run chkdsk /r. Also this site has a fix for this type of STOP error that you can try to install after you are able to run chkdsk /r on the hard drive. Let me know if you need any more assistance with how to get into the recovery console, installing the update, etc....
Serge
Apr 08, 2009 | Dell Inspiron 1525 Notebook
Blue screen
This is an operation system error. You will need to run a repair with your recovery disc or operating system disc.
Jun 18, 2008 | Compaq Evo N610C Notebook
Toshiba PSA60L-004003
1. Try removing the memory
2. Try removing the hdd (try to use another ide drive)
3. try removing the cdrom
In that order try to remove them clean them, or use a spare, and see if the error pops up again.
Apr 09, 2008 | Toshiba Satellite A60 Notebook
KDS Valiant 681XH PC Notebook Logo
79 people viewed this question
Top KDS Computers & Internet Experts
Denise
RobertFonner
RobertFonner
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
