Question about Texas Instruments TI-36 X Solar Calculator
Lower half of numbers gone
Hi to one and all; sn N 0397 only half the numbers on display can be seen.
is there any fix available?
Thank You
bygeorge
Remove the back cover. Do this by removing the 6 philips screws. Look for the red (+) and black (-) wires from the solar cell. Place 3 volts across the wires. this will unpolarize the solar cell / battery.
Posted on Aug 21, 2012
    Genius:
  • 1,665 Answers
    Genius:
  • 1,142 Answers
Try a hard reset...take the batteries out..keep the on button pressed for 10 seconds..leave it turned off for 5 minutes with no batteries...then turn it back on by reinserting the batteries and check
Posted on May 06, 2008
  • Maanita Chadha
    Maanita Chadha May 06, 2008
    if that does not work it is possibly an issue with the diaply cable which is like a plastic ribbon connecting the diaply to the main circuit board. you can get the same repaired through a service technician
    Genius:
  • 3,422 Answers
The only solution which can be tried is replacing the battery.
Goodluck.
Hi l have senao phone sn 258 don't worke my screen have key name ( in use ) flash all time and all key not dilling plz l need it worke
Hello
Is it your phone model SN-258 Plus with out display ?
Is look that you just lock the keyboard
You can unlock with fast pressing two time for PTT button on handset
Thank you
Mr.Boban
www.longrangephones.net
Jan 22, 2014 | Cell Phones
Panasonic viera
Try replacing your video cable, if that doesn't work, try using a different input on the T.V. If that doesn't fix it, you may be out of luck with out an extended warranty.
Dec 06, 2013 | Panasonic TH-50PX75U Plasma HDTV
Philips 50" Plasma with ambilight
It sounds that there is some loose contacts to some connections to your Plasma display. Almost all plasma displays will have similar configurations to display circuits, will change only with the size of the screen. If you wish to get some details http://electronicshelponline.blogspot.com/ Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
Jun 03, 2013 | Philips 50PF9631D 50 in. HD-Ready Plasma...
Display is gone. background light is still there on my harmen karden advanced audio system on my 06 s.g.
there is an "update" available for this model years stereo which should fix the problem. I have seen it in cyberspace. DL and install and see if it helps
Jul 12, 2010 | 2008 Harley Davidson FLHX Street Glide
My 5 years old Plasma TV found half of the screen picture view not very clear.. The half colour seen blur..
Your Buffer boards or the YSUS main are bad. THe YBU-Y Buffer upper controls the top half of display, the YBL-Y Buffer lower controls the bottom half and the YSUS Main controls both those boards. They are located to the Far Left on and opened Set.
Jun 21, 2010 | Philips 42PF9966 42 in. HD-Ready Plasma...
Philips tv 20pt1782 want service manual
hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me.. hi! this is shiharan.i am repairing a philips20PT,crt type tv.the problem is that only the lower half(vertical) portion of the picture tube lights up to display pictures.after taking off the back cover i am not been able to locate the horizontal,vertical driver IC.Perhaps the driver section is built arround FET.Please help me..
Jun 10, 2010 | Lexmark All-in-One Printer with PictBridge
My plasma, bottom half of the screen is black and goes in and out. Now it's staying black on the bottom half of the screen. What's the cause of this and is it expensive to repair?
Hi, It is your lower Y sus Buffer. Runs about $80
BN96-03362A Y main buffer lower.BN96-03361A Y main buffer upper. Encompasparts.com Also try Shop Jimmy, And Ebay. Sometimes they are lower in price.
Oct 31, 2009 | Samsung HP-S5053 Television
I need authorized code for this: sn.1045 0436
Im sure that FixYa.com isnt affiliated with any kind of illegal acts like sharing keys for programs.
So call adobe and get your code as its shows in your installation.
Oct 10, 2009 | Adobe Photoshop CS for PC
After a drop, iPhone lower half of screen does not respond
its a problem with the touchscreen itself and that needs to be replaced..ive seen a lot of these lately and the last reeason would be replacing the lcd since formatting or restoring wont do any help.
Oct 14, 2008 | Apple iPhone Smartphone
SAECO Magic Roma SUPO13 sn#163830
yes there are parst available but it sounds that the boiler has a leak. You can get a gasket set for it but it aint an easy fix
Nov 12, 2007 | Saeco Vienna De Luxe Espresso Machine
Texas Instruments TI-36 X Solar Calculator Logo
315 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
