Question about Casio Protrek Triple Sensor PRG80T7VDR 4 6 Watch for Men
I purchased a casio protrek PRG-80T-7V 2 years ago. I haven't experienced any problems with it until recently. When I traveled abroad i passed through the ray gate in the airport wearing my watch. This made the compass showing wrong indications. I read the instructions in the manual and performed both bidirectional and northern calibration but without any result. The are is not a display of error either. It performs both the calibrations processes but then it still gives wrong indications. Was the sensor damaged or magnetized in the airport? Can you advice me what to do?
  • 1 more comment
  • syrimisch Aug 26, 2010
    Thanks for the advice! I took the watch to a casio dealer who took the battery off and reset the watch. The compass still doesn't work. The barometer and altimeter though work ok. Is this possible if the sensor was damaged?
    Thanks!!!
  • Casio Master
  • 19,396 Answers
Re:"When I traveled abroad i passed through the ray gate in the airport wearing my watch. This made the compass showing wrong indications."
The strong electromagnetic field produced by airport detectors can damage electronic devices.
Try removing the battery for five minutes to reset the watch, if that does not fix the problem , then the internal chips are irreparabaly damaged.
Note: the battery is replaced opening the back plate. The back plate of the Casio can be opened at home using a pair of tweezer, then taking care not to damage the rubber seal, battery is flipped out and replaced. watch is reassembled by placing the seal in correct way and using the tweezers to screw the back cover.
It may look like a simple operation, but if it is not being done properly you can compromise the impermeability of the watch. I suggest having the job done at an authorized shop.
If battery reset does not help, then the watch logic circuits got damaged by the airport scanner.
Regards.
Ginko.
Posted on Aug 26, 2010
  • Ginko
    Ginko Aug 26, 2010
    HI:
    Re:I took the watch to a casio dealer
    work. The sensor (which is a chip ) had been damaged by the strong elecromagnetic field from the airport scanner. The sensor is sensible to elecromagnectic forces within the range of the earth field. The airport scanner litterally blew it up!
    I do not think this kind of damage is even covered by warranty.
I need to buy strap only for model prg-110b
Go to your local Jewelry (watch) H samuels , HINDS bout expect to pay a lot .
Dec 24, 2015 | Casio Protrek Triple Sensor Prg 110T 7VDR...
Change time on a protrek casio triple sensor watch
You can download the manual from the link below. The timekeeping instructions are found on pages E-19 - E-24
http://support.casio.com/en/manual/009/qw5213.pdf
Mar 10, 2015 | Casio watch PRG-550-1A1 PRG550 Casio...
I dont know how to turn the alarm off on my casio protrek triple sensor watch and it alarms each midnight!?
Scroll through the screens until you get to the alarm screen and select the barometer button to turn alarm on and off.do not go into edit mode.
Sep 03, 2011 | Casio Protrek Triple Sensor Prg 110T 7VDR...
My Casio Protrek PRG 120 triple sensor show an "open" message and I am no longer able to program the functions and including the alarm. Please tell me what I should do.
it's because the contact that sense whether the watch is opened or not is misaligned.
Just open the watch caseback, re-allign the gold contact on the case-back, and make sure it touches the spring in the other side of the watch.
Aug 29, 2011 | Casio Protrek Triple Sensor Tough Solar...
Hi, I have a casio protrek PRG-80T-7V(triple sensor). I haven't experienced any problems with it until recently. When I traveled abroad i passed through the ray gate in the airport wearing my watch....
Try to reset the watch.But first be sure that you capable of doing this.
Reseting the watch procedure:
1)Remove the back cover.Be sure that you have the appropriate screwdriver.Keep the 4 screws safe, not to loose them.
2)On the chassis of the watch (metallic surface) somewhere there is a hole with AC (All Clear) written nearby.
3)Use one little thin retracted paper clip (not totally retracted).Insert the retracted end of the clip into the hole, gently, until it touches the end and with the upper part of the clip contact the chassis (metallic surface). Wait for 1-2 sec and remove the clip gently.The watch is now reset.All functions have been set to factory settings.
4)Put back in place and with caution the back cover, respecting right (up-down) positioning and taking care that the O-ring gasket is well in place,first.
5)Holding in place with one finger the back cover,screw back screws gently and without applying excessive force (delicate job) until you meet resistance, in the following order:
Up-right,down-left,up-left,down-right.
After setting the time/day/date etc try to calibrate compass both ways as you did before.
I hope this will solve your problem.
NOTE:Again,be absolutely sure that you are capable of doing this.
It is a bit delicate job.If not,you better bring the watch to an official CASIO service center.
Apr 27, 2017 | Casio Protrek Triple Sensor PRG70 1BVDR...
I cant change the temp to celsius on a protrek triple
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
May 15, 2010 | Casio Protrek Triple Sensor Tough Solar...
I need an english instruction manual for my casio protrek the number on the back is 2272 prg-40sj
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please .
Apr 07, 2010 | Casio Protrek Triple Sensor PRG70 1BVDR...
Casio PRO TREK error 'OP EN' Display frozen with the above msg. None of the buttons - except the light - works. Whats wrong .. battery charge shows FULL
The problems is very simple: On the back cover (inside) is a little Cu metal Part. This part is glued to back cover using a poor glue (rubbered glue) and, in time, is moving from original position. You must put back this parts to original positin ( a little hole inside of back cover) and glue using a good glue. When the back cover is mounted , this part must have a ferm contact with two springs from mechanism (sensor for back cover open). If beatwin this springs isn't a electric short (using Cu metal parts) the internal mechanism of watch "see" the back cover is open and show "OPEN" on screen!
Mar 22, 2010 | Casio Watches
Casio Protrek Triple Sensor PRG80T7VDR 4 6 Watch for Men Logo
194 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
