What is the tcc - Office Equipment & Supplies
    Genius:
  • 1,218 Answers
Hav'nt heard of a tcc, there is a tcr; which is the Transmit Confirmation Report.?? Hope that helps.
Posted on Aug 29, 2010
What does the TCC code mean for chevy s10
The Torque Converter Clutch (TCC) solenoid valve is an electrical device that is used with the torque converter clutch pulse width modulation (TCC PWM) solenoid valve in order to control TCC apply and release. The TCC solenoid valve attaches to the transmission case assembly extending into the pump cover. The Powertrain Control Module (PCM) controls the solenoid by providing the ground path. The PCM monitors the throttle position (TP) voltage, the vehicle speed and other inputs in order to determine when to energize the TCC solenoid valve.
replace the relay.....its common for it to go out.
Jun 29, 2014 | 1997 Chevrolet S-10 Pickup
Engine code 894
DTC P0894 Transmission Component Slipping
DTC P0894Circuit Description with 4L80-E / 4L85-E Automatic Transmission The powertrain control module monitors the engine speed and the transmission output shaft speed. The PCM calculates turbine shaft speed and torque converter clutch (TCC) slip speed by using inputs from the automatic transmission input shaft speed sensor, automatic transmission output shaft speed sensor, and other transmission components. The forward clutch housing is used as the AT ISS rotor. Whenever the TCC is engaged, engine speed and turbine speed will closely match, indicating low TCC slip speed. In D3, with the TCC engaged, calculated transmission component slip can only occur in the torque converter. In D4 OVERDRIVE, with the TCC engaged, transmission component slip can occur in the TCC or the fourth clutch assembly. If the PCM detects an excessive TCC slip speed in D4 OVERDRIVE, when the TCC should be engaged, then DTC P0894 sets. DTC P0894 is a type C DTC. For California emissions vehicles, DTC P0894 is a type B DTC.DTC Descriptor This diagnostic procedure supports the following DTC: DTC No MAF sensor DTC P0101, P0102 or P0103. No MAP sensor DTC P0106, P0107 or P0108. No TP sensor DTC P0120 or P0220. No VSS DTC P0502 or P0503. No ISS DTC P0716 or P0717. No TCC Stuck Off DTC P0741. No TCC Stuck On DTC P0742. No 1-2 SS valve DTC P0751, P0752 or P0753. No 2-3 SS valve DTC P0756, P0757 or P0758. No TFP manual valve position switch DTC P1810. No TCC PWM solenoid valve DTC P2761. The throttle angle is 10-100 percent. Engine speed is 1,250-5,000 RPM. The TFT is Vehicle speed is TFP manual valve position switch indicates D4. The TCC is commanded ON for 0.04 second or greater. TCC is locked ON for greater than 0.1 second. Commanded The PCM detects slip in the torque converter clutch and/or the fourth gear clutch pack with the TCC in an apply or locked mode. DTC P0894 sets during the second consecutive trip when one of the following conditions occur: The TCC slip speed is 100-550 for 10 seconds for three occurrences.The TCC slip speed is 100-550 for 10 seconds, the PCM commands maximum line pressure. The TCC slip speed is 100-550 for 12.5 seconds, the PCM commands the TCC Off for 2 seconds. The TCC slip speed is 100-550 for 15 sec For California emission equipped vehicles, the PCM illuminates the malfunction indicator lamp during the second consecutive trip in which the Conditions for Setting the DTC are met. For Federal emission equipped vehicles, the MIL is not illuminated. The PCM commands maximum line pressure. The PCM inhibits the TCC engagement. The PCM freezes transmission adaptive functions. The PCM records the operating conditions when the Conditions for Setting the DTC are met. The PCM stores this information as Freeze Frame, California only, and Failure Records, California and Federal. The PCM stores the DTC P0894 in PCM history during the second consecutive trip, California, or the first trip, Federal, in which the Conditions for Setting the DTC are met. For California emissions, the PCM turns OFF the MIL during the third consecutive trip in which the diagnostic test runs and passes. A scan tool can clear the MIL/DTC. For California emissions, the PCM clears the DTC from PCM history if the vehicle completes 40 warm-up cycles without an emission related diagnostic fault occurring. For Federal emissions, the PCM clears the DTC from PCM history if the vehicle completes 40 warm-up cycles without a non-emission related diagnostic fault occurring. The PCM cancels the DTC default actions when the fault no longer exists and the ignition switch is OFF long enough in order to power down the PCM. A TFP manual valve position switch malfunction can set DTC P0894. A mechanical failure of the shift solenoids or TCC PWM solenoid valve can set DTC P0894. Internal transmission failures can result in a DTC P0894. Sticking or contaminated shift valves may cause intermittent slipping in D4. DTC P0894 defaults to an elevated line pressure condition which may result in partial TCC apply. This may produce an idle surge that could stall the engine. The numbers below refer to the step numbers on the diagnostic table. 3. This step tests the indicated range signal to the actual selected range. A faulty TFP manual valve position switch can set a DTC P0894. 4. This step tests for excessive TCC slip speed while in a commanded TCC lock-up state and in fourth gear; and confirms that the fault is present. 5. This step tests for excessive TCC slip speed while in a commanded TCC lock-up state and in third gear. 6. This step tests for a sticking TCC shift valve. 7. This step tests for proper transmission line pressure.
Apr 18, 2014 | 2005 GMC Sierra 2500HD 4WD
Having a problem with my p0742 will I need a new transmission?
How would some know that?
I assume you haven't even had it road tested yet
by a trans or repair shop
There are no new transmissions,only new when the
car is assembled
Nov 26, 2012 | 2001 Chevrolet Monte Carlo
01 Buick Century Custom with a 3.1L . I have a code po741 or p0741 it says the troque converter circuit is stuck on what can i do to fix this .
P0741 TCC STUCK OFF If the PCM detects high converter slip when the TCC is commanded on, then a DTC P0741 will set. The following conditions must exist for two times during the same ignition cycle. This code will set for all the same reasons that a P1870 will set: • The TCC duty cycle is greater than 50% • The TCC slip speed is greater than 180 RPM for 7 seconds • TCC slip in 3rd gear on 4L80-E transmissions Known causes for P0741: • Worn TCC valve bores in the valve body • Damaged or worn pump bearing seal • Defective TCC PWM or TCC apply solenoids • Restricted separator plate solenoid feed orifice • Defective converter • Computer reprogram • Channel plate sleeve & turbine shaft sealing ring damage I would suggest changing fluid and filter & reset pcm.
Sep 21, 2011 | 2001 Buick Century
Po742
Trouble Code: P0742 This should be looked at by a trusted transmission shop in your area to address this problem. This sometimes does require the replacement of the torque converter itself.
Torque Converter Clutch Circuit Stuck On (4T65-E)
Possible Causes:
TCC PWM solenoid valve for the fluid exhaust is restricted TCC regulated apply valve is stuck in the TCC apply position TCC control valve is stuck in the TCC apply position TCC feed limit valve is stuck (i.e., the TCC feed limit pressure, and the TCC release pressure to be low or nonexistent) Pressure regulator valve is stuck TCC fluid circuits leaking or abnormally low/high line pressure TCC release switch circuit is shorted to ground TSB 00-07-30-007A contains a repair procedure for this code
May 21, 2011 | 2000 Chevrolet Impala
CODE P0741
P0741 "Torque Converter Clutch Solenoid stuck off"
If the PCM detects high torque converter slip when the TCC is commanded ON, then DTC P0741 sets. The Powertrain Control Module (PCM) controls the Torque Converter Clutch Solenoid Valve (TCC Sol. Valve) Pulse Width Modulation (PWM). The solenoid controls the hydraulic fluid for TCC apply and release. When the TCC is applied, the engine is coupled directly to the transmission through the TCC. The TCC slip speed should be near 0.
Thank you for using Fixya and good luck
Aug 05, 2010 | 2004 Kia Sedona
Does not shift ,engine makes whining,rattling sound diagnostic code:0742 displays allfluid levels are topped off,oil,tranny,powersteering,radiator
it doesnt matter if the fluids are topped off?????????????? you need a tcc switch
Circuit Description
The TCC release switch is part of the automatic transmission fluid pressure (TFP) manual valve position switch. The TFP manual valve position switch is mounted to the transmission valve body.
The TCC release switch is a normally-closed switch. When the TCC is released, TCC release fluid pressure opens the TCC release switch which opens the TCC release pressure circuit. When the voltage on the circuit is high, switch open, the PCM recognizes that the TCC is no longer engaged.
If the PCM detects that the TCC release switch is closed when the TCC is commanded OFF, then DTC P0742 sets. DTC P0742 is a type B DTC.
DTC Descriptor
DTC P0742 Torque Converter Clutch (TCC) System - Stuck On
Conditions for Running the DTC
  • No TCC release switch DTC P1887.
  • No TCC PWM solenoid valve DTC P2761.
  • The engine speed is greater than 500 RPM for 5 seconds and not in fuel cut off.
  • The engine torque is 95 - 270 Nm (70 - 200 ft. lbs.) .
  • The TP indicated angle is 5-45 percent.
  • The transmission fluid temperature is between 20°C (68°F) and 130°C (266°F) .
  • The TCC is commanded OFF.
The TCC release switch is closed 6 times for 4 seconds each, during one trip.
Action Taken When the DTC Sets
  • The PCM illuminates the malfunction indicator lamp (MIL) during the second consecutive trip in which the conditions for setting the DTC are met.
  • The PCM commands maximum line pressure.
  • The PCM commands the TCC ON at maximum capacity.
  • The PCM freezes transmission adaptive functions.
  • The PCM records the operating conditions when the Conditions for Setting the DTC are met. The PCM stores this information as Freeze Frame and Failure Records.
  • The PCM stores DTC P0742 in PCM history.
Conditions for Clearing the MIL/DTC
  • The PCM turns OFF the MIL during the third consecutive trip in which the diagnostic test runs and passes.
  • A scan tool can clear the MIL/DTC.
  • The PCM clears the DTC from PCM history if the vehicle completes 40 warm-up cycles without an emission-related diagnostic fault occurring.
  • The PCM cancels the DTC default actions when the ignition switch is OFF long enough in order to power down the PCM.
Diagnostic Aids
Test Description
  1. A Yes answer indicates that the TCC release switch is functioning properly.
  1. With the 20-way connector disconnected, the PCM should interpret the open circuit as TCC release pressure present.
  2. The TCC release switch is a normally closed switch and must be disconnected to properly test for a short to ground condition. An open condition in the TCC release circuit or switch would set DTC P1887. Open circuits are not diagnosed in DTC P0742.
  1. This step tests for a mechanical or hydraulic condition that would cause the TCC to be stuck ON.
' var HIGHmap133785047 = '' // --> Step 1 - Step 7
Mar 07, 2010 | 2006 Chevrolet Uplander
Servise engine light on the code is p1860
code - po1860 tcc pwm solenoid circuit malfunction 4t80- E conditions.5 possible causes 1. tcc solenoid control circuit is open or shorted to ground. 2.tcc solenoid control circuit is shorted to system power b+. 3.tcc solenoid power circuit is open check the trans fuse. 4.tcc solenoid is damaged or has failed. 5.pcm has failed.
Dec 07, 2009 | 2001 Cadillac DeVille
Wondering what the TCC fault code is
Here are the DTC's for the TCC Solenoid:
DTC P0740 TCC Enable Solenoid Circuit Electrical
DTC P0741 TCC System Stuck Off
DTC P0742 TCC System Stuck On
DTC P0743 TCC Enable Solenoid Circuit Electrical
DTC P0744 Torque Converter Clutch Circuit Intermittent
-KC GTO Dad
Sep 17, 2009 | 2002 Pontiac Grand Prix
22 people viewed this question
k24674
