Cell Phones Logo
Posted on Aug 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to adjust brightness - Cell Phones
mohit gangwar
Level 2:
  • Expert 132 Answers
  • Posted on Aug 26, 2010
mohit  gangwar
Expert
Level 2:
Answers
132
Questions
0
Helped
20350
Points
541
Go to your display settings,there you find the option of brightness.
  • mohit gangwar Aug 26, 2010
    go to your display settings menu..there you can find the brightness options
2answers
Hino clock screen light adjustment?
Somewhere on the lower part of the dash, you will find a small thumbwheel that increases the brightness.
It might be shown in here. 'Year make model' are important.
How do I adjust the brightness on my Samsung Tab 4?
Tap Settings>Display>General>Brightness, adjust to desired brightness, left or right. Alternatively, from your home page, drag your finger from the top edge of the table screen downward to expose several power button shortcuts (Wifi, GPS, Mute, etc), including the brightness scale, adjust the brightness left or right and/or select the auto[brightness] checkbox.
1helpful
2answers
Screen brightness
Changing the Screen Brightness
1. Press the Home Key > Menu Key > System
settings > Display > Brightness.
2. Check the Automatic brightness box to make the
phone adjust the screen brightness automatically
or clear the check box to adjust the brightness
manually.
3. Tap OK
1helpful
How to adjust contrast on dell 610
From this web site:
http://www.computerhope.com/issues/ch000594.htm
How do I adjust my brightness or contrast on my laptop? Every laptop is different, so adjusting the brightness or contrast on your laptop may vary from the steps provided on this page. However, understanding the process of how to adjust the brightness or contrast will help you change your settings.
Most laptops adjust their brightness and other settings using the function key in conjunction with another key. For example, pressing and holding the function key (abbreviated as "Fn") and pressing the up or down arrow keys as shown in the picture below, increases and decreases the brightness.
Other examples also shown in the above picture include pressing Fn and F1 and F2 or F7 and F8 to increase and decrease the brightness. If none of the above examples resemble your keyboard look for keys on the keyboard that have pictures of a sun or a half moon to identify the correct key to adjust the brightness.
How can I adjust the laptop contrast? Laptops only allow users to adjust the brightness of their screen. Contrast settings are not adjustable on a laptop display.
How do I save the new adjusted settings? After adjusting your laptops brightness it will retain the new settings.
Laptop brightness is still not enough or screen is black If after following the above steps your brightness is still not enough, plug your laptop into the wall to make sure it is not a power setting that is decreasing the brightness. If the laptop is plugged in but still is not bright enough, try the suggestions on the below link.
Adjust brightness ipad
that is a basic thing to know:
  • Open Settings and tap on "Brightness & Wallpaper"
  • Adjust the brightness slider as desired
  • Flip "Auto-Brightness" to OFF to have the screen stop automatically adjusting brightness
adjust-brightness-ipad-fsa0em3gpfye3khtm1m3hcbs-4-0.jpg adjust-brightness-ipad-fsa0em3gpfye3khtm1m3hcbs-4-2.jpg Change Screen Brightness Stop the Display Auto Adjusting on iPhone
How to adjust screen the brightness on HP TouchSmart 520-1100
To adjust the brightness you press the Fn key on keyboard and simultaneously press F10 to reduce brightness. Press Fn simultaneously with F11 to increase brightness.
Ibm thinkpad 600x brightness control
There is no otherway. becase the slides sends direct signal to inverter for adjusting brightness. You can adjust brightness the
other way ,through graphic cards property, but that is only adjustment for the color and if you do make it bright, you'll be loosing the vivid color..not so natural.
takecare.
1helpful
LCD brightness question
You can adjust the brightness or color of the LCD display as needed. 1. Set the POWER switch to CAMERA position. (In the PLAYER mode, you may only setup the LCD while the tape is playing.) 2. Open the LCD screen, and the LCD switches on. 3. Press the MENU button. 4. Turn the MENU DIAL so that VIEWER is highlighted and then press the ENTER button. 5. Turn the MENU DIAL so that LCD ADJUST is highlighted. 6. Press the ENTER button to enter the sub-menu. 7. Turn the MENU DIAL so that it highlights the menu item you want to adjust (BRIGHT SELECT, BRIGHT ADJUST, COLOR ADJUST). 8. Press the ENTER button again. You may select NORMAL or SUPER in the BRIGHT SELECT feature and press the ENTER button to save the setting. Use the MENU DIAL to adjust the value of BRIGHT ADJUST and COLOR ADJUST. You can set values for BRIGHT ADJUST between 00 ~ 35 and COLOR ADJUST between 00 ~ 35. 9. Press the MENU button to finish the setting.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
 Mikey
Mikey
Are you a Cell Phone Expert? Answer questions, earn points and help others
