Question about Kenmore Sewing Machines
The bobin thread is not tight. I have a1584180. how do i fix it?
  • sqs1011 Aug 26, 2010
    Do you mean it's not wound tight or it's not tight when you sew? Thanks.
    Genius:
  • 1,788 Answers
Is bobbin wound evenly? Also, check that your needle is not bent, put a new needle in just to check it anyway (make sure the flat side faces away from you and inserted all of the way), then rethread your machine completely. Usually the problem lies in your top threading for threads bunching underneath,
Posted on Aug 27, 2010
Bobin thread loose
There is a comprehensive 5 page illustrated tutorial I have written to address this specific issue: HERE
Oct 20, 2011 | Sewing Machines
Sewing with heavy thread, what should the tension be set on?
hi there
the tension depends on thikness of material but you must use heavy thread on needle and thin thread on bobin case .
- you must be sew fiew stitches firist and look if losse stitch from down you must tight tension slowly sloly and if there is losse stitches from upper you must tight screw for bobin case spring slowly slowly until stitch format be agood condation.
best regards
ashraf abozid
aabozid@hotmail.com
Jan 06, 2011 | Juki DDL-8700
How to stop bobin thread from knotting
When loading the bobbin there is most likely not enough tension on the thread letting it overlap incorrectly. Try wrapping thread around a tensioner when filling and that should help. That way the bobbin is rolled as tight as the tension on the upper thread when sewing.
Apr 13, 2010 | Brother LS-2125 Mechanical Sewing Machine
The bobbine thread is not catching and I'm trying to fix it and I am not sure were to start.
start by removing the bobbin, and reinstalling, make sure the thread runs through the bobin tension plate, the little plate that puts pressure on bobbin thread to keep it tight, also look at thread and needle, if thread insn't thread through the needle, it won't catch, feelfree to call me if you need better help, devin 239-895-4845, Quality Auto Trim Inc 239-849-0015
Mar 12, 2010 | Sewing Machines
Brother sewing machine vx1120 Ithink won't pick up bobbin thread
have you tried other thread and a different bobbin?  The tension screw on the bobin case could be too tight.
Mar 11, 2009 | Brother LS-1217 Mechanical Sewing Machine
Lower thread tension is too loose but no adjustment seems to work
From your description it appears that you have tried tension settings on the upper tension control adjustment knob without success.
Check that the bobin tension is adjusted correctly by taking out the bobin complete with the spool.
Pull the cotton thread and it should be a smooth light pressure if the tension is correct. If it is tight to pull or pulls freely then adjust the tension screw which is found on the outside of the bobbin. The screw is very small and requires a minature size screwdriver. The adjustment will only be a slight turn of the screw one way or the other to obtain the correct tension(depending if it was loose or tight).
Once this is set reinstall the bobin and tread up the machine, hopefully with the upper tension set at approx."2" the machine will sew correctly.
Nov 28, 2008 | Brother LS-2125 Mechanical Sewing Machine
Thread bunches from the bottom while sewing.
Hello, sewing is a part of my income and I've encountered this problem before and managed to fix it on my own, by trying out these different things. I re-threaded the machine and checked to make sure that the tension is not too loose. Check the bobin and the sack the bobin fits into, sometimes it comes loose too, click it back into place and re-do the bobin. adjust the tightness of the stiitches, I usually put it on 2 .5 - 3. Hope this helps. Good luck to all. Nefishakh@hotmail.com
Nov 16, 2008 | Singer 5050 Mechanical Sewing Machine
Brother Industrial Machine Tension
This is an answer to another person with a similar complaint. Try the suggestion below, it may fix the problem.
Nov 14, 2008 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
27 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
