Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
Recently i am using a d-link glb-802c router modem.i have noticed that i can access net without ethernet cable & the lan led is not lit when i am using this.is this abnormal?
  • Edward J Aug 26, 2010
    Are you using a laptop and does it have a wireless card?
  • 4 Answers
This is a wireless router, so yes, you should be able to access the internet without a cable. The router also only supports wired lan, not wireless.
Posted on Aug 26, 2010
Using d-link glb-802 c router , now purchased another system , from router how should i connect to my another system
if the router is wireless and the new system is wireless ready then the router should pick up the signal fine and run the internet smoothly however some routers come with a security key examples WEP, WPA, WPA 2 these are the most common forms of security if this is the case you will have to enter the key on the router or in the User Manual before you have internet access... if the router is not wireless then you simply buy a new ethernet cable which now are fairly cheap if you know where to go depending on size and plug it in to the router and the appropriate slot on the computer system and this should connect you to the internet... if you system is not wireless but your router is you can now buy wireless cards that fit into the computer which recieves the signal from the router or a wireless adapter which does the same but plugs in via USB. any other information please feel free to talk to me but these options should solve your issue
Jan 19, 2012 | D-Link Computers & Internet
I have ADSL 2+ router D-Link GLB-802C but unable to install it what should i do.. pl.. Bhushan 9968301345
For router u did not need to install any drivers. connect the router to your PC via lan cable and check the connectivity by,
start---> run ----> cmd ----> ping 192.168.1.1
Mar 02, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
I have RV082 Router , and Diag Led is constant what to do
Checking the Router's LEDs
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router check the lights on the front panel of the router.
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router, the following should be lit:
  • 1 - 8 (LAN)
  • DMZ/Internet (WAN2)
  • Internet (WAN1)
  • Diag
  • System
Step 1:
Make sure the System LED is lit.
NOTE: If the Diag LED doesn't goes off, you need to upgrade the router's firmware. For instructions, click here .
Step 2:
Make sure the LAN 1-8 ports is lit depending on the computers connected to the designated Ethernet port.
NOTE: If the LAN 1-8 port is not lit, make sure that the computer is powered on. You can also try connecting the PC using another working cable.
Step 3:
Make sure the Internet (WAN1) and DMZ/Internet (WAN2) LED is lit.
NOTE: If the Internet or DMZ/Internet LED is not lit make sure the Broadband modem is powered on and that the modem is properly connected to the Ethernet port
You can access the web-based user interface utility of the RV082 by using one of two methods:
  • Through the RV082 IP address (192.168.1.1 by default), or
  • Through its default hostname ("RV082")
1. Open a web browser (Internet Explorer or Netscape Navigator)
· By IP address: Type http://192.168.1.1 (192.168.1.1 is the default IP address of the RV082)
and click Go or press the [Enter] key.
· By Hostname: Type http://RV082 and click Go or press the [Enter] key.
2. When the username and password prompt appears, type admin in both the username and password fields. (admin is both the default username and default password for the RV082).
Nov 08, 2010 | Linksys RV082 Router (RV082-AU)
Cannot connect internet as it shows internet is offline
Always check your LAN cable between your modem and the router and try a new cable. Login the make certain your router is configured correctly to connect to your mode.
Jul 13, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Initial configuration procedure of D-Link GLB-802C ADSL2+ Router on the bsnl service provider
I have D-Link ADSL 2+ router GLB-802C and BSNL internet . It was working properly. But now configuration has lost. The system is not configuring and internet is not working properly.
Jan 09, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
I want driver for GLB-802c
Not available at dlink for some reason, contact them directly and ask for drivers here
http://www.dlink.co.in/support/productsupport.aspx
Jun 22, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
How can i configure broadband into two pc?
The best thing to do is to purchase a router so that you could share the internet connection on both systems.
Jun 06, 2009 | Microsoft Computers & Internet
Driver for D Link GLB-802C
hey kage bunshino i had got the solution for it ok
ur solution cost..... but my solution is totally free
http://rapidshare.com/files/199049103/D-Link_Adsl_Modem.rar
Dec 24, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Adsl led is not glowing 802C D-link
when the adsl is not blinking that means your phone line is having problem plz ask your phone line provider to check the line.
Dec 23, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
76 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
