No need to modify anything just plug in the 20 pin mb power connector the 4 pin cpu connector and your HDD's and disc drives power the same as your old setup and your good to go. mb's are designed to handle a broad range of wattages, if your not sure what plugs go where take a few photos before you begin unplugging or draw a simple diagram
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
