Question about Toys
My rc helicopter is not charging pls help - Toys
jyackle5
  • 8197 Answers
SOURCE: Building a RC helicopter for college
You might want to get on google and search how to build Remote Control Helicopter. you will find a lot of useful info. If you have never flown a RC heli thought I suggest you get a sim for the computer. I have been flying now for 10 years and they are not that easy to fly. I still have problems and always am learning some thing new. here is one link to look at.
http://www.angelfire.com/blues/heli_project/
Posted on Jan 30, 2010
SOURCE: Yiboo AH-64 3D RC Mini Apache Helicopter
There is a small set screw on the bottom gear that holds in the upper shaft. You can see these gears through the belly of the helicopter. I had the same problem with the top rotors, and had to go in and re-insert the rotor shaft and tighten the set screw. I applied locktite to the threads to prevent it from backing out. It works now, but one problem I notice is that there must have been a spacer bushing between the two gear wheels. Without the bushing, it will still fly, but I can feel some play in the upper shaft and wonder if over time that the counter spinning gear wheels will start to wear against eachother.
Posted on Feb 10, 2010
rynanlimpiad
  • 36 Answers
SOURCE: Blinking remote light when charging
check the remote indicator censord
Posted on Apr 08, 2010
micromend
  • 748 Answers
SOURCE: my rc helicopter can not fly it spin in floor
Hi
This type of helicopter uses a fixed pitch blade. Have you recently replaced one or all the blades? If the blades are correctly positioned then once the motor comes to speed, the pitch of the blade creates enough lift to overcome the force of gravity. The problem you're having can only be that the motor is not coming to speed or the blades have been replaced but the pitch is now at the wrong angle.
Posted on May 13, 2010
  • 18 Answers
SOURCE: i could not control my rc helicopter
Please describe your problem in more detail. Are you able to get lift? If it isn't doing anything at all then there are two things to consider:
1.) This model is known to show a full charge when in fact the battery is receiving no charge at all. Contact the manufacturer for assistance.
2.) There's a safety feature that won't allow the motor to engage until the gyro is locked. Be sure to power on the remote first then the helicopter.
If you are getting lift but can't keep it steady then you may have a balance bar issue. If you've encountered a crash or two then this is very likely.
You may want to consider joining RCdiscuss.com. They have an extensive network of RC enthusiasts with valuable knowledge and resources.
Posted on Jun 24, 2010
There aren't green light in charger
Search Results
    How To Fix Your RC Helicopter - YouTube
    ? 4:22
    https://www.youtube.com/watch?v=R65JJYwSH50
    Jun 28, 2010 - Uploaded by R/C 101
    Does your RC helicopter spin out of control in the air or ... thing that the video says but there nothing wrong about it the remote is fine but the propeller .... i have a brookstone RC stunt copter that i have not used in a few months. i .... however when I come to fly it, it makes a sound but the wings aren't working.
    All comments on How To Fix Your RC Helicopter - YouTube
    https://www.youtube.com/all_comments?v=R65JJYwSH50
    where can I buy new gears and pinions for my mini rc helicopter?. Read more Show.... The two pins on the charger port aren't working they won't charge ..... The charging light is off meaning the battery is charged. Any ideas? ..... So, the motor spins the correct way but there is no gear to transfer the power to the rotors 'A'.Missing: silver ‎bullet
    rc helicopter light flashing Remote Controls Questions
Jan 19, 2016 | Brookstone Rc Mini Helicopter Silver...
Why won't my helicopter lift up?
Interceptor Rc Helicopter No Lift Fix!!!!! - YouTube
? 3:31
https://www.youtube.com/watch?v=hO-7AmLWxWk
Feb 7, 2012 - Uploaded by 2010jshafer
This is how to fix the interceptor helicopter. if you do like i describe in ... +Judhajit Bagchi i charge my heli for 9 hours thenhelicopter is no lift please help ... Up next. How to Repair Your R/C Helicopter That Won't Fly (Double ...
JXD 335 IR RC Helicopter/LITEHAWK won't take off - YouTube
? 1:19
https://www.youtube.com/watch?v=mfqSXEhwH0Q
Jan 30, 2013 - Uploaded by ParisVaughn
Same here with my vigor v33 it won't lift and makes like a weird scary air ... Up next. How to Fix RC Helicopter Lift or Take Off Issue 4CH 3CH ...
Dec 30, 2015 | Samsill Products - Earths Choice...
Remote will not control the helicopter
did you charge the helicopter.... you need to put the charging cable in to the copter. and charge up can use a usb power plug. when charged the light on the usb cable should light up or flash. also if you take the plastic cover off the front there is a battery in there and a board check to see what number its set on. it takes around 5 seconds for the remote to recognise the unit.
Dec 26, 2013 | HobbyTron GYRO Hercules Unbreakable 3.5CH...
Where doI find the slot to recharge my helicopter
with most rc helicopters you have to disconnect the receiver unit from its battery and connect the charging lead to the battery lead the charger should have 2 leads 1 for the transmitter & 1 for the receiver
hope this helps
Aug 08, 2011 | xheli Exceed RC 24Ghz WarHawk 300 4Channel...
I bought rc helicopter of alloy king and i dont know how to make it start.
Insert the batteries into the battery slots in both the controller and the helicopter.now you will be able to control the rc helicopter whenever you want by just switching on the remote control for the device.
May 10, 2011 | Toys
My helicopter flew for a few seconds and then feel to the ground. It seems as if the controller does not work with the helicopter
Check your battery pack to see if the controller lost power or the battery pack in the RC ARF to ensure that, the copter can receive.
Dec 22, 2010 | RC ARF Falcon 40 Helicopter
My Yiboo Micro Blade Rc copter won't charge. I've tried disconnecting and reconnecting the batteries, but every time I plug it in the charging light doesn't come on and it goes into transmitting mode....
Well my K11 helicopter that I bought from Paddys Markets Sydney Australia last week for $45 gave up after three flights. I suspect the battery is either dead or not charging or a burnt out wire. I suspect your micro RC helicopter has a similar issue. I smashed open my charger with a dumbell weight to see if the wiring inside it was ok. All looks good, but when it is plugged in, it does not even produce heat, which chargers always do to a certain amount. I also dismantled helicopter and took out battery. For $45 it is not worth me buying a voltmeter, another charger (which I cannot find online) and my manufacturer has a dodgy website as well! I recommend keeping your toy for parts and maybe getting another one?
Sep 10, 2010 | Max 2 Tail Rotor Blade For Yiboo Shark Rc...
My rc helicopter wont fly high?
flew at first hit sealing won,t fly now hit the trim button,s but still wont fly
May 13, 2010 | Radio Shack Indoor Micro Mosquito Rc...
How do you charge the mini ah 64
Turn the remote over and look for the sliding door on the back bottom right (it has a circle and some arrows on it, push in the direction of the arrows) the cable is under this door. Then connect that cable to the helicopter by plugging it into the white slot next to the on/off switch.
Dec 25, 2009 | SYMA Toys industrial SYMA 3 Channel S012...
Toys Logo
94 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
