How do you delete the 9 last number that u dialed
Have switched phones and taken SIM card out - how do you delete all contacts, etc. from the phone.
Posted on May 21, 2008
How do I store a number for autodial at a later date?
Autodial? You're going to use one of the 8 buttons for autodial or are you trying to put system speed dialing in? The phone buttons are easy if you dial "9" to get an outside line. You press PROGRAM a button, and dial 29 plus your number and STORE.
Now, obscurely, you can program one of the 8 buttons to SAVE a number. Thats done by PROGRAM the button 5 STORE. When you dial a number that you want to save, you press Autodial and SAVE (the button you programmed) and it will save that number under the button.
Now, grab a line and press the SAVE button and it will dial your saved number.
Last, if you're not totally bored, you can store 10 Personal speed dial numbers on your phone. They program by 2* (0-9) number # and are dialed by pressing # (0-9).
Yeah. BTW this is an instruction set for a TA-624, common for the type of phone you have. I think it applies to most of the TA series KSU's.
Carl
Mar 25, 2011 | Panasonic KX-T7560 1-Line Corded Phone
How do I program a phone number to the one touch buttons on a Panasonic KX-T7730 phone?
It depends on what you get when you dial "9" on the intercom. If you get an outside line, then the 12 right side buttons on your phone can be programmed for one touch dialing like this:
On an idle phone, press PROGRAM a button and dial 9 plus the number and STORE. You can program more than one button by just pressing button numbers and STORE. Exit programming by picking up the handset and dropping it back down.
If you want a specific line, you may be able to dial the specific 8x code to access a line directly, or you can go into system programming and delete the open lines in program 400. Disabling would be the best, because if your 8x line is busy, you can't make the call with the auto dial button.
Carl
Mar 08, 2011 | Panasonic KX-T7730 Corded Phone
When dialing a 4 digit extension from the call log, a 9 is placed in front of the extension and it won't work because we don't need the 9 to dial internal extensions but do need it for dialing numbers...
That can be done in your pbx go to outbound routes and select the specific trunk there you can see in "dial patterns" 9|xxxx some thing like this there you can delete the 9 i hope it solves the problem
Mar 12, 2010 | Avaya 4610SW IP Phone
I need to know how to program the numbers into the speed dial option. My mother's phone is a table set with large numbers #29267A ... close enough?
Before you store a telephone number in memory, make sure the dialing mode is
correctly set for the type of service you have. The default dialing mode is tone
(touch-tone), so if you have pulse (rotary) service, you must first change the dialing
mode. See “To Set the Dial Mode.” The following buttons can be stored into any
memory location: 0-9.
STORING FREQUENTLY CALLED NUMBERS
1. Pick up the handset.
2.Press the store button.
3. Push the desired memory location button.
4. Press the store button.
5.Use the handset number keys to enter the telephone number (up to 16-digits)
and press the store button.
6.Hang up the handset.
NOTE: If you make a mistake, use the delete button to delete wrong digits.
CHANGING A STORED NUMBER
Repeat the storage sequence above. The new number replaces the old number at
the memory location.
ERASING A STORED NUMBER
3.Press the memory location (0-9) to be erased.
4.Press delete for three seconds until the number in the display is erased.
5.Hang up the handset.
DIALING FREQUENTLY CALLED NUMBERS
1. Pick up the handset and press the mem button.
2. Press 0-9 for the memory location. The number dials automatically.
OR
1. Pick up the handset and press the dial button.
2. Press the review button for the desired memory location.
3. Press the dial button to dial the number.
OR
1. Press dial button while the handset is still in the cradle.
2. Press the review button for the desired memory location, lift the handset and the
Download User Manual
If this information was helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 02, 2010 | GE 29267GE3 Corded Phone
Re-programm speed dial keys
Sorry delete it/them and reprogram. Carl
Jun 10, 2009 | Ricoh FAX2900L Plain Paper Laser
Panasonic KX-T7730- assigning speed dialing/one touch. I tried to press prog button and the one touch button..but it gives me an error message "not stored". How to solve this? I have 12 buttons to assign...
It says "Not Stored" because you haven't stored anything in it. There are 12 buttons on the left side with lights and 12 buttons for feature dialing on the right. If you want to monitor extensions, the buttons on the left are the ones to use. If you want to store speed dial numbers and feature codes use the ones on the right.
Left button programming. Press PROGRAM and the button. For extensions, dial 1+ext and STORE. For CO's, press 0+line number, for inside codes press 2+code, for outside number press 2+9+number, all followed by STORE.
Right button programming. For inside codes dial the code, for outside number press 9+number followed by STORE.
Note that you could also dial "8x" or "80x" in place of "9" for specific line access. Also, you can store extension speed dial numbers on the right, you just won't get a light indication when they're busy.
Carl
Jun 04, 2009 | Panasonic KX-T7730 Corded Phone
Enter memory data
Here are the commands to run the phones memory dial (speed-dial).  I have included the instructions for deleting and changing numbers as well.  It is listed below.  I hope this helps you out.
Ken
MEMORY DIAL INSTRUCTIONS Store up to ten 20-digit numbers in memory for quick dialing. Storing a Number in Memory 1. Make sure the phone is OFF (not in TALK mode). 2. Press the MEMORY button. 3. Press a number (0-9) to store the dialed number in that memory location. 4. Press the MEMORY button again. 5. Use the handset number keypad to enter the telephone number (up to 20 digits, including pauses) and press the MEMORY button again to save the number. The unit beeps to confirm. 6. To enter another number in a different memory location, return to step 1 and repeat the process.
Storing a Redial Number 1. Repeat steps 1 through 4 in Storing a Number in Memory. 2. Press the REDIAL button. 3. Press the MEMORY button to store the number. You will hear a confirmation tone.
Changing a Stored Number 1. Repeat steps 1 through 6 in Storing a Number in Memory. 2. Press the MEMORY button to store the number. You will hear a confirmation tone. The old number will be overwritten with the new number.
Dialing a Stored Number 1. Make sure the phone is ON by pressing the TALK button. 2. Press the MEMORY button. 3. Press the number (0-9) for the desired memory location. The number dials automatically. Inserting a Pause in the Dialing Sequence Press the PAUSE# button once to insert a delay in the dialing sequence of a stored telephone number. A pause is needed to wait for a dial tone (for example after you dial 9 for an outside line, or to wait for a computer access tone). Each pause counts as 1 digit in the dialing sequence. If you need a longer pause, press the PAUSE# button twice.
Deleting Stored Numbers 1. Press the MEMORY button. 2. Press the desired memory location (0-9). 3. Press the MEMORY button twice to delete the entry. 4. You will hear a confirmation tone.
Jan 08, 2009 | GE 27928GE5 Cordless Phone
Missed calls
How do I view the numbers of calls made or received? space.gif space.gif answer.gif You can view the last ten calls that have been placed and the last ten calls which have been received in the Recent Calls option menu.
  • Press the Menu, Recent Calls and press the right soft key to select.
  • To view the calls you have received scroll to Received Calls and press the right soft key to select.
  • To view the calls which have been placed, scroll to Dialed Calls and press the right soft key to select.
  • Once in the Received or Dialed calls you can get more information such as the time the phone call was received/dialed by highlighting the call you want to view, and press the right soft key to view.
  • Scroll down to view all the available information.
In order to delete a received, or dialed call simply highlight the call you want to delete, press Menu and then select Delete. You can delete all the calls in the chosen section by selecting Delete All instead of just delete.
Mar 13, 2008 | Motorola Mobility RAZR V3
Saving numbers
If you incorrectly stored an entry in speed dial, just do the steps to store a number. The previous number will be overwritten.
"With the handset on the cradle, dial the number to be stored. Next press set, then the location you want the number stored at. 0-9"
Hope this helps-wicc-
Feb 29, 2008 | Innovage 1604007 Corded Phone
One touch dial or speed dialling.
Hi Menu => Contacts =>Speed dials. Good luck.
Aug 28, 2007 | Nokia 1100
Computers & Internet Logo
491 people viewed this question
David Payne
David Payne
