Question about Samsung Digimax S800 Digital Camera
When we turn the camera on we get 3 quick beeps and the camera does not turn on. We have replaced the batteries with new batteries.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 26, 2010
Digimax s500 cutting off
BAtteries draws down too quick...
Use 2500 mAh or better for longer life the higher the number...
eveready bunny is sometimes not in all their work
Jul 27, 2009 | Samsung Digimax S500 Digital Camera
Samsung L100 Digital Camera Problem
right as the lens comes out very quickly remove the battery before the lens slides back inand beeps three times, wait a second put the battery back in and switch on obviously let the lens go back in and hay presto itshould work, it worked a treat for my L100, i hope this helps some of you but its obvious to us all our camera's are ****.
Oct 27, 2008 | Samsung L100 Digital Camera
Cameras - No respond?
Try replacing the batteries.That's what my camera did when it just needed a battery replacement.
Jun 05, 2008 | Samsung Digimax S730 Digital Camera
Camera beeps 3 times the shuts off
I've decided to send the camera in for possible repair.
Feb 17, 2008 | Samsung S630 Digital Camera
Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
Beep - Beep - Beep - but No Picture
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries.
Sep 15, 2005 | Toshiba PDR-M60 Digital Camera
Sep 15, 2005 | Toshiba PDR-M61 Digital Camera
Sep 15, 2005 | Toshiba PDR-M65 Digital Camera
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries. Please refer to the section pertaining to Battery Life.
Sep 11, 2005 | Toshiba PDR-M25 Digital Camera
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Samsung Digimax S800 Digital Camera Logo
16 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
