Question about Ovens
Manual for proline fan oven model ef6200b/2 - Ovens
2 Suggested Answers
bozcro
  • 867 Answers
SOURCE: my proline electric single oven is not heating up
most likely the heating element needs replacing, about 25 $ part.
Posted on Aug 31, 2009
In all models, is the top oven a fan oven?
look in the oven and if you see a fan then it is a fan oven
Nov 21, 2015 | Ovens
Need a manual for a neff fan assisted oven
Hi, Same can be found on neff website, Please find the same.
http://www.neff.co.uk/getting-started-with-your-neff-oven.html
Aug 25, 2014 | Neff Ovens
I have a cooker model venezia FE 8622EX and i dont have a manual for it and cant work out with knob does what as the writing is rubbed off through use...please help!
The 3 knobs each have 6 positions corresponding to clock-face positions 2,4,5,7,8,10 o'clock.
Left - Grill Temperature 1-6. (Note Oven Temp needs to also be turned on before grill will work.)
Centre - Function
1 - Lamp
2 - Defrost (fan only)
3 - Fan Assisted Oven
4 - Grill
5 - Grill with Fan
6 - Fan & Bottom Element
Right - Oven Temp 50,100,150,200,250,Max (celsius)
Sep 12, 2011 | Ovens
My proline electric single oven is not heating up
Aug 31, 2009 | Ovens
Hi, ive just been given a smeg fan oven, but there are no instructions i dont know how to opperate the oven or anything else on it, the oven is stainles steal and has 4 control knobs, 2 on the left and 2...
http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN
Try this web site. If this is not your oven, reenter the correct model number in the box on the left and it should provide the correct manuals. It will also ask you to specify the language you want the manual in.
Hope this helps.
If you find the model number and have trouble with this site, let me know and I'll give you a hand.
Jun 15, 2009 | Smeg SE210X/1 Stainless Steel Electric...
Omega europa 40-1 oven settings?
I had the same problem when I moved into my current apartment (mine's the 20-1 model). I was at a loss as to what all those symbols meant, so emailed info@hagemeyer.com.au and they sent me a pdf copy of the manual. It's not exactly the same model as you have, but I assume the symbols are the same. I'm happy to email you my manual if you'd like. Otherwise, the controls (for the 20-1 at least) are as follows:
Fan symbol - defrost (fan only - does not use thermostat)
Fan symbol within a circle - fan forced oven
3 little triangles - static grill (keep oven door open)
3 triangles above the fan symbol - fan grill (keep door closed)
I hope that all makes sense.
Apr 12, 2009 | Ovens
Chef Coronet Integra oven - no manual
Problem not solved, so I will just have to bumble on! Cannot afford the premium plan, but thanks - I have you on my list should something else happen! Thanks Gabrielle.
Mar 20, 2009 | Ovens
No manual
The light bulb is the oven light.
The snowflake with 3 raindrops is Defrost Mode (fan runs with no heat to reduce defrost time)
The 2 lines up top & down bottom is Traditional Cooking (heat from top & bottom elements)
The big circle with a fan is the Fan forced Oven
The small line at top only is the Grill Mode
The larger line at top only is the Double Grill Mode
The line up top with the fan underneath is Double Grill with Fan mode
The line on the bottom with fan on top uses the lower element with the fan for delicate dishes
The manual can be found on the Baumatic website - www.baumatic.com.au - select your product which takes you into another page & you will see on the left hand side a link to "View User Manual"
Nov 11, 2008 | Baumatic B187 Stainless Steel Electric...
VDSC307-4bss how to operate self-cleaning oven
I continued a search and found a manual on line... simple process to turn on self-cleaning operation... close the door and set to "clean" ... timer on this model is automatic... runs for 3 1/2 hours.. fan continues for an additional 30 minutes ... open the door and the oven is clean. Thanks
Mar 28, 2008 | Viking VCSO244 Dual Oven
Ovens Logo
74 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
