Whirlpool Front loader AWM5100. machine will not fill or spin. it does drain and door can open while it drains
    Genius:
  • 1,073 Answers
Replace the door lock switch
Posted on May 06, 2008
Door won't open on front load washer
How to Unlock a Whirlpool Duet Washing Machine ' Home ...
homeguides.sfgate.com > Mortgages > Mortgage Options
If you must manually unlock the washer door after each wash cycle your drain ... to Change a Water Inlet Valve for a Whirlpool Duet Front-Loading Washing Machine ...Causes and Repair for a Whirlpool Washing Machine That Won't Spin or ...
How to open a washing machine door that won't ... - YouTube
? 3:57
https://www.youtube.com/watch?v=-65_eoT6zuk
Aug 22, 2013 - Uploaded by how-2-repair.com
Your washing machine door won't open this video will show you a technique ..... Front Load Washer Repair - Not Draining or Spinning - How to Unclog ... Washing Machine Repair - Replacing the Door Bellow (Whirlpool Part
Nov 05, 2015 | Whirlpool WFW70HEBW Duet 4.1 Cu. Ft. Front...
My whirlpool front loader wont final spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. Or
http://www.youtube.com/watch?v=TB_W6sPdzkM
Pl click if helped
Apr 05, 2013 | Whirlpool Washing Machines
Due to power outage can't get door open on Whirlpool Duet front loader washer. With wet towels inside, need to manually open door to get them out. Is there an easy solution?
On that type of washer the door lock is wired in series with the water level switch and if water remains in tub the door lock will not power up and unlock..what you can try is (if havent already done so) is select the drain/spin only cycle and when the water has drained the door should unlock
Aug 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool front loader washer is not spinning
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Dec 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The washing machine, AWM5100, is set to start. It does the drain but doesn't fill with water. The door is not locking.
UNTILL THE DOOR LOCKS, YOUR MACHINE WILL NOT FILL AS THIS IS A SAFTEY MESURE , CHECK SPRING IN DOOR LATCH .
Oct 19, 2009 | Washing Machines
Front load washer won't spin
not so much hte switch , but perhaps the hose that attaches teh tub to the switch, usually it rubs a gainstrear of machine and gets a hole in it, look to the hose first
Mar 28, 2009 | Whirlpool GHW9100L Front Load Washer
I have a duet f/l loader. The washer fills with water when not on
I FOUND THE PROBLEM WAS THE VALVEWHICH CONTROLS THE WATER INTAKE ON THE TOP OF THE WASHER. I PICKED UP THE REPLACE VALVE IT WAS LOCATED AT THE TOP OF THE WASHER WHERE THE WATER INTAKES ARE. THIS SOLVED MY PROBLEM.
yOUR SITE WAS VERY HELPFULL
THANKS ****
Nov 26, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Whirlpool AWM5100 Tests Fine Without Clothes but Stops With Them
Rkwolfers, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Rkwolfers), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 24, 2017 | Whirlpool AWM6100 Front Load Washer
I have just replaced the inlet valves for my Whirlpool AWM5100 front load washer and it is still not filling up with enough water to do a load of washing. I have checked all the hoses for blockages and...
Your pressure switch controls the water level.
Is this machine new to you? or ?
Front loader use less water. the water level will be close to the bottom of the door.
Let me know if you have any more questions.,
May 24, 2008 | Whirlpool Washing Machines
Washing Machines Logo
555 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
