Seagate 250GB USB external harddrive was working now it is not. Cannot see it in Disk Management. In Device Manager, USB controllers the harddrive shows up as Unknown Device when I plug it in. In Properties it shows No drivers are installed for this device in Device Status. Any suggestions?
    Sergeant:
  • 291 Answers
Unplug seagae usb external h/d
Device manager>Under usb= ,uninstall the device.
run: RESTORE, choose the last check point, reboot,then plug in the h/d in your usb.
Posted on May 06, 2008
My Lenovo laptop won't recognize my seagate desktop 1TB external hard drive. Got any ideas?
Can you see it under "Device Manager" or "Disk Management"?
To get to device manager and disk management click "Start"-> Type in "management" in the little white bar at the bottom and click "Computer Management".
Aug 07, 2013 | Seagate FreeAgent 2TB GoFlex Desktop USB...
Seagate st90000u2 160gb no longer recognized by home laptops
w7
First, please disconnect all USB devices and then perform the following steps:
Click "Start" button, type "devmgmt.msc" (without quotation marks) in the "Search" bar and press "Enter". Click "Continue" if necessary.
In Device Manager, double click to expand "Universal Serial Bus controllers", right click on the Host Controller, click "Uninstall" and click "OK".
Repeat the step 2 to uninstall all items under "Universal Serial Bus controllers".
Then, restart your computer and Windows 7 will reinstall all USB controllers automatically.
for xp
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.cleverfiles.com/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
hope this helps
Aug 10, 2012 | Computers & Internet
My Seagate harddrive experienced a code 10 error, how do i fix it
code 10 error no driver
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Mar 07, 2012 | Seagate FreeAgent 2TB GoFlex Desktop USB...
Driver not shown on my computer/wd my passport 250gb
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working sroll to Ports(Com&Ltd) right click to update driver if you computer came with a motherboard disk the drivers could be on it
hope this helps you
Jul 13, 2011 | Western Digital 250GB MyBook External USB...
Verbatim clon harddrive 250 gb wont show up
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
if your computer came with a motherboard disk the drivers could be on it
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems"
hope this helps
Jul 12, 2011 | Verbatim CLON Portable, 250GB, USB,...
My toshiba 250gb external hard drive doesnt show in my computer (xp) but it is in device manager?
Click Start
Right-mouse click My Computer
Click Manage
Expand the Storage branch
Click Disk Management
Click Disk Management (local)
Click to create a partition on the drive, and to assign a drive-letter.
Oct 27, 2010 | Toshiba 250GB TOSHIBA USB 2.0 PORTABLE...
External 500gb hard drive not readable
Check the partition size in Disk Management (if running Win7 - download a free Partition Manager if not) and see if the system is seeing the partition correctly. Seagate has recovery software available on their website but you may just have to repartition and reformat.
Apr 25, 2010 | Seagate 320GB Portable External Drive ...
I cannot see my free agent external drive
u can see the news that the st drive has many bugs,and which cannot be detected by the pc is the most popular one,so u can update the firmware from seagate official and if still cannot repair,u can go back to me,honglake@gmail.com
Mar 15, 2009 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
I reformatted my C: drive and ever since Windows will not recognize my Seagate External Free Agent hard drive. It shows up under ?My Computer? as Removable Disk (I: )? It used to be listed as Seagate...
Try connecting it to another computer. If you can see your data then back it up etc.
After you have recovered your data connect it to your computer, from Disk Manager, remove the partition, recreate it again and then format the drive, hopefully your external drive will be operational again.
There is a possibility that the hard disk has died and you will have lost your data. If you are desparate, hard drive data recovery companies charge an arm and a leg to recover data from dead drives.
Jan 10, 2009 | Seagate Free Agent Go Small 12 GB USB...
Hard Drive Dropped
Hi there
You may want to try going to add new hardware and see if scanning for hardfware change will let it recognoze the device if not uninstall it under device manager and have it reinstall the device upon start up of the pc
Jan 03, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Computers & Internet Logo
225 people viewed this question
David Payne
David Payne
