Question about Garmin StreetPilot c340 GPS Receiver
Garmin C340 battery not charging
I've been using this GPS for about 2 years now and I recently noticed there is no longer a battery icon or power when it is unplugged from the power source in the car. I tried the reset button and that did not work. I also left the GPS plugged into my computer for a whole night and still no battery icon or battery power. Is the battery replaceable? Do I need to change the fuse? I am concerned that if I lose power in the car I'll be stuck. Any suggestions?
  • 6 more comments
  • Anonymous May 11, 2008
    checked power coming in. put new fuze in. battery will not charge
  • JONGRIF May 22, 2008
    i JUST GOT THE GARMIN FROM MY SISTER. SHE HAD IT IN HER CAR AND THE SUCTION CUP STOPPED WORKING ON HER WINDSHIELD. SHE BOUGHT A NEW FLAT SCREEN GARMIN AND GAVE THIS ONE TO ME. I JUST TIRED PUTTING IT IN MY CAR...IT BRIEFLY TURNED ON, BUT THEN IT IS JUST DEAD. I ONLY HAVE THE AUTO CORD FOR IT. IS THE BATTERY DEAD?
  • blackzx1200 Jul 05, 2008
    My c340 is not charging anymore. I changed out the vehichle power cord for a new one and still no battery power. The unit is dead. What do i need to do?
  • u2xtra1 Jul 14, 2008
    it dont want to turn on are charge
  • doug18 Aug 10, 2008
    Battery has seemed to died after about 13 months of use. I plugged the charger into my car's cigarette lighter area and pushed the reset button. At first, the unit worked about a minute or two before dying again. Now the unit doesn't work at all. I am now at a loss as to what to do. I really like the C340, especially when I compare it to the Tomtom One, which someone gave to me as an award for my production at work. Please help. My email address is doug18@optonline.net.
  • Anonymous Aug 12, 2008
    MY GARMIN DIED WHILE IN USE OUT OF STATE,LOW BATTERY MESSAGE CAME ON THEN IT WENT OUT AND WOULD NOT COME BACK ON PLUGGED INTO 12VOLT STILL WOULD NOT CHARGE,THESE
    GPS COST TOO MUCH FOR SOMETHING LIKE THIS TO GO OUT
  • Anonymous Aug 21, 2008
    Battery will not charge and will only work on 12 volt power.
  • Anonymous Mar 30, 2014
    gps will not charge even when plugged into external power
The Garmin batteries tend to die after about 2 years. Garmin will replace the battery for you but prepare to pay top dollar. It is a shame because the problem is commonplace. They should have made the replacement user friendly. The battery is buried deep inside and it is soldered.
Posted on Jul 13, 2008
  • 504 Answers
It is possible the battery has died. This is not designed to be replaced by the consumer. Your best bet would be to contact Garmin regarding replacing the battery.
Posted on May 21, 2008
2 Suggested Answers
SOURCE: Saving Favorites before updating Garmin c340
Use MapSource to transfer the Waypoints from the unit to your PC. If you lose them, you can then transfer them back. (I updated a C330 from 4.40 to 6.10 and did NOT lose them, however.)
Posted on Jul 28, 2008
GPS StreetPilot c340 quit working
Plug charger in, and then reset it. Let it charge for awhile before tryng to use it though. It sounds like the battery is very very low. When it is plugged in it still will not operate unless the battery has some charge in it. I hope this helps.
Apr 18, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin c340 loses the satellite very frequently. Battery?
1. make sure the unit is as low un the windshield as possible, remember it needs to see the sky, the more sky it can see the more sat it can lock in on.
2. Check the GPS Mode, under tools(Wrench), select system, the GPS mode, make sure it is in the normal setting. WAAS is more accurate, but most of the sats are at the equator, so in some areas the coverage is not as good.
Hope this helps.
Apr 17, 2009 | Garmin StreetPilot c340 GPS Receiver
Frozen touch screen on
hold down the power button when you turn it on until the calabaration screen comes up and that might fix your problem
Nov 01, 2008 | Garmin StreetPilot c340 GPS Receiver
StreetPilot c340 will not come on even when plugged in
I had this problem before, i called garmin and they told me that the charger cradle was not design properly so it sometimes doesnt charge...anyways...carefully remove the grey cover around touchscreen and there is a master reset which will set it back to factory...it worked for me...good luck!
Oct 13, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin Streetpilot c340 arrived dead
The battery symbol would show the charge, somethign doesn't pop up.
May 08, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin C340 GPS - Will Not Power On
Thanks. This helped me fix the problem.
Apr 02, 2008 | Garmin StreetPilot c340 GPS Receiver
Charging unit with AC adapter
I have a 100v A/C power / charger unit for my garmin C340 GPS that I use to charge my Garmin's battery every day. I can use thj adapter to run the GPS, or just turn it off and let it charge the GPS. But it connects dirctly to the Garmin GPS unit, not to the cradle like the Cigarrette lighter unit does. .
Mar 18, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin c340 FROZE? Here is how to fix it!
My garmin shuts down immediatly when I switch it on. Dont know if there is an internal battery that needs to be replaced or some thing else.
Jan 26, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin c340 gps freezes up
Avoid buying Garmin GPS. Their units have a non user replaceable battery that last about 2 years. After that, you have to send the unit to Garmin to replace the battery and be hit with at least $150 plus shipping. Possibly more if they need to fine tune something else. Look at other brands with easier battery replacement such as Sony, Navigon, etc. Garmin is a total rip off.
Sep 08, 2007 | Garmin StreetPilot c340 GPS Receiver
Internal battery won't charge
Common issue. Steps to troubleshoot/solve:
1. Pull off face, press reset tab.
2. If unit wont turn on or if turns off immediately, connect to home computer using mini usb on side of gps (any usb cord that fits will do). This will charge the internal gps battery, which is discharged.
3. You will not be able to see the gps charge indicator while the usb cord is plugged into the unit. To check charge level, disconnect it, turn it on, and note the large "battery" icon.
4 Do you have a dead internal battery? If the gps holds a charge from your computer usb port, you don't.
5. If you have a dead battery, Google DIY replacement. With some soldering it can done for $15 total.
6. If you don't have a dead battery, the issue is charging from the cigarette lighter socket. Your car socket may have blown a fuse (check car manual). Your charger unit may have blown a fuse (unscrew the tip, check fuse inside). Also, some car sockets don't work when the ignition is off. Test yours.
7. There is a good chance the connection of the charger wire to the gps cradle is the problem. Fiddle with that. Replacement cradles are available for the c340 at about $25.
8. If your unit is not charging from the cradle/socket, buy a 12v usb cord. Plug into socket and into usb port of the gps. This is a workaround or alternative to buying a new cradle.
9. IMPORTANT: observe the "battery" icon while driving, esp. if you have doubts about charging. Basically, if you can see the icon, you're not connected to an outside (car or computer) power source. That is, if you can see the battery-charge indication, it means your battery is currently discharging and unless you get another power source to work it will be dead in a few hours.
Aug 27, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
2,857 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
