Question about Epson Stylus Photo R320 InkJet Printer
Epson R3220, printer error report says the cd tray is open, (it definitely isn't)
SOURCE: Epson R300 CD/DVD Tray ERROR message with Leopard any Solutions?
One of the guys on this site said read the manual over and over again, and he was right.
You must go to system preferences and choose print and fax. Set the default media to A4. Then in the Print CD program when you hit print your will see fifth line down Epson Print CD on offer. Hit the arrows on the right and choose print settings from the drop down menu and then media type and choose CD / DVD. All should then work. It does on mine.
Regards and best wishes. David
Posted on Jan 07, 2008
SOURCE: cd tray error Canon Pixma MP810
Sorry a little late only just read your problem.
The location is not the bottom tray feeder but the disk tray. In settings change your media type to "Printable Disk" the paper scource should automatically change to "Disk Tray" and hopefully every thing will work OK.
Posted on Jul 11, 2008
PABLOCSA
  • 1124 Answers
SOURCE: Epson Stylus R320 - cant align the CD tray to print....keeps showing error.
This printer has a bad system tray. If doesn't work in regular way, try inserting the cd tray from the back using the back slot and see what happen (usually works)
Posted on Oct 03, 2008
jacklee366
  • 541 Answers
SOURCE: Epson stylus photo R300 cd/dvd tray not set correctly
you can try and reset the printer with software let me no if you dont haver it
Posted on Nov 18, 2008
SOURCE: epson R300 printer cd/dvd tray
I had the same problem and after a few uninstall and re-install, what I did is to pull the printer away from the wall, and voila! it works fine.
What happened is I didn't realize that when it pulls the tray in, it pushes out on the back, and as it was close to the wall it couldn't, so I got the error message.
Posted on Dec 02, 2008
A problem with epson artisan 810
  1. Turn the printer off, then disconnect the power and the interface cable. Open the cover and check for any torn or jammed paper and remove it.
  2. Reconnect the power cable and turn the printer back on.
  3. Press the Copy button and see if the unit responds.
Note: Also check that the ink cartridges and lids are pushed down fully.
If the problem persists, an unknown printer error has occurred. The printer may require service.
Sep 08, 2014 | Epson Artisan 810 AllInOne InkJet Printer
My Epson Artisan 730 Printer keeps ejecting its CD/DVD Print tray, saying that there is a cd there. There, of course isn't. Can anyone help me? I really need to print.
My husband adjusted the CD/DVD tray, then we selected the icon that looks like a wrench on the printer's message window, then "restore default settings" on it. Turned computer off then on again, and it FINALLY started working again :)
Jan 14, 2013 | Epson Artisan 730 All-in-One Printer
I have an Epson R 300. It worked fine with my PC. I recently got a new I-Mac and I cannot print CD/DVD's. I have the Epson "Print CD" application loaded but when I try to print on a DVD I keep getting an...
If you are using a leopard operating system, you have to install easyprint. http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=26322&prodoid=37368458&infoType=Downloads&platform=Macintosh,
Trash / re-install epson print cd.
There is a work around for that. Please contact epson.
Apr 30, 2009 | Epson Stylus Color 300 InkJet Printer
Epson R300 printer cd/dvd tray
you can try and reset the printer if you dont have the tool let me no
Nov 15, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson 220 not printing cd labels anymore
Clean the white areas on the tray with a light solvent cleaner like windolene/windex liquid. Also try giving the tray a helping hand as it is started to be fed into the printer
Nov 08, 2008 | Epson Stylus Photo R220 InkJet Printer
Oct 03, 2008 | Epson Stylus Photo R320 InkJet Printer
Epson stylus r1800 problem with printing on cd/dvd
Try this :
Disconnect the printer from the computer.
Turn it off & make sure the CD/DVD tray is closed then turn it back on.
Here's generic instruction for you:
If you are receiving an error pertaining to the CD TRAY NOT BEING INSERTED CORRECTLY, please do the following:
Recommendations:
-Don't force the CD/DVD tray into the printer.
-Make sure your printer is powered on, and the output tray is in the upper position.
-Please ensure there is at least 3 inches of space behind the printer, or the CD tray may eject.
Included, are the correct CD/DVD loading instructions. Please follow the instructions below:
CD/DVD LOADING:
1. Ensure the printer is powered on. Remove any paper from the sheet feeder.
2. Push in the paper support extension on the printer, and close the paper support.
3. Push in the output tray extensions, but leave the tray open.
4. Lift the output tray. Place one hand on the top of the printer, and pull up on the output tray until it stops. Lay the tray down in the upper position.
5. Place the CD or DVD into the CD TRAY with the white (or printable) side facing up. Note: To print on small 8cm CDs, please place the small CD ring on the tray first, then place the CD inside the ring.
6. Slide the tray into the tray guides located in the output tray. Push in the guide until the arrow on the tray matches up to the arrow on the tray guide.
7. Press the PAPER button to load the CD/DVD into the printing position. The CD is correctly loaded when the printer's POWER button stops flashing.
General tips for CD and DVD printing:
-Burn data/video/images onto CDs or DVDs before attempting to print on them.
-Do not use thermal-printable or regular CDs or DVDs in the printer.
-Moisture or fingerprints on the printable surface of the CD may cause marks or smearing to appear after printing.
-All printable inkjet media is different. Some surfaces will absorb ink better than others. If output appears banded, faded, or streaky, print a Nozzle Check pattern to confirm that all colors of ink are printing completely. If the ink does not completely dry or smears after 24 hours curing time, you may need to use the Epson Print CD tools to adjust (lower) the print density.
-The only supported resolution for CD/DVD printing is 1440 dpi (aka "Photo")
-Borderless printing and printing on the "inner circle" (plastic around central hole) of CDs is not supported.
-Do not use the "print preview" feature provided by the Epson printer driver as it will only show the image on a blank field and does not offer a clear indicator of where the image will print.
-The Epson Print CD software works best with JPG images and may not import some TIFF images.
Sep 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson 300
It sounds that there is a possible hardware failure concerning CD/DVD guide cover. We can try this to resolved that issue:
1. Turn off the printer.
2. Close & open the CD/DVD guide cover for three times and make sure that the CD/DVD tray is not inserted.
3. Close CD/DVD guide, Turn the printer on. If printer is ready, press the maintenance button.
4. Try printing again.
If the above step wont resolved that issue your printer may need to send to a nearest Epson Authorized Service Center.
--->>> Tirzo
Jun 04, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson stylus r300
Hi Chillyslade,
Try this..
Close the CD/DVD guide, then press the font28.gif maintenance button.
If the CD/DVD tray is inserted, remove the CD/DVD tray, then close the CD/DVD guide
Hope this works, kindly let me know by providing your valuable rating.
Thanks,
Robosoft.
Jan 04, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R320 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
