Question about Cameras
Ixus 70 lens stuck out message says restart but it will not work
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 26, 2010
How to restart canon ixus 70. Get an error message saying ''Lens Error. Restart camera.'' Lens won't extend.
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your batteries need to be replaced because they are just too worn to properly power the camera. And then, of course, there's the possibility that your camera may have a problem that requires professional repair.
Sep 27, 2009 | Canon Cameras
How to fix canon ixus 7o lens error restart camera?
Do you mean its taking black pictures? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 05, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
PowerShot SD630 lens stuck out, says lens error, restart camera
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 20, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon ixus 75 digital camera reset?
Hi
What you are seeing is just an error message, starting your camera again won't do anything unfortunately.
You need to replace the lens, we have your lens repair available on our site for about $75! If we can help please let us know.
Thomas
Owner- Darntoothysam com
Apr 07, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Error on lens
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jan 18, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Lens Error, Restart Camera
Jan 02, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Camera lens will not open
Oct 12, 2008 | Canon IXUS V2 Digital Camera
Lens error
Press the power button on and hold it down while extending and twisting the zoom lens......
Oct 03, 2008 | Canon IXUS V2 Digital Camera
Cameras Logo
24 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
