Question about Cub Cadet Garden
Trying to reset the service reminder after i done the service oil change etc. and also its a i 1042 zero turn but cant figure out what blade it takes, the motor was manufactured 12/07. and 1 more thing what do they mean by timed deck
  • 19,396 Answers
Hi.
Even if service on this tractor is due every 100 hours, this model should not have any service light. Ensure that the problem is not the oil light coming on because of low oil level.
Here the manual
Other Cub Cad tractors can be reset with the same trick working on Mahindra (they are both Mitsubishi tractors).
I quote from this website.
"1. Lift the small fuse cover
2.Put the key switch on to "IG" position
3. Wait for 10 seconds
4. Short circuit terminals for a moment
This should silence the service light and busser."
Posted on Aug 26, 2010
2004 Ford Explorer UZ XLT "Oil Change Required" maintenance reminder reset
Try turning the ignition to on and push the trip meter knob in and hold it till it resets.
Aug 23, 2014 | 1999 Ford Explorer
How to reset service reminder alarm on Toyota aurion 2008?
I am not familiar with that model but most Toyotas reset like this. Tune the key off. Pess and hold the odo/trip reset button while you turn the key to the run position (do not start the engine). The odometer should change to all dashes which will disappear one at a time then change to all zeros and then back to the mileage. Release the button as soon as the mileage is displayed. Sometimes the trip A needs to be displayed before you turn off the key to start. Your owners manual should have this info as well.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Aug 07, 2012 | Cars & Trucks
Try starting doesn't seem to want to turn over try a few time usually start after a couple of time dignontic done could not fine problem started everytime started today did uturn then died now change...
You have several different problems.
First, the starter...if you are hearing a loud "click" several times before the starter engages and cranks the engine, you have a bad starter solenoid and you need to replace your starter.
The dying problem could be caused by a WHOLE LIST of things. It could be anything from a bad Idle Air Control (IAC) motor to a fuel pump that works when it wants to, or a bad Crankshaft Position sensor circuit, etc. Unless it sets a fault code in the computer or does it on a regular basis, you will probably never figure this one out.
The Change Oil light is simple: You just need to reset your oil change reminder. Sometimes it doesn't get reset when the oil change gets done and then comes on only a few miles after an oil change. This is very common - it even happens at my shop sometimes. If the oil change reminder light is not on when a customer brings the car to me for an oil change, I don't think to reset it. Not all cars have them, and of those that do, half the customers reset the light themselves. I simply do not always take the time to look it up and see if it even has one. They are different depending on what kind of vehicle you have, so I cannot tell you how to reset yours because you forgot to mention what kind of vehicle you have...YEAR, MAKE, MODEL, ENGINE SIZE, etc. (This would be nice to know if you really want help fixing your car.)
Jun 21, 2011 | Chrysler Concorde Cars & Trucks
How do you turn off the "Car needs Oil Change"
1. Make sure the trip odometer is NOT on 'Trip A' or 'Trip B' (ie: just the normal ODO). With the ignition off, press and hold the reset button. Press the 'Start' button twice without pressing the brake, but while holding the reset button. The dash will let you know its resetting, just keep holding the button until it is done.
2. Make sure the Trip/Odometer is set to "trip A". With ignition off press and hold the reset button. While pressing the reset button, press the start/ignition button twice to turn ignition on. Keep watching the trip/odometer display to flash the lines (-----) until you see it flash the zeros (00000) then it
Feb 22, 2011 | 2009 Lexus LS 460
My indicator light is showing MAINT. REQ even though i already replace new oil and filter
you need to reset it. by having key turn off and pushing the trip reset button on the dash. then turn key on and the light should blink and go out after a while keep holding button tell it goes out
Sep 07, 2010 | 2009 Honda Accord
Just had oil change done on my 2000 alero now my service engine soon light is on.I want to know what this means
It simply means that the service indicator was not reset when the oil was changed. If the oil was changed professionally, then resetting the service indicator is usually part of the job.
It's not just a reminder to change the oil, it's also there to remind you to check/adjust/lubricate/replace other items such as the air filter, oil filter, spark plugs, fuel filter, dampers (UK=shock absorbers) etc.
The service indicator is simply a dumb counter keyed to mileage and time elapsed and cannot sense when you have completed a service. Resetting the indicator requires a special tool so you'll need to take your car to a suitably equipped garage.
May 03, 2010 | 2000 Oldsmobile Alero
Why maint req´d driver in my car lit? what´s it the problem?
Maintenance required light is a reminder to change the oil. if you have had the oil changed within the last 3000 miles its likley the people that did the oil change didnt reset the light, if im not mistaken, to reset that light turn the car to the key on engine off position and hold the odometer button down until the light blinks and goes away
Apr 09, 2010 | 2005 Honda Civic
I have a 2008 corolla. It has an auto light when the car needs an oil change. I need to know how to reset it.
Look in your owners manual and go to the part that explains the different symbols on your dash. Look for that service reminder and it should tell you what page to go to to learn more about that. Somewhere there should be some wording to the effect that "When you have your car serviced by a certified Toyota dealer they will reset it for you. In the event that someone other does your maintenance then this is the procedure to reset......."
Oct 04, 2009 | 1998 Toyota Corolla
How to clear a maintenance request message from a volvo 2006 S60
can you scroll down to the mileage indicator for the oil change and re-set it again to zero miles on the oil change.....just an idea
Sep 11, 2009 | 2006 Volvo S60
My car has the oil light on
First - did you use the correct viscosity - SAE spec ?
Using a thiner oil can affect oil pressures.
Presuming that you did, and oil levels are ok, then I would check if this is a standard service light come one. They are programmed to light after a certain milage since the last change - and this seems likely if you have just done it (before light came on to remind you)
Try resetting it. This works for most models -
Turn ignition on - so you get display/ lights etc.
Set trip meter to show milage.
Turn ignition off.
Press trip meter button - and keep pressing it while turning ignition to on again.
Light should blink and go out.
Take finger off trip meter.
Depending on model - you may get some figures - 1200 , 800 , etc. This alows you to change service interval if you want - but if not - then just turn ignition off again.
Light should stay off.
If this doesn't solve it, I'll look for specific info of how to do it - or start checking other possible causes to check.
Aug 11, 2009 | 2006 GMC Envoy Xl
Garden Logo
89 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
