Question about Elna Heirloom Edition 6005
Bottom thread is loose and loopy, have tried new needle, thread, cleaned out bottom, tension adjusted.....nothing works, can you help. I see many others have same problem but i cannot see an answer
  • 109 Answers
When your bottom thread is loopy it means that the UPPER thread is not properly threaded. First make sure your needle has the flat side to the back of the machine and that it's the right size needle for your machine and the fabric you're using. You probably missed the tension discs when you threaded the upper thread. Make sure that your presser foot is up and that your needle is in the uppermost position. Try re-threading it and when you get to the tension discs pull the thread back and forth so you hear a little snap. That tells you that your thread is being placed in the discs correctly. (This also cleans out your tension discs in case there's lint in them.) Make sure that you tension dial is on about #4. Finish threading and you should be good to go. Thanks for using FixYa!
Posted on Aug 26, 2010
Tension - I am getting a loopy bottom row and a straight top row of stitching when using a slightly thicker thread. If I adjust the tension on the wheel the thread just snaps.
If when tightening the upper tension the thread breaks it is likely the needle is two small.
Try sewing same setup with a very light fabric. The weight of the fabric can also require a larger needle to provide for a channel to allow the tension to pull the thread up. Check that the thread is properly routed through the tension mechanism.
26255548-krhgav1oaptdc4xjlkggf2tf-3-2.png Confirm that the needle is installed correctly.
26255548-krhgav1oaptdc4xjlkggf2tf-3-9.jpg Hope this helps?
Aug 09, 2016 | Sewing Machines
Why does the bottom tread come out loose and loopy
First, check the stitching to verify that it is in fact the bobbin thread that is loose & loopy. Usually, loopy thread under the fabric is the upper thread--which, if that is the case, is an indication it is either threaded incorrectly or the upper tension is too loose.
Make sure you are using a brand-new needle.
Always RAISE the presser foot and then thread the upper thread making sure that every guide and the correct path is followed.
Set the upper tension to the midway point between high & low number and re-test the stitching. Re-adjust as needed. The tension is correct when both upper and bobbin threads meet in the middle of the fabric.
Understanding Thread Tension Threads
If it is in fact the bobbin thread causing looping, it could be that the bobbin case is not threaded properly or the tension is way off.
Liz Kettle adjusting your bobbin case tension 1 wmv
Apr 11, 2016 | Sewing Machines
Model 525B. Why is bottom stitch loopy and the hand wheel and needle jam?
try a new needle
try adjusting the top thread tension to see if that helps the bottom loopy stitch
Jan 10, 2016 | Janome Sewing Machines
Correct bobbin size for a Necchi Omega 6030
You can use either 16 or 16J. If your threads are loopy on the bottom side of fabric, the problem is either your needle thread tension is too loose or you have a snag in your needle plate where you have broken a needle. Check needle plate and clear snag if any. Then tighten up your needle thread tension until both needle and bobbin threads are in middle of fabric.
Jan 30, 2015 | Necchi 6030 Mechanical Sewing Machine
Over locker loopy bottom stitch
Loopy on bottom means the top tensions need to be adjusted. "All on 3 means nothing" These are tension knobs and are not required to be on the same number.
In the mean time rethread the machine with a different color on each spool This will help you determine which thread is the offender. sew the same type of material this thread set up... tighten the corresponding tension dial. Once you get a good stitch, Lift the food, cut all the threads near the spools and tie off new thread/spools and pull the thread through to the needle. Once it is all threaded again test your stitch with the same fabric again.
Oct 02, 2013 | Sewing Machines
Brother cs-6000 will not sew, the top thread go through and tangles on back, and the bobbin thread is a straight line and can be easily pulled out, please help, trying to make kids school clothes
Hi:
Ok... so try to remember that loopy stuff on top means the bobbin tension is too loose (or the top tension is too tight...)
Loopy stuff on bottom, means the top tension is too loose. (or it's not threaded right)
Now. Get some scrap of the same material. Loosen that bobbin back to where it was. RETHREAD the top, with the foot in the UP position.
Place your scrap under the foot, and sew. still have problem? clip your threads and try again only this time hold the top and bottom threads off to the side as you begin to sew. How did that do?
Adjust the top tension to the point where you start seeing the bobbin thread come up in loops to the top... then back off until the disappear.
Now... be sure you have the correct thread and needle for your fabric. A lot of problem are caused by not having the proper needle and thread.
Jul 09, 2012 | Brother CS-6000
Back thread loose and loopy - tension
If you have the instruction manual, you might read the chapter which describes the proper adjustment for threads and fabrics.
If you do not have one, try to find it on eBay. It is the huge source of everything.
Feb 20, 2012 | Juki MO-644D Mechanical Sewing Machine
I have a brother XL2600i machine. It was sewing fine, but now, the bottom thread is all loopy. I have tried reinserting the bobbin, and making sure that it goes through the tension adjusting spring. But it...
try these suggestions
check top tension & try a tension of 3 to 5
try a new needle-flat side goes to the back of machine--also make sure the needle is the correct one for the fabric & thread
Sep 09, 2011 | Sewing Machines
Tension problem
Set the top tension as recommended by the mfg - this is usually between 3 - 6.
Now re-thread the machine with the presser foot up and see if this doesn't eliminated the loopy stitches.
What appears to be an issue with the bobbin may actually be the top thread was not seated into the tension during threading and the tension cannot control the flow of thread to the needle and you get a loopy stitch.
Keep the bobbin case clean as built-up lint can cause stitching problems.
Feb 20, 2010 | Brother LS-2125 Mechanical Sewing Machine
My bottom thread is loose and bunchy. When I checked my seam, it got progressively worse from start to finish. This is a new machine, and I'm baffled. Nothing has changed from project #1 to this project #2...
The case that holds the bobbin in the bottom has a small screw that needs to be tightened. Do so by a quarter turn at a time and test the sewing on a scrap of the same material you are working on until you get an even tightness between top and bottom threads.
Mar 13, 2009 | PfaFF Creative 7570
Sewing Machines Logo
80 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
