Question about Cameras
Camera will not accept a tape. auto ejects without dropping into camera and an intermittent high pitched beep sounds. was working fine. last cartridge ejected, the tape was pulled out a bit when taken out of camera.
  • mollie123 May 06, 2008
    it is a cannon HV20 HD cam corder
    it beeps five times when the tape carrage is first opened and again when a tape is inserted. tape ejects automatically without loading into the camera.
  • 3,037 Answers
Possibly there is moisture in your camera. Please inform us of the exact model of your camera and how many beeps it may give in a row so we can narrow down your problem.
I would first leave the camera to sit overnight and see if it works in the morning. Remove the battery during this time too.
Let me know how this works out
thanks
Posted on May 06, 2008
  • Benjamin Patri
    Benjamin Patri May 06, 2008
    Please only rate the solution as Fixya that fixes your problem
    Master:
  • 555 Answers
What is the maker and model of your camera?
  • Matt Jurach
    Matt Jurach May 06, 2008
    You can follow a troubleshooting guide for your camcorder at Canon-USA's support website.
  • Matt Jurach
    Other users like you have reported the same problem, and found that it is a hardware fault requiring service from an authorized technician. Most have been sent back to Canon for repair.
SOURCE:
Canon zr700 won't play tape
That is the pinch roller. If it does not press the tape against the capstan, then the tape will not pass the read/write heads. Replace it.
Jun 25, 2017 | Canon ZR700 Mini DV Digital Camcorder
Everytime a place a cassette in the recorder...it makes a high pitched wine sound and ejects the tape...and says "remove the cassette" with 5 "beeps" following. I've read these complaints on other...
Tape mechanism problems are quite complicated but they can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I
Oct 18, 2010 | Canon ZR200 Mini DV Digital Camcorder
The tape will not eject, battery is charged, help! Thank you!
Unplug battery and reattach it again, then try to eject the tape.
If problem still exist and camera shows error code "C:..:.." and beeps then it is problem of tape mechanism.
Dec 13, 2008 | Sony Handycam DCR-TRV50 Mini DV Digital...
Won't properly accept tapes/ tape won't fully insert
probably a bent cassette housing in the deck - time to seek out jvc authorized repair.
Jun 12, 2008 | JVC BR-DV3000U DV/Mini DV VCR
Audio problems
Video head is dirty/ clogged, use good quality head cleaning cassette. If problem still exist, go to nearest Sony repair shop, they will use Lapping tape to clean head.
May 31, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Flashing code C:32:11
USE THE MAINS ADAPTER....TAKE THE BATTERY OUT, AND CONNECT MAINS ADAPTER THEN IT SHOULD WORK THEN TRY EJECTING THE TAPE AGAIN
Feb 23, 2008 | Sony Handycam DCR-TRV103 Digital Camcorder
Canona Elura 60 problem...
What a hunk of junk. Not a month after the warranty period expired, my Elura 60 would zoom out without warning and refused to stay zoomed in. I paid Canon to fix that problem.
Now, I'm on vacation (in the Carribean for more than 24 hours) and the unit wouldn't accept a tape. Every time I tried to load a tape, it would beep five times and then kick the tape out. So I tried taking all of the batteries and media out. That didn't work.
Next, I tried the drop method. I figured the unit is broken and I'm not going to pay again to get it fixed, so dropping it couldn't break it anymore than it already is. I let the unit fall onto the throw rug in the bathroom. In then tried to install a tape. Waddyaknow! It worked.
I can only reiterate again two things: dropping the camera from about 6" onto a carpeted surface over a tile floor seemed to clear up my "remove the cassette" problem, and the Elura 60 is a temperamental hunk of junk (although the recordings and playback are pretty good, when you can actually get a tape into the unit).
Nov 12, 2007 | Canon Elura 60 Mini DV Digital Camcorder
High pitched noise, then ejects tape
Hi friends. (Excuse my poor English). Well, i bought a SCD364 Samsung CamCoder that is physically and mechanically exactly as scd363. My scd364 also have the same problem. Because the warranty has expired, i discovered a solution. The problem ocurs due to a missing calibrati?n at tape motion mechanism then when the cam goes heat, the motor grazes with another part of the mechanism that this located very near (wax)causing a metallic noise, eating the battery and, finally the blinking "D" eject signal. I amazing when discovered that the solution is to open the tape compartment and place the opened camera infront of the air conditioning machine by 2 minutes in order to cool it. Once cold, the camera is ready to play or record again without noise and blinking "D".
Jun 04, 2007 | Samsung SC-D365 Mini DV Digital Camcorder
Ejects Tape after high pitched noise
Will not accept any tape
i bought this camara from someone with the same problem for 5 bucks at a yard sale. an easy fix. 1. blow the dust out 2. charge the battery. 3. put the tape in and when it gos down into the case close the door and turn it on, run tape on ff then rr then turn camara to record. if it says to eject tape at any time, eject it and do it again. it worked for me.
Jan 11, 2007 | Canon ZR80 Mini DV Digital Camcorder
Cameras Logo
60 people viewed this question
Top Cameras Experts
Marvin
Marvin
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Camera Expert? Answer questions, earn points and help others
