Question about Kenmore Sewing Machines
On my Kenmore sewing machine Model 1756 when I press the pedal the needle does not move. When I turn the hand wheel the needle does not move. any help out there? or is the machine done for
    Problem Solver:
  • 13 Answers
Disengage the sewing mechanism (like you are winding a bobbin)
If the motor runs fine that way then you have a machine that is frozen.
If that is the case take off the top, bottom, needle plate, needle bar and bobbin cover. Spray all moving parts down with Mean Green and let it sit for about an hour. After that blow it out with canned air.
See if there is any improvement. If so you just need to clean out all the old lubricants. Sometimes I take a hair dryer to loosen the sludge up.
Posted on Aug 26, 2010
The handwheel will turn manually but it will not move using the foot pedal. The sound it makes when I press on the foot pedal *sounds* like I am filling the bobbin.
foot pedal not moving needle - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Sewing
Nov 8, 2013 - We have a Brother Limited Edition Project Runway Sewing MachineRefurbished LS2250PRW. I was trying to sew on a button and was turning the hand wheel to do ... front near the needle where you can run the machine with foot pedal ...just what I would experience when my Bernina was running, or not, ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home.../Machines/Sewing_Machines/index.html
The thread is being picked up from underneath, but will not form a stitch at all. ... Butwhen I push my pedal down my needle won't move, the motor runs, but nothing happens. ... I have a Bernina machine which is sewing OK with the normal foot. ....The hand wheel, the wheel at the end that manually turns to make the needle ...
Help me diagnose and fix a problem with my sewing machine - Sewing ...
artisanssquare.com > ... > Sewing Machines
Jan 11, 2016 | Bernina Sewing Machines
The needle does not move when the foot pedal is used.
Make sure that you pushed the bobbin winder all the way to the left.
Jimmy
Apr 01, 2012 | Singer 7444 Mechanical Sewing Machine
Needle and take-up lever don't move when I push the pedal
It's possible there's a part loose or broken only a sewing machine repair shop can tell what's wrong
Feb 02, 2012 | Singer Sewing Machines
Kenmore sewing machine Model 1602: I was filling a bobbin and when I went back to sewing - the needle won't go up and down. Motor runs when I press on the footpad. It is as if the clutch is stuck as well...
Sound like you need to take it out of bobbin winder mode. Suggest looking for a way to engage the clutch. Turn the center knob on hand wheel and or move the bobbin winding post back to postion.
The center hand wheel should move about 1/3 turn towards you to look it back into place.
Feb 09, 2011 | Kenmore 15516 Mechanical Sewing Machine
My needle won't move up or down when I press the foot pedal or turn the side knob manually. What can I do to fix this problem?
The needle on my sewing machine won't move. The pedal makes a noise but nothing happens. The hand wheel doesn't turn either. Please help this is the first time I have tried to use it and disaster
Sep 27, 2010 | Brother LS-2125 Mechanical Sewing Machine
The needle is stuck,not moving.its very hard and the motor makes a sound but needle does not move.
Refer to your manual and make sure the bobbin winding feature is disengaged.
Turn off the power and remove the needle and if there is fabric, remove it also.
Open the needle plate look for thread tangles.
After cleaning, turn the hand-wheel by hand to see if it moves the needle up and down.
If it does, press on the foot pedal to see if it is working.
Any of the above could be the problem.
Mar 01, 2010 | Kenmore Sewing Machines
Hand wheel wont turn on my Kenmore sewing machine
it sounds like the belt to turn the wheel broke
Dec 12, 2009 | Kenmore Sewing Machines
Won't sew when foot pedal is pressed
foot pedals do fail and possibly your s has .
Oct 31, 2017 | Kenmore Sewing Machines
When i press the pedal, the needle wont move and i already oiled the machine
press the hand wheel in. On this machine you pull the hand wheel out to disengage the needle while threading the bobbin and press it back in to reengage the needle.
Jul 11, 2009 | Kenmore 15212 Mechanical Sewing Machine
Kenmore 10 stitch needle won't move
hi there,
push or pull hand wheel clutch to engage
motion of needle and shutter.
if not check belt on downside of hand
wheel open cover motor,loosen bolt cover
see belt check if engage on pulley by
holding hand wheel move belt if
hand wheel move,if not tighten screw on
pulley from hand wheel and moter.
have a nice day and thanks
Apr 03, 2009 | Sewing Machines
Sewing Machines Logo
291 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
