Hi have a panasonic tv ct36d308 and it dead relay clicks fuse ok
  • 70 Answers
Relay click means stanby power supply working fine pls check the other power supply section and trouble shoot
Posted on Aug 26, 2010
Why wont my tv come on after I unplugged it from the wall while it was on.
hi yes this is possible, there's a glass type inside the tv, but beware if you replace the fuse and it blows again there's a dead short, thanks
shaun
Feb 13, 2017 | Panasonic Televison & Video
Where is the fuse located for the tail light on a 2007 jeep command
commander, is a grand with diffr, rear seats, bla bla.
the book is free, for the WK posted 300 times.
click free here, then click WK.
http://jeepdied.com/books.html
THE BETTER question is HOW do they work?? IT'S NO 1993.
they are park lamps, tails is old skool name, ok no prob.
parks are front /rear and sides
so all parks dead. be key fact, even the dash dimmer uses the parks (first click of the HL switch is PARKING LAMPS)
I might add that we have answered this maybe 3 times here.
already. ill do it one more time.
in the same book chapter 8w covers this, called exterior lighting or lamps.
it is digital controlled.
the TIPM underhood does this.
the TIPM hears the network commands for parks.
and closes its PARK relay
this relay then runs all park line feeds. front and rear
the license plate is a park lamp. too.
the 3 fuse are 8,9,10 in the TIPM under hood. clearly marked park.
if you look there the lids has all then names , marked.
that does rear.
8w-51-4 covers rear.
same fuse 8 left 10 right.
if 10 blows the cab switch bank goes dead for illumination.
but you never said how many are dead.
if all are dead and the relay is ok
the programming is bad or
you forgot to see DTC errors scanned.
if all lamps are dead, it must be scanned, or replace relay
2005 up'
Jan 19, 2017 | Jeep Commander Cars & Trucks
Horn relay
my guess, its a dead horn? both dead?
no actual question asked????????
the fuse is blow? in fuse box, eng. bay box.?
if no power to horn, (voltmeter)
we check power in and out of relay if there is one.
then at the horn button wire, (air bags can kill any mech. defeat them
first if heck bent to fiddly steering column parts in any why)
all this info is convered in in the FSM, get one. or login to alldata dot come. and read it.
here, ill look at yours. now.... a fast look.
ok 2 horns, hi/lo, and 1 relay in the under hood fuse box.
it should be labeled in the box, HORN
the relay can not work if the fuse is blown
or the horn enable line is dead. button.
the button grounds (0v) the relay via wire color lt.green-blu pin a11 on relay. if the a11 is at 12v the fuse is good.
if you push the horn button this A11 goes from 12v to 0v, and the relay energizes (click) and the horns both blow.
if no power makes it to the horns, the relay is bad no 12v
if by chance the relay output to horns go to 12v, then the horns are both dead.
Oct 05, 2013 | 2003 Honda Pilot
My Panasonic TC-32LX85 LCD TV powers on but then clicks of and on repeatedly?
The main power regulator board to your TV should be checked. In most cases, it need replacement.
Feb 05, 2013 | Panasonic TC-32LX85 LCD TV
Hi, I have a 5-year Panasonic TH-42PZ700E plasma and a week ago it got broken. When I tried to power it up with the remote, it just didn't do anything. Tried the power button with the same...
Hi from your description it sounds like your TV is turning on since the red light stays on and it's not blinking. In that case I would say that since your TV is on but you are not geting a picture then one of your Zustain boards is bad. the first thing I would do is to check the fuses since you said you already did that and they are fine you can check that their is high voltage getting to your Zustain board. Their is a sticker on the screen that tells you how much voltage they should be geting. Usually about 220 volts. If you are getting voltage to both bords you can check to see if the heat sinks are getting how. They are supposed to be hot so if they are not that board is bad. If all else fails you can try replacing both boards. To order parts you have to get the part numbers from the actual parts. You can get parts from www.interliquidparts.com
Jun 13, 2011 | Televison & Video
It wont turn on
You give us littel to go on here. Can you describe what happens (if anything) when you attempt to turn on the set? Is there a click? Is there a standby light on the set before you try turning it on? Is there sound or nothing at all?
While possible, dead sets are not usually caused by a blown fuse. If the fuse is blown, then the power supply will need work. If not blown, the power supply may still be the problem. Please update this with any other symptoms and we'll try to assist further.
Thanks,
Dan
Apr 08, 2010 | Panasonic Viera TH-50PZ85U Plasma TV
The TV will not power on at all
Is the set completely dead? if so you should see no indicator lights and hear no "click' when the power button is pressed. If so than the only thing wrong with the set ic the main Fuse (6.3A 250VAC) has blown.
Sep 19, 2009 | Panasonic CT-32HC14 32" TV
My Philips 20' TV Dead condition
If you still haven't thrown the set away . . . The ticking noise can come from different sources; either a relay that is tripping so the set doesn't burn your house down, or the horizontal output transistor is shorted shutting the set down, or there are failed components in the power supply.
I'm not sure which 'line transformer' you suspect but it isn't a likely place to look for this problem.
Sep 09, 2008 | Philips 20PT6441 20" TV
Panasonic TX14S2T
What are the symptoms? Is the set dead? Please clarify
model number from back of set...The red power light coming on means the AC fuse is OK, but the B+ fuse may be bad. If that
is true,check the horiz o/p xistor and get back to me....T.
Oct 20, 2007 | Panasonic CT-27G14 27" TV
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
