Question about Irons
My Philips steam iron Easy Care 3232 oozes brown liquid through holes when used on steam. How can I clean it?
Periodic Descaling of the iron will help reduce this.
Mineral deposits in the water will remain inside the iron after being converted to steam. This builds up over time as scales unless cleaned.
For descaling instruction, refer to manufacturer.
Posted on Aug 27, 2010
Why is brown liquid coming out of bottom of iron when steaming
this is usually a sign of not enough steam. allow your iron to heat up. you may also need to clean your iron.
Apr 30, 2018 | Irons
We have a GC8420 steam iron. The steam is regularly discoloured, first a pink, chalky stain - very difficult to get out of fabrics - and today a lot of dark brown/black water coming out. We do empty out...
Hi, Brown water and whitescale are often the result of the water you use in the iron... If you have scale, white vinegar will clean that... For brown water, empty the iron, rinse out the insides with bottled water, and then use the bottled water instead...
Also check out this tip...
Cleaninga Steam Iron White Scale and Brown Water
heatman101
Jul 14, 2011 | Philips Irons
I need to descale my iron and don't have any instruction manual.
heatman101
Apr 03, 2011 | Philips GC 2522 Iron
How do I clean the water reservoir in my T-FAL Avantis 90 iron. When I use the iron hard particles come out of the steam holes.
heatman101
Mar 23, 2011 | Tefal Avantis 90 Iron
Clean iron?
Hello tcant....
  • 1 Fill the iron's steam receptacle with white vinegar or CLR, a product used to clean coffee pots. CLR is available in department stores.
  • 2 Plug in and set the iron to its steam setting.
  • 3 Operate as usual. When the vinegar or CLR begins to steam, operate the iron as you would normally. Press it over an old, clean towel as the vinegar or CLR loosens sediment and dirt from the appliance.
  • 4 Continue ironing until all of the cleaning solution has steamed out. Repeat the cleaning process if necessary until the iron no longer oozes discolored liquid and the ironing surface is clean.
  • 5 Fill the iron steamer receptacle with distilled water and set the appliance to steam.
  • 6 Continue steaming until the smell of vinegar or CLR is gone.
  • 7 Prevent future mineral buildup by using distilled water for steam in your iron, rather than tap water. Joe. Thanks for choosing Fixya!
  • Jan 12, 2011 | Black & Decker ICR250 Iron with Auto...
    Brown coming through holes and there is a funny odor.
    Tell us what water you have been adding to the iron over the years?
    Often times our household drinking water is 'hard' or has iron in trace amounts in it- While it may not be toxic to our bodies-- when you boil it off in the steaming process, the minerals remain behind, and make a brown or dirty residue in the chamber. That residue will often 'bleed' out into the passages of the steam holes.
    Have you ever used Vinegar to try to clean out the chamber?
    Tho this might helb get rid of the residue-- it does tend to move the debris into the steam passageway-
    So-- unless you have some way of spending considerable time and effort cleaning it out-- It may ruin more white shirts in the process than it is worth.
    Note: Using distilled water will extend the life of a steaming iron-- but eventually, even the best treated Steam iron will need to be replaced!
    Mack B
    Dec 27, 2010 | Krups V70 Iron
    How to clean a phillips gc 8320 steam iron
    <div class="solution-text"><span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">Hi,<br />Here is a tip that will help you with that problem...<br /><br />Cleaning a Steam Iron Soleplate</span></div> <div class="solution-text"><span><br /><a href="http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate" target="_blank">http://www.fixya.com/support/r5301167-cleaning_steam_iron_soleplate</a></span></div><span> <div class="solution-text"><br />Cleaning a Steam Iron White Scale and Brown Water</div> <div class="solution-text"></span> </div> <div class="solution-text"><span><a href="http://www.fixya.com/support/r5300985-cleaning_steam_iron_white_scale_brown">http://www.fixya.com/support/r5300985-cleaning_steam_iron_white_scale_brown</a><br />heatman101</span> </div><!-- /solution text --><!-- helpful bar -->
    Aug 26, 2010 | Philips Irons
    Our iron keeps shutting off and on. It then spurts out brown liquid from the iron. It is on my wall and it stains our clothes
    the brown liquid is rust from leaving the water in the iron. Always dump the water out when you are done ironing. You need to run a descaler through it. you can purchase descaler online. The shutting off and on could be a loose wire.
    Aug 11, 2010 | Euro-Pro Shark GI490 Iron
    Dirty water in my iron
    The dirty water coming out of your iron steam holes is caused by the accumulation of 'dirty' tap water: if you look inside an eletric kettle, you will see the same 'dirty' muddy brown mineral residue on the inside. In addition, if your iron is old, it can also be rust. It is a pretty common problem that can be minimized by using distilled water. You can get commercial steam iron cleaning fluid to clean the inside of your steam iron or you an simply use vinegar: 1) with a cold iron, fill the reservoir with straight vinegar 2) Place your iron on top of a metal kitchen rack above your kitchen sink, turn iron on and let it steam out all the vinegar: it should spit out the whitish mineral and muddy brown deposity. 3) Refill iron reservoir with clean water and repeat as of step 2. 4) Refill iron reservoir with clean water, wipe any dirty from the sole plate and this time on full steam, iron on clean layers of Kitchen paper to ensure that all dirt has been removed from the inside of the iron reservoir, if not, repeat from step 1 again.
    In the future, try to use distilled or at least filtered water.
    Hope it helps: let me know how you go!
    Feb 24, 2010 | Bosch TDA8340 Iron
    Brown dirt coming out of steam iron
    You're seeing hard water deposits and maybe a little rust. Use some CLR and pour in the iron and let it sit with it off. Shake it a bit and let it clean it all out, then rinse with clean water. (Vinegar will work too)
    Jul 01, 2009 | Sunbeam 4214 Iron
    Irons Logo
    512 people viewed this question
    Top Irons Experts
    Are you an Iron Expert? Answer questions, earn points and help others
