Question about Whirlpool DU1055XTS Built-in Dishwasher
My dishwasher runs 2 hours as a complete cycle. I think it is never going to finish but I have not stopped it in mid cycle. Dishes are very clean but they should when it runs this long. I hear it change cycles so I know it is not stuck on 1 cycle. It also makes a lot of noise. 2 hours of noise. HELP!!! How long it it suppose to run?
  • Whirlpool Master
  • 19,396 Answers
That means that the machine does not detect that one condition to continue the cycle is met.
Sometimes when this happen unesperience repairers replace the timer board , an expensive part that rarely fails. The timer board must be replaced only after everything else is tested, the problem is usually a sensor, or a faulty part that causes the condition to advance not being reached.
In your case, if dishes are clean , then filling heating and recirculating are OK, problem is likely the drain system not stopping, this is fixed replacing first the pressure switch, then checking pump and timer board.
If drain is OK, and machine hangs on drying (only self drying models), then replace dryness sensor or thermostat.
Check also that there is water pressure from the house line, and that the drain hose is not kinked or blocked.
The door switch must be tested just in case the problem is caused by a defective door switch cutting off randomly with vibrations and causing the cycle to delay. This is tested jumping its contacts and running a controlled cycle.
All tests must be done with power off.
Try first tripping the circuit breaker and check the drain well, cleaning it and removin blockage. If that does not fix the problem call the support number listed on the user manual to have the appliance repaired.
Posted on Aug 26, 2010
Status light blinking
Please do a full clean up of the machine after checking in all the connections to the mains panel.Please check this link for tips to go about:http://www.espares.co.uk/advice/dishwashers/a/3/174/cleaning-your-dishwasher.html
Mar 12, 2012 | KitchenAid KUDS01IJ - Multiple Color...
Dishes not coming out clean
Hello
There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
Sep 13, 2011 | Maytag Dishwashers
Whirlpool Gold dishwasher not cleaning dishes. It runs through the cycles and rinses, but dishes are not completely clean.
I had a similar problem with my last two dishwashers, with food still left on the dishes at the end of the cycle. What a nightmare. The most recent dishwasher is new, now the problem is solved. Here's what the manufacturer told me. Pour white vinegar (approximately 2 cups) into the dishwasher and run through the cycle. Buy some Cascade Complete and only use this type of soap for the dishwasher. Make sure you run a cup or two of the white vinegar through the dishwasher cycle once a week. My dishes are now clean and clear!!
May 26, 2011 | Whirlpool Dishwashers
Dishwashwer stopped cleaning dishes properly. Powder detergent was not clearing the dispenser (even after 2 runs). Strange burning smell emitting. Ran again completely empty on Auto Clean, even stronger...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Oct 26, 2010 | Maytag 24 in. MDB7600A Jetclean® II...
When the washer gets to 1 in the cycle, it doesn't stop washing.
try running the test cycle or running delicate economy in that cycle it gets up to 150 degrees in the very first cycle let it run 15 or 20 min see if the water is screaming hot it is not and Luke warm it is not heating it is most likely a control board heaters very rarely go out
Jul 24, 2009 | Bosch SHU5316UC Dishwasher
Dishwasher is not cleaning dishes.
you need to check to see what the temps of you water going into the unit is. it needs to be atleast 120 degrees. if not your unit may be waiting to heat the water, until it does then it wont go into the next cycle. it could be the heat cycle is not working so that would cause the unit to not advance.
let the unit run thru the place you think its stopping, but not more then 2 hours. if its not advancing then you might have a bad heating element.
Jan 06, 2009 | Frigidaire 18 in. FDR252RB Built-in...
Kenmore dishwasher 587.15159400
to whom it may conern:
about six month ago I purchese the dishwasher, But It just stopped working, the green clean light just blinks all day and night, but wont start it's, when I push the red start button comes on but turns off about 5 seconds later turns of, and wont run and clean my dishes. Could you please help me get strat the dishwasher to start up and run again. Thank you patrick c smith
patrick c smtih
phon 951 805 5187
19050 rockman street
lake elsinore, ca., 92530
actt, 5049 9485 2176 1660
Aug 13, 2008 | Kenmore 15769 Built-in Dishwasher
Whirlpool DU1055XTS Built-in Dishwasher Logo
198 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
