Question about Creative Labs ZEN V Plus MP3 Player
Creative V Plus MP3 problem
My MP3 has hanged. It keeps showing the USB sign and says docked.
I can neither turn off the MP3 nor operate it. Its just stuck. Can you please help me solve this problem?
Reset it with paperclip. the hole is on it's left side, down from "on " trigger. then if you have probs with "re-building library", reset it, hold play button and turn it on. there will be recovery mode, try clean-up, if it doesn't help, just format it.
and read other solutions before you post yours)
Posted on May 08, 2008
I have a Creative Zen V plus. It has worked fine
Try to switch it ON when it is connected with USB or charger. If it turns ON then batteries require replacement.
Jul 15, 2009 | Creative Labs Zen Micro MP3 Player
Stuck on docket but not attached to usb
I had the same problem with zen V stuck in docked without usb - and the reset-button worked like a charm!
May 20, 2009 | Creative Labs ZEN V Plus MP3 Player
CREATIVE ZEN - NOT CHARGING
Go into your lab top and click on remove hardware safety.Find your zen the click remove..Next do not unplug it,shut off your zen then you should see instantly on the zen its charging...
Mar 31, 2009 | Creative Labs Zen V MP3 Player
My zen charges but doesn't dock
Try the Creative System Information program. It will scan for your Zen.
Jan 01, 2009 | Creative Labs ZEN V Plus MP3 Player
Wont detect Zev V plus
ok... i found a fix...
insert zen v plus install cd
exit out of autorun for cd
go to control panel
click on system
click on the hardware tab
click on device manager
click on portable devices
right click on your USB device with the yellow warning sign
go to properties
when it tells you that the drivers arent installed... go to the browse button and select your zen v plus install disk
hit ok and it will find the drivers that way...
Apr 04, 2008 | Creative Labs ZEN V Plus MP3 Player
Charging
if you use the usb cord connected to the computer it will charge( over night), i recommend an ac charger it's a lot faster!
Feb 12, 2008 | Creative Labs ZEN V Plus MP3 Player
Cd/mp3/usb player
Hi, try holding down the play button for a few seconds until "USB" shows up on the little display - my sons ipod nano works when I plug in the ipods usb lead.
Jan 11, 2008 | Audio Players & Recorders
Docked prooblem
Plug it in and start charging it. Once it has a decent charge if you ever have that problem again... (see below)
Using the instructions below try Reset, first, if that doesn't fix it try the Cleanup method, if that doesn't work... (if you have a backup of all your music on your computer), try the format option
This is from Creative's website:
Zen V Plus and Zen V
  1. Detach your player from the PC if it is connected, and turn off the player.
If the player stops responding, you can reset the player. To reset the player, gently
insert a thin object into the Reset hole located below the power switch.
2. Press and hold the Play button while powering on your player.
3. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All) Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
Jan 07, 2008 | Creative Labs Zen V MP3 Player
Hanged mp3player
Hi, I think you will need to remove the battery for a few seconds then try it.
Jan 04, 2008 | Creative Labs Zen Touch MP3 Player
Creative Zen V Plus stops reading
· Make sure you have media player 11
· If you can, the best test is to try your player with another PC, to see if you still have the problem. This localises whether the problem is with the PC (most likely the USB) or the player. See the link below (search on "connection problems") for a lot more troubleshooting on this.
· Download recovery tool off creative's website.
Aug 15, 2007 | Creative Labs ZEN V Plus MP3 Player
Creative Labs ZEN V Plus MP3 Player Logo
80 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Brian Sullivan
Brian Sullivan
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
