Question about Vector Camping, Backpacking & Hiking
I got a vector vec1395 3,000,000 candlelight flash light i need new battery and power cord for it where can i find one?
3 Suggested Answers
brainyass
  • 242 Answers
SOURCE: Vector Sport Spot 1,000,000 candle power spotlight
6 Volts, here is info from site.
VEC127Y
VECTOR SPORT SPOT 1 MILLION CANDLE POWER CORDLESS-RECHARGEABLE SPOTLIGHT
  • HIGH CANDLE POWER QUARTZ HALOGEN BULB DELIVERS A BRIGHT AND TIGHT BEAM
  • AREA WORKLIGHT IN HANDLE PROVIDES UP TO 15 HOURS OF LIGHT WHEN FULLY CHARGED
  • PROVIDES CONTINUOUS SPOTLIGHT USE FOR UP TO 25 MINUTES WHEN FULLY CHARGED
  • HIGH IMPACT, BREAK RESISTANT ABS AND POLYCARBONATE HOUSING
  • TOUGH, WEATHER RESISTANT AND BUILT FOR RUGGED OUTDOOR USE
  • REPLACEABLE 6 VOLT, 6 AMP HOUR, NON-SPILLABLE, SEALED BATTERY
  • LOCKING TRIGGER FOR ON/OFF LIGHT CONTROL
  • INCLUDES AC AND DC CHARGING ADAPTERS
  • INCLUDES BUILT IN HANDS FREE WORKSTAND
Posted on Sep 17, 2008
CarlGlas
  • 283 Answers
SOURCE: I need a battery for
http://www.batteryspec.com/cgi-bin/cart.cgi?action=link&product=313
Posted on Nov 09, 2010
Could really use your help repairing a WorkForce SportSpot WKF124HD. The WorkForce SportSpot 1,000,000 candle model WKF124HD Locking Trigger MOMENTARY SWITCH for on / off light control has failed.
You can try to find the O.E.M. part, take one from an old junked light, or find a generic switch from the hardware store and make it work. You diagnosed the problem already. You could replace it with a regular (DC) switch if you normally "lock" it on most of the time.
Miniature Pushbutton Switches
You might just consider replacing it, as it seems there is risk for fire with this model.
1 000 000 Candlelight Spotlight fire
Feb 02, 2016 | Vector Cars & Trucks
I own a Vector Industrial Series 900 to jumpstart system and power. When we recently moved the cord was lost and now I am in need of buying the new cord. Is this availale?
I advise caution when using a standard battery charger to charge a jumpstarter via the main leads. Firstly if there is polarity protection it probably won't work and secondly the heart of the jumpstarter is a sealed lead acid battery which does not usually tolerate high charge currents without shortening the life of the battery.
This type of battery needs either the low charge current supplied by the original charger or similar or a sophisticated regulated charger.
If using a standard charger avoid using a high performance type and use only the type that provides a trickle charge.
Apr 07, 2014 | JUMP START SYSTEM
I have a Vector HID Spotlight Power on Board SLH100P and I'm trying to recharge it. When you plug in the charger the led lights flash and click really fast. What could be the problem? Thanks for your...
The battery needs replaced. In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service. Or, you can order a replacement battery from: www.batterymart.com/p-6v-4_5ah-sealed-lead-acid-battery.html
Aug 04, 2010 | Vector 1 Million Rechargeable Spotlight
Where can I buy a new power cord?
If yours is the same vintage as mine ... it is enough like a coputer power cord that it worked.
May 30, 2010 | JUMP START SYSTEM
I have been charging my 2 million candle power spot light for last 2 days but full battery charge indicator (red light) does not flash yet. the led white light is working but the main lamp doesn't work....
It should take 10-12 hours, any longer the battery is no good, you can test the battery using a Volt Meter, the battery should be reading 12 volts, any less and the battery will need to be replaced. You can order a new one from Black and Decker, they purchased Vector in 2006, here is the link;
http://www.dewaltservicenet.com/servicenet_home.aspx?AspxAutoDetectCookieSupport=1
Feb 13, 2010 | Vector 20 Million Power Series Spotlight
Everything works but the jumper cables
Most likly the battery is old and will not keep a charge. I just replaced my battery for about $50 a few weeks ago. Go to a story like Battery + for a replacement. It worked for me.
Jun 09, 2009 | Vector VEC010S Jump Start System 300 Amp...
No power output from my vector 1000w inverter.
Sounds like a ground issue,Try this,Take the jumper cables and hook just the neg clamp tho the battery and the other end to the case of the inverter for a direct ground and see if that works..
Please rate this fixya
Jan 26, 2009 | Vector 1000w Power Inverter
VEC127Y
Sep 07, 2008 | Vector 2M Pwr Rch Spotlight
My Vector Vec157 Flashlight won't Charge...
It is the battery, I have a similiar Vector light for a few years and tried re-charging the battery but only the little LED light would come on. I have another Vector light, same model and switched batteries from the worjking one to the non-working one and now it works fine.
I then proceeded to purchase a new battery for the non'working one and when I arrived home I installed it and turned on the main light, still won't turn on, I tried the LED's, they work. I figured maybe the new battery needs a good charge so I plugged the charger in and charged the light for 12 hours, still no main light.
I guess the new battery is defective, so now I will return it and exchange it for another one.
Aug 22, 2008 | Vector 20 Million Power Series Spotlight
Camping, Backpacking & Hiking Logo
765 people viewed this question
Top Vector Camping, Backpacking & Hiking Experts
Barry_IA
Level 1 Expert
Jim London
Jim London
Are you a Vector Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
