Question about Cell Phones
Batter does not charge - Cell Phones
  • 4,102 Answers
Hi if the battery does not charge than this points to the fact that it has got bad cells and this means the battery will need replacing, once you have replaced the battery you should find you will have no problems.
if the phone dont even light up when you plug the charger in then this would point towards the charger being faulty, if you take the phone to any phone shop they will test the phone for you for free, so if you are unsure if its the battery or the charger then just take it into any shop and they wil tell you for free if the charger is working or not.
let me know how you get on or if you need further assistance ok.
plz rate this post as i have a whole page of unrated posts, thanks
Posted on Aug 26, 2010
Why doesn't it charge?
The battery may have to be replaced.
Feb 13, 2016 | LG Radio Communications
What would cause the vehicle to keep depleting batteries?
Sounds like you alternator might not be charging. If you can charge the battery and get the vehicle to a parts store, like an Oreilly's or Pep Boys, they will be able to test your charging system and determine your problem.
Nov 23, 2015 | 2001 Suzuki Grand Vitara
PUSH START BUTTON AND IT JUST CLICKS, bATTER SAIDS IT IS FULLY CHARGED
click it egen and egen if it dosint wrok call the pales
Mar 03, 2014 | Garden
Razor electric scooter e 300 battery charges but won't run
first check to ensure the batter has held the charge you put into it. Just plugging the charger in does not mean the battery is holding the charge. If the battery is bad, it will drain as fast as you put it in. if the batter holds a charge, should be able to disconnect the charger and battery will show charge. if so, you have a bad connection or motor.
Jun 29, 2013 | Motorcycles
My john deere la125 seems to be drawing power wile shut down, it take a week for the batter to go dead, i've pulled the batterer and it stays charged up , I've checked the charging unit and i
What you do is power off the machine, and disconnect the negative battery cable. Put a test light or volt meter between the battery negative terminal and the disconnected negative battery cable.
You will likely have a light or voltage reading...Then you start disconnecting things....I suggest the alternator.
When you have the correct component disconnected and the test light or volt meter shows no current.
If this component is the alternator, they have diode sets inside (or somewhere else in the charging circuit) Typically one diode fails and this causes the draw that you describe. The system often still charges, but at a slightly lower capacity with the failed diode.
Doc
Nov 23, 2012 | Garden
Plug in not charging the battery. I have laptop Sony Vaio VGN-NS10L-S but when I open the battery and that refix the batter it will work and next day it will not and I have to open the batter and to refix...
see on the battery there are small square holes, u will see metal contacts inside it. clean the metal part with a dry cloth & also clean the contacts of laptop. if still not working then try with replacing the battery.
Sep 03, 2011 | Sony Televison & Video
After installing newly charged batter when I turn
How old is the batt.? I purchased a digital camera and after 2 months the batt. went bad. Have had it now 2 years and several batt.later.
Dec 25, 2009 | DXG Technology Video Cameras
Battery is dead and I want to charge it and take it in for replacement
Boost your car with jumper cables and let the car idle or drive around for about 20 minutes for the alternather charge the batter on its own .if the car shuts off after you started it might be your alternather is no good . the reason why ur alternather might not be working is because the batter all it does is give enough power for the starter to crank the engine as soon as the engine starts running it gets all its juice from the alternather and it charges the batter as well. but some times when the alternather works and the batter is dead meaning all the cells inside the batter are dead it will never take the charge from the alternather. so you would have to change the batter.
if you would like to know how you can you test both parts useing a volt-a-meter... just ask...
p.s. I think its ur batter if you never changed it. so get that changed for the winter so you wont have any more starting problems during cold wheaters
Sep 26, 2008 | 2001 Chrysler PT Cruiser
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
