Question about Panasonic DMR-EZ47V DVD Recorder/VCR
I have just purchased the panasonic dvd freesat recorder. how do i connect to tv
    Problem Solver:
  • 6 Answers
Jus like every electrical circuit your combo player will b colour coded. the video out is usually a single jack on its own in da colour of yellow. now da audio is a bit more difficult but very easy to connect.if u read da back pannel u will read audio out wic u will connect da remainin cables. the colour coding for audio is either red and white or red and black
Posted on Aug 26, 2010
HOW DO I RECORD FREESAT FROM TX-L42D25B TO DMR-EX773EB
link the output from freesat box to input on recorder, output from recorder to TV. if you have the correct leads. then the freesat will play through the recorder to TV even when recorder is off.
To record, set record from the input, av1, or what ever it's called on the recorder.timer recordings can be set the same way, or if the system allows, record from input detect.
Sep 30, 2013 | Televison & Video
I. Have a panasonic DVD recorder with Freesat HD tuners built in. After a power down at the house the recorder shows F5 108 on the display and the TV screen shows NoDignal. Does anyone have any suggestions...
I had the same problem. The display is simply showing that the unit is tuned to Freesat channel 108. I connected a SCART cable (rather than HDMI) and was able to get an output. I am planning to try a replacement HDMI cable as the video quality is obviously much better than with SCART. I hope this proves to be the problem rather than there being a bigger issue with the box itself. I hope this helps...
Oct 15, 2011 | Televison & Video
How do i connect my samsung dvd recorder sh853m to my free sat box? Also is it possible to record a channel from free sat onto my samsung recorder while also watching a different free sat channel.
If it's a Standard-Definition (SD) FreeSat box then a SCART cable would be the normal method of connection to your DVD recorder. This would connect to the SCART/EXT OUT socket on the back of the FreeSat box and the SCART/EXT IN on the DVD recorder. However, this depends on whether your FreeSat box has multiple SCART outputs and whether you are using a SCART cable to connect to the TV.
If there is no spare SCART output socket on the FreeSat box, then you need to use an alternative connection which is common to both devices, i.e. co-axial, and make sure you are connecting from an OUT socket on the FreeSat box to an IN socket on the DVD recorder.
If you have a FreeSat HD box, then you need to connect it to the DVD recorder using an HDMI cable or another cable type that will carry an HD signal.
You will only be able to record from a different Satellite channel if you have a Dual LNB with 2 feeds to the FreeSat box. The LNB is the receiver that attaches to the arm on the satellite dish. You can determine whether you have a Dual LNB as you will have 2 cables from the Dish to the FreeSat box. They may be joined as one cable, but there will be 2 F-plugs (threaded co-axial plug) on each end.
If you don't have 2 cables then you will only be able to record the same channel as you are watching. To record another channel, you need a FreeSat box that supports this feature and each channel needs also a separate feed from the dish.
Hope this helps. If you need any further assistance please post back with the brand model number of your FreeSat box and details of the connections you are using between the FreeSat box, the TV and the DVD recorder.
Regards,
BElectric
Dec 29, 2010 | Samsung Televison & Video
How can i connect my toshiba rdxv59dtkb2 to freesat
be more specific please. Normally you could use A/V cables to your dvd recorder then from dvd recorder to TV.
from your signal that feeds to your tv just feed to the toshiba dvd recorder, then from dvd recorder to tv, then you should be golden. Just dont forget to set the channel on the dvd recorder.
Sep 17, 2010 | Toshiba D-VR3 DVD Recorder/VCR
Can i set up my blu ray recorder DMR-BS750 without
The purpose of that freesat to bo able to record/playbak 2 channels at the same time. But you still need a satellite dish pointing to the satellite in the sky so it can work.
Jan 13, 2010 | Panasonic Televison & Video
Setting a new Panosonic TV
If it has no freesat tuner then you can only record what the TV is viewing/tuned to as an output from the TV.
Mar 21, 2017 | Panasonic CT-27SF36 27" TV
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
161 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
