Question about Minolta Maxxum 5000 35mm SLR Camera
The film advances only one or two frames before rewinding
    Genius:
  • 1,234 Answers
Problem with the Minolta Maxxum 5000 35mm SLR Camera
Posted on Aug 26, 2010
5 Suggested Answers
  • 11 Answers
SOURCE: Problems rewinding film.
Your film is already rewound (if I understood you correctly). Your camera is beeping because the film is rewound and there is no film for the camer to take the photo on since it has been rewound.
Posted on Sep 21, 2007
SOURCE: Inserting film
That is how, it is designed. So it is not a problem
Posted on Jan 30, 2008
SOURCE: Film advance inoperative
check the polarities of the battery.
Posted on Apr 02, 2008
  • 4 Answers
SOURCE: Pentax MZ 50 film winding problem
Well, I'm not a camera repairman, but it sounds to me (and probably to you too) that the electronics are damaged or perhaps there's dust in the contacts inside. I also have an MZ-50. There's so many electronics involved and they don't age so gracefully. I would consider buying another one off eBay or you can get a ZX-30 (same as MZ-30) for $75 from Blue Moon Camera & Machine with a 1 year warranty (parts and labor). The best way would be, in my opinion, to get a manual, mechanical camera from the 1970s and put a good lens on it. Those seem to last forever. No electronics to worry about. Advance and rewind the film manually. You can use a digital camera as a light meter to set the aperture and shutter speed. I'm thinking of going this route when my MZ-50 finally conks out.
Posted on Mar 26, 2010
Film rewinds when loaded
Align film leader at mark, then close the camera back for prewind loading. Film rewinds as each shot is exposed. Built-in motor for automatic winding/rewinding. Film advance: Automatic. Single-frame and continuous (1 fps). Automatically rewinds film leader into cartridge when designated number of frames have been exposed (midroll rewind available).
sorce: http://www.canon.com/camera-museum/camera/film/data/1996-2000/1999_eos3000.html?p=2
Canon Camera Museum Camera Hall Film Cameras
good luck
Dec 20, 2014 | Canon EOS-AE-1 35mm SLR Camera
Is there a manual rewind on nikon n65?
If by manual you mean turning a crank to rewind the film, no. If you mean to do it at a point other than the end of the roll, yes.
To rewind film mid-roll, press the two film rewind buttons simultaneously for approximately one second. The film will then rewind and the frame counter will count backward. The film is completely rewound when the E appears in place of the frame number.
The two film rewind buttons are marked with a red film canister symbol with left-pointing arrows. One is the exposure compensation button next to the control panel, the other is the self-timer button next to the mode dial.
If you need a manual, you can download one from
http://butkus.org/chinon/nikon/nikon_n65/nikon_n65.htm
Jan 21, 2011 | Nikon N65 35mm SLR Camera
How do i get my advance lever to move it seems jammed
A Canon AE-1 is not an EOS camera the Canon "A" series is manual focus while EOS is auto focus. First thought In answer to the advance lever stuck or jammed I'm going to assume the camera is in serviceable condition and has not been subjected to water damage or harsh use. If we are dealing with just the advance lever then I'd say that you have over advanced the film at the last frame. I've done this myself after loading a 24 exposure and thinking I had a 36 exposure film. At the bottom of the camera there is a little pin which releases the advance lever and allows the user to rewind the film. Under normal conditions when it's time to rewind the film into the canister this pin offers little resistance to pushing in to release, however depending on how much force the advance lever has been subjected to increases the tension on this pin. Push the pin in and rewind the film.
Second thought is if you have film in the camera and it has not been used fully then it's possible that the film has already been advanced to a new frame and the shutter needs to be activated before the lever will become free and advance to the next frame.
Other problems with the Canon "A" series cameras is they have a tendency to dry out the lubrication and begin to squeak when the shutter is fired. This condition can eventually result is a shutter seizure and give the same advance lever condition.
Those are the three things that come to mind over this lever problem lets hope it's just run out of film.
Nov 20, 2010 | Canon EOS-AE-1 35mm SLR Camera
How do i rewind the film in my nikon n2020
Set the film advance mode selector to L.
While sliding film rewind lever, push film rewind button.
Fold out film rewind crank and rotate until film advance indicator stops moving.
If you don't have a manual, you can download one from http://www.butkus.org/chinon/nikon.htm
Feb 13, 2010 | Nikon N2020 35mm SLR Camera
I have an Canon AE-1 and the film advance lever will not advance the film, the lever goes half way. The shutter will not release. Thanks
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
Nov 16, 2009 | Canon EOS-AE-1 35mm SLR Camera
I release the small black button on the back of the camera and tried to rewind it but iy won't do it. I am afraid to loose my pictures. Please help me.
On the bottom you have the Film rewind button. On the top you have the film rewind knob with crank . Here are the instructions on how to rewind the film. You can tell you have reached the end of the film by the frame counter and the film advance lever. Either the film advance lever will not turn at all or it will not turn all the way. First press in the rewind button, you may immediately let go of it, its on the bottom as shown before. Then turn the rewind crank clock wise until the frame counter, which counts backwards as you rewind, reaches "S" then open the back cover, remove the film, place it back in its canister and have it developed as soon as possible.
Oct 03, 2009 | Canon EOS-AE-1 35mm SLR Camera
How do you take a double picture
In much the same way as with any other 35mm SLR:-
1. Turn the rewind crank gently to take up any slack in the film.
2. Take your first photo. The 3800N has a special lens mask to help this process by blanking out one half or one quarter of the image, on other cameras a thin card mask over the lens achieves the same effect.
3. Hold the camera so that your thumb or finger is firmly on top of the rewind knob to stop it turning, whilst doing this press the rewind button on the base of the camera and then operate the film advance lever. By holding the rewind knob and pressing the rewind button, you allow the shutter to c0ck without advancing the film.
4. Turn the lens mask to cover the portion of the image which was just exposed.
5. Press the shutter using the same exposure value (EV) as previously used. Usually you'll use the same shutter speed and aperture, but by varying them and maintaining the same EV you can get some interesting effects.
6. If you're exposing more than two exposures on one frame then repeat as often as required.
7. Note that this is and always has been a bodge: the film frame often moves slightly between exposures except on a few specific SLRs which had a special multiple exposure setting. The V3800N is advertised as a multi exposure model but has no specific control for it, just the plastic lens mask.
Jul 25, 2009 | Vivitar V3800N 35mm SLR Camera
Film advance lever and shutter release button are "stuck"
No, it is not the battery. My guess is that the film leader did not stay in the take-up spool and is now bunched up around it. Try rewinding the film carefully as you normally would but remember that you are only rewinding a small portion of the length. You can even just open the film door and start over. You will only loose 3 or 4 frames on the roll.
Apr 27, 2008 | Nikon FE 35mm SLR Camera
Camera Rewinds New Roll of Film
Check the camera and the manual to see if there is a control to override the auto rewind; it may be set to rewind. Other than that, check Mikon's website for support info.
Jun 16, 2007 | Nikon N55 35mm SLR Camera
Apr 25, 2007 | Pentax MZ-50 35mm SLR Camera
Minolta Maxxum 5000 35mm SLR Camera Logo
37 people viewed this question
Top Minolta Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Parshiv Luthra
Are you a Minolta Photography Expert? Answer questions, earn points and help others
