Question about LG 24 in. LDF7810 Built-in Dishwasher
Wash cycle just keeps going, does not move on to the next stage
    Problem Solver:
  • 10 Answers
If it is a HAIER (or a rebadged) d/w with a dial as a program selector (not the electronic type) and it stop before the heating part of the cycle, it can be the overtemp limiter switch inside the base of the d/w that tripped out. the way it works is power will go to the limiter, then to the heating element, then back to the motor for the dial to turn around and click to the next part of the cycle.
so if the limiter is tripped, no power to the element and no power to the motor of the dial. then selector switch will not click over to the next part of the wash (the heating cycle).
take care.
Posted on Jul 22, 2008
    Genius:
  • 1,073 Answers
What is the model number
Posted on May 06, 2008
Hi my machine will fill with water then doesn't do anything for the whole wash cycle then will dran and spin but will not wash in the wash cycle
Hi, it could be your heater element is not kicking in and so its not heating up the water and not moving on to the next stage of washing. Best get the unit checked out.
May 03, 2016 | Washing Machines
Zanussi zwf1421
Thermostat or heater most likely causes. Does timer button move round without doing anything? Timer knobs on Zanussi notorious for breaking off inside.
Apr 28, 2012 | Zanussi F1245W Front Load Washer
I have a problem with my hotpoint wf340 1400 spin when i put it on it washes but wont come off the wash cycle and will continue washing unless i stop it manually i then have to select pump out and then a...
it is either a broken wire to your heating element or the element itself is open circuit. when the water does not heat the machine will not move onto next stage of wash.
Feb 20, 2011 | Hotpoint Washing Machines
Ariston LS 2020 taking more than two hours to go through cycle.
Ariston and on and on...lol
The water temp thermostat is to blame or the water is not heating.Basically what happens is the washer fills with cold water and starts to wash and heat at the same time.Once the water reaches a certain temperature it moves onto the next stage of the wash program.If the water is not heating or the thermostat is not working the programmer wont get the signal to move on.Hope this helps.
Apr 26, 2010 | Ariston Technologies Dishwashers
WFC 2260 - Machine Fills and empties, but drum doesn't rotate
You probably need to replace the brushes in the motor.
Remove rear panel, remove belt from drum, undo 2 screws securing motor, unplug lead to motor, lever motor back with a screw driver, keeping hold of it, and remove motor.
You will find the brushes located at the opposite end to the motor pulley.
Please leave a fixya rating for my proposed solution.
Thankyou.
Feb 03, 2009 | Bosch Axxis WFL 2060 Front Load Washer
GE Top Load Washing Machine -- Agitator will not cycle
Agitator's don't spin on wash cycle.
I would suggest washing the clothes without soap until they rinse clear. If you have hard water, the soap will not easily rinse out of clothes, or off of you when you use soap to wash or shower.
Reduce the amount of soap you use in each wash if this is the case. It sounds like your washing machine is working right.
Jan 26, 2009 | GE WBSR3140DW Top Load Washer
Washer will not go to rinse or spin cycle
electronic problem in timer board,not being electronically moved to next stage of washing
Jan 24, 2009 | Kenmore 43142 Front Load Washer
Maytag Neptune Stacked unit door leaks
This can be caused by water collecting in the door to tub seal. Best repair would be to replace the door seal.
Nov 29, 2007 | Maytag Neptune MLG2000A Front Load Stacked...
Dishwashers Logo
132 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
