Question about Mitsubishi Heating & Cooling
My daughter has Mitsubishi split type air conditioner, model MXZ-2A20NA. The problem is that one of the unit puts out more cold air than in called for on the remote resulting in a room temperature that can be 5 degrees colder than desired. Yesterday, the outside temperature reached 87 degrees. The remote control in the living room called for 75 degrees and the temperature in the room was 75 degrees. In the bedroom, the remote was calling for 78 degrees but the room temperature was 69 degrees and the split was still pouring out cold air! I am unable to find a solution in the technical manuals. Does anybody have a suggestion?
  • Mitsubishi Master
  • 43,501 Answers
The best thing for you to do is to call Mitsubishi Tech. Support directly..they are first class and will probably know exactly what the issue is...
For technical application questions, please call:
Mr. Slim: 1-800-433-4822 (press option #3).
heatman101
Posted on Aug 26, 2010
I am not able to get the unit to change from air conditioning to heat
Unfortunately these units are not user fixable , beyond checking for power and checking battery in remote. You would need to call a pro who is able to get service information and has special digital logic meters to diagnose and repair .
Oct 04, 2014 | Mitsubishi MXZ-2B20NA-1 Mr. Slim Dual Zone...
MXZ-3A30NA Unit takes longer to get cold and is making a slight noise. The red error light is flashing twice. It says that is IPM or PMC is faulty or compressor is faulty. Would this happen if it is...
low on freon, dirty coil, drain problem are the most common, (no particular order) it also could very well be the compressor, however you stated it takes longer to get cold...verify the drains are open and flowing, that all coils are clean, if they are the next call is to your service tech. Hope this helps
Dan
Aug 28, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
What are the overall dimensions of the outdoor unit of Mitsubishi air-conditioner type 6E50VA?
You can check with your model and type log on to :
www.mitsubishielectric.com.au/.../MXZ-2A52-3A54VA-Specs.pdf
Jan 03, 2011 | Mitsubishi Heating & Cooling
I have a mr slim split unit model mxz-2a20na and i cant get the indoor units to power up also the compressor does not com on i do have 220 volts going to unit. on the pc board i have solid lights on led1...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the Mitsubishi line. The manual include both troubleshooting and installation.
Mitsubishi Air Conditioner Troubleshooting and Repair
heatman101
Sep 08, 2010 | Mitsubishi Heating & Cooling
My daughter has Mitsubishi split type air conditioner, model MXZ-2A20NA. The problem is that one of the unit puts out more cold air than in called for on the remote resulting in a room temperature that...
Here is a tip about Mitsubishi Air Conditioners and how to get the manuals for all of the mitsubishi line. The manual include both troubleshooting and installation.
http://www.fixya.com/support/r5643983-mitsubishi_air_conditioner
heatman101
Aug 24, 2010 | Mitsubishi MS09TW Air Conditioner
I have a Mitsubishi ductless mini-split AC unit (model MSY-A17NA) and a Mitsubishi Electric remote (type KM07L 0029445). Could you please tell me what some of the mode symbols mean - in particular, the...
google ( mitsubishi air conditioner ) you should be able to get all the help you need .. dont forget you need your modal and serial number when you call it will give them the help they need to give you the right answers you are looking for .. once you google mitsubishi , there should be some numbers under what you are lookin for . may even be a picture of your unit .. just tryin to lead you in the right direction ..
Aug 17, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi split-type air conditioner model MSH-26SV. When the unit is switched on, the 2 green lights on the front panel light up normally but but the unit doesn't work at all and, after a few minutes,...
Hi I have Mitsubishi split unit which is 5 years old. when turn heat mode for 30 deg C on the remote condesing unit runs for about 6 minuts and stops. what would be the Technical problem ?Thanks an Apprentice.
May 23, 2010 | Mitsubishi MS09TW Air Conditioner
Split HVAC does not achieve requested temperature
If is heating on outside temp must bee max 5 degree
Celsius.If leak inside unit then check drain hose.
Feb 15, 2009 | Mitsubishi MS-A09WA Split System Air...
Heating & Cooling Logo
201 people viewed this question
Top Mitsubishi Heating & Cooling Experts
D. E. Hev
MightyMikeJr
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
