Question about Xtant 403A Car Audio Amplifier
Blown channel only one channel works tried different rca's, can this problem be fixed
  • paul12 Sep 09, 2008
    no the channel was not working when i received the amp
  • 631 Answers
Was the blown channel working and then quit or was the channel out when you received the amp?
Posted on May 06, 2008
  • Perry Babin Sep 09, 2008
    Do you have jumpers on every group of headers?
    Have you tried connecting speakers to all channels and moving the jumpers to see if the other channels would produce audio with other jumper settings?
Rca hdtv channel changed by mistake
RCA channel setup and selection is not easy to understand. You may try to add channel 3 on the add/remove channel section. If that doesn't work try pressing the input button. Good Luck.
Feb 28, 2010 | RCA HD52W56 52" Rear Projection HDTV
I think one of my channels blown how can i check to know for sure
Try switching your RCA cables around from the one that you know is getting sound. It may jsut be a bad rca or output from your radio!!
Sep 06, 2009 | Car Audio & Video
NAD T973 amp had noise, overheated, and then blew fuse
Hi, Very unlikely your repair of the RCA caused any damaged as preamp shouldn't cause big issues in the amp and would say you right that the problem existed already. The resistor is 100 ohm 5% but there is almost definitely blown outputs to have caused it. Most electronic places should be fine to test advise and repair. Would suggest outputs and drivers, but unfortunately not always that simple. Best of luck
Jul 10, 2009 | Audio Players & Recorders
Get closed captions on some channels, but not all, even though it is CC
RCA have choices for different methods of CC in user CC menu. Labelled T1, T2, etc. . Different selections are for different types of close caption. Tune to a signal (on your other TV) that has closed caption working.
Tune your RCA to the same signal. Change the T1,T2, etc settings until the closed caption for your signal appears.
If this doesn't work, try connecting analog video or VHF channel 3 (or other specified channel) to the TV. check CC. When TV stations, sat channels, sat receivers, cable boxes etc, convert analog video signals to HD, problems can result. Some equipment causes RCA TVs to do unexpected things with sound and closed caption.
If you use RF or video output, old analog video may look better on CH3 or video than on HD input and the CC will work more consistently. Watch HD signals on HD input, Analog signals on Video in or through the TV tuner . Many HD channels and programs are converted analog video and look poor on TV HD inputs.
easyab
Nov 03, 2008 | JVC AV-48WP30 48" Rear Projection...
DEH-P360 Won't output to rear channels/Sub
Make sure that the FIE (front image enhancement) is off. If it is on, the rear outputs are muted.
Oct 01, 2008 | Pioneer DEH-P3600 CD Player
Right channel doesn't work
check you rca jacks switch sides if the right channel still has no sound then it needs repair if the left channel doesnt work then the rca jacks are messed up
Mar 26, 2008 | Pyle 3000 Watts 2 Channel High Power...
Rca guide plus gold 32'
pull the ac plug for about 5 min and start your set up again paying atention to the features you want and don;t.set the menu to suite your requirements.
Jan 16, 2008 | RCA 32F531T 32" TV
Weird sound
get a portable player with a head phone jack get one of those cables with a headphone plug on one end and RCA's on the other plug the portable player into the amp and hit play. If you get Boom then the RCA grounds in your head unit are blown and only a repair shop can fix that. Also double check all grounds making sure they are solit with the proper gauge wire. Under the rear seat belt bolts is a prime connection point. Check with different RCA's
Jun 15, 2007 | Solid Audio F11D 1-Channel Amplifier Car...
Xtant 403A Car Audio Amplifier Logo
189 people viewed this question
Top Xtant Car Audio & Video Experts
hoyzee1
Tom Chichester
FastHarley
FastHarley
Are you a Xtant Car Audio and Video Expert? Answer questions, earn points and help others
