Question about Panasonic KX-T7630 Corded Phone
How can i change the extension numbers and names on kx-t7630
  • Panasonic Master
  • 2,460 Answers
It requires access to system programs 003 and 004. That can be done from the extension authorized for programming, usually extension 101. There is no "swap" command and we usually move the hardware at the frame rather than in software, but you can do it if you find a vacant number. An example would be to swap 102 and 108 you make 102 some other extension, like 402, then make 108 102 and then 402 108. Yeah. Sure.
Anyway, the user's guide (UG) for your specific system (not the phone) has instructions for the System Manager that details how to program Extensions and Names.
Carl
Posted on Aug 27, 2010
How do I change the display name on KX-T7630
http://service.us.panasonic.com/OPERMANPDF/KXT7630.PDF
May 13, 2014 | Panasonic KX-T7630 Corded Phone
How do I know which is the specific KX T7630 phone to program extension names on?
When you press PROGRAM ** on the right phone, it won't beep at you. By default, extension 101 is a programming phone. Access can be granted to any and all phones.
Carl
Jul 28, 2011 | Panasonic KX-T7630 Corded Phone
How to change extension name in panasonic kx-t7633
depending on programming restrictions:
at ext 101
1) press "PROG"
2) "**"
3) the user programming password (most likely "1234")
4) "004"
5) "ENTER"
6) enter the extension number you wish to change
7) txt out the name (you must use the direction pad in the bottom right corner of your phone if you have 2 letters in a row that are on the same key)
8) press the "AUTO DIAL/STORE" button
9) lift hand set and hang up
Jan 06, 2011 | Panasonic KX-T7630 Corded Phone
How do I change names that are programmed into the phone?
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system.
From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook:
1. Press PROGRAM * * or PROGRAM * # followed by the system password ( default is 1234).
2. Now press 004 and then ENTER.
3. Enter the extension number you want to change.
4. Enter the name (the same way as texting on a cellphone)
5. To save the changes press AUTO DIAL / STORE.
6. To go to the next extension press NEXT on the screen.
7. Lift the handset and put it down to exit program mode.
Mar 16, 2010 | Panasonic KX-T7630 Corded Phone
Extention Names?
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system -
4. Enter the name (the same way as texting on a cellphone.)
Feb 18, 2010 | Panasonic KX-T7630 Corded Phone
How to change a name on kx-7630
Without picking up the handset, press program *# 1234. 004 + enter. Then enter the extension no. whose name has to be changed. then change the name. After you finish entering the name press autodial.
Apr 17, 2009 | Panasonic KX-T7630 Corded Phone
How do I change the name display on my extensions
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook press Program * * or Program * # followed by the system password ( default is 1234). Now press 004 and then ENTER. Enter the extension number you want to change. Now enter the name (the same way as texting on a cellphone) To save the changes press AUTO DIAL / STORE. To go to the next extension press NEXT on the screen. When you are done lift the handset and put it down to exit program mode.
PLEASE rate/vote this answer if it was helpfull.
THANK YOU
Feb 12, 2009 | Panasonic KX-T7630 Corded Phone
Programming help
THANK YOU
Dec 23, 2008 | Panasonic KX-T7630 Corded Phone
Kx-t7630 product spport
This is how I did it:
1. Press the 'Program' button 2. Then dial ** (star, star) 3. Enter the password (usually 1234) 4. Press 'Next' until you get to 'Ext Name' 5. Press 'Enter' 6. You will need to know the Extension Number of you phone, when you find out enter it (eg: 104 or whatever yours is) 7. Press 'Clear' to get rid of the old name then start entering the new name via the number keys. Note: If you keep cycling through the letter on each number you can get to lowercase or uppercase letters. 8. Press 'Enter' then you are all done... pick and hang up the handset.
Feb 11, 2008 | Panasonic KX-T7630 Corded Phone
Panasonic KX-T7630 Corded Phone Logo
285 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
