Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Whirlpool ice maker red light blinking - Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
HVACRH20
  • 237 Answers
SOURCE: Ice Maker
I agree with Catriver, sounds like the "motor module" needs replacing. I must replace 3 of these a week at least so they seem to only last 2-3 years.
Posted on Nov 15, 2006
Dinoza
  • 112 Answers
SOURCE: Ice Maker
Catriver, as always your solution is great!
Posted on May 30, 2007
catriver
  • 878 Answers
SOURCE: Ice maker sotp making ice / red light blinking
J, As you open the freezer door the LED on the right should flash 2X with a pause repeatedly. When you hold the left side emmiter down the light should stay on steady. If you have this, you know the optics are good unless the ejector blades are not home. First thing to check is where the ejector blades on the ice maker are parked. They should be resting in the 2:00 position. If they are not, you could have a broken module. If they are in the 2:00 positon the next thing to check would be the fill tube. You want to make sure it is not frozen over. You can disconnect it from the back and see if you can blow through the line or visually inspect it. If all of the above mentioned check out, jump start the ice-maker. Remove the quarter inch screw holding the harness cover on the right side. Remove the harness cover. Pull the ice-maker straight out but be carefull not to smash the emmitter flap on the left side. Leave the harness connected. Get a jumper wire with the ends stripped apout a 1/4 inch. Unplug the refer and place the jumper in test holes T&H. Leave the jumper in and place the ice maker on the shelf where you can close the door. Close the door and plug the refer back in. Wait 30 seconds and open the door. The ice maker should be cycleing. Pull the jumper and place the module cover back on. Put the ice maker back in the rails. It should fill at approx the 12:00 position. Let me know how you make out. Catriver.
Posted on Jul 08, 2007
fridgetech
  • 473 Answers
SOURCE: Ice Maker on/off switch has blinking red light, will not produce ice. Manual no help
When you open the freezer door the light should be blinking. When you hold the flipper door shut (on the left hand side) without blocking the beam, the light should stay on solid. If all of this happens then the optics are o.k. If optics are ok then you most likely have a broken motor module on the icemaker and should replace the icemaker thermostat along with it. A bad icemaker thermostat will lead to the module breaking. If you not sure how to replace these parts then I would just replace the whole icemaker. That would be easiest and usually not much more expensive.
Posted on Nov 07, 2007
  • 42 Answers
SOURCE: Light blinking on ice maker control switch
The red light on the right side of the freezer at the on off slide mechanism is normal and ok. I indicates the ice maker is not in a cycle at the time. It is not meant to tell the customer the unit is ok or it is not ok. Ignore the light.
If I helped enough please don't forget to rate as a FixYa if you need more information please request more help.
Thanks, supertechks
Posted on Feb 14, 2008
I have a Whirlpool Model GD5YHA. The icemaker is not making ice. The red light is blinking.
Your have not given the full model #. Anyway most likely you have the Ice Maker Optical Level Sensor.
Just red light blinking does not mean faulty here. There is a Optical Sensor check sheet. You have to follow those instructions.
Google "Whirlpool Ice Maker Optical Sensor check sheet". You will get the instruction sheet and/or youtube videos on the subject.
Not making Ice means either the ice maker is faulty or Optical sensor faulty or water valve cannot feed water due to malfunction or line frozen. Also freezer should be below - 12C to ice maker sensor to work.
Oct 25, 2017 | Whirlpool Refrigerators
How do you flush water thru the water filter of my refrigerator
ice maker does not come out water to water hose and ice maker on/off switch red light two times blinking how can i repair to ice maker?
Jan 21, 2012 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
My whirlpool conquest side by side frig purchased in 2008 has a red blinking light in the freezer the ice maker is not working at all.
The blinking light goes to the ice maker on/off sensor. This is actually a real easy fix. The sensor is bad and needs to be replaced. If you look at the blinking light you'll notice there are two screws holding that section in. Directly across from that is another white piece held in by one or two screws. Whenever you close the door the beam is complete and the ice maker will turn on. To order the parts, find your model number, which is normally located in the refrigerator side, and then call any parts distributor ( i use appliance parts depot), and tell them you need the ice maker sensor kit. Thecost shouldn't be more than $50 I think. Hopefully this helps and let me know if you have any other questions.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Dec 06, 2010 | Refrigerators
The ice maker has stopped making ice. The red light is flashing (in the freezer. Part ot technician?
Hi, The blinking red light is just a sensor that shuts down the ice maker when the door is open so that it will not dump. This should have no effect on why the ice maker is not working unless the little door that blocks the beam does not return when the door is shut again...
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Oct 02, 2010 | Whirlpool Refrigerators
Free standing ice maker not functioning
Have you got a slow flash or fast flash?
A slow flash is a problem with the sensor.
A fast flash is dirty condenser failed condenser fan.
See page 16
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 15, 2010 | Kenmore 51lb. Clear Ice Maker
Flashing red light on ice maker control
Hi
I have Kitchen Aide refrig. Resently, we had a power surge which seems to have done something to the ice maker control. immediately after it stopped making ice. It has since started to make ice but very slowly. Before the controller blinking red light blinked and paused steady. Now, it blinks two red and pause steady. Is this repairable?
Thanks
Jul 16, 2009 | Whirlpool Refrigerators
Red light blinking on ice maker and ice maker not making ice
the red blinking light is normal . it sounds like you have a whrilpool,kitchenaid or kenmore made by whirlpool. if your ice-mkr fingers are not resting in the 2 o'clock position, then your
I/M motor/module is broken. use part#8201515
Jul 16, 2009 | Refrigerators
Seee note on ice maker stopped working, blinking red light
heatman101
rtwywy
May 25, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
604 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
