Hi.
Try
first leaving the unit disconnected from power for 15/20 mins, that
will probably not fix the problem, but is a necessary step in
troubleshooting.
If there is a dim light, that means that the inverter is on. Problem is likely the main control board, but parts must be tested before replacement.
The unit is repaired testing the internal component.
This TV comprises few boards: a Button/IR board, a digital controller board, a PSU, an inverter.
If you are a repairer,testing willl start from PSU, following voltages on main board and testing the inverter.
Parts can be tested following this procedure : A full
test ...
the best way to contact an authorized technician is
by ringing the number listed on the owners manual. Alternatively try Fixya directory here:Fixya directory-
Consumer Products Repair
To get parts try ShopJimmy .
Regards.
Ginko
