I have a Bush Idaptor DFTA1001 which has stopped working. The remote has been tested and functions fine, but the IR sensor is permanently on red and the Idaptor does nothing, all I get is snow. The TV (Bush 1403) is fine and receives analogue channels from the external aerial OK. Is it possible to work out whether the sensor needs replacing or the Idaptor and are they available? Thanks
jomaru
  • 337 Answers
SOURCE: Can receive only channels 1 thru 27 although connected to cable with 70 channels.
First you need to check if your set is in the cable mode and not antena mode,if the set is in cable make sure is in the standard cable mode and not another type of cable like HRC,if it is change it and try the autoprogram to set the available channels.I hope it helps.
Posted on Sep 13, 2006
SOURCE: Remote won't work
I would try 'waking up' the remote-Take the batteries out,press each button once then put the batteries back in.See if that works.
Posted on Dec 31, 2006
skippy101
  • 143 Answers
you can build a ir sensore box find parts at radioshack or you could open your remote clean contacs with mild soap and water nothing else and do not use any thing that may scratch then check to see if your (leds) light emiting diodes are broken of the pc board
Posted on Nov 02, 2007
ryan7
  • 11 Answers
SOURCE: Remote doesn't work
Check out my solution here:
http://www.fixya.com/support/t300197-tv_w_built_in_dvd
It's for the 37" version, but also works for the 26" TVs with little variation.
Hope it helps,
Ryan
Posted on Feb 12, 2008
jerryg50
  • 1667 Answers
SOURCE: symphonic b-19wm
It can be the remote sensor, or the circuitry that works with it. I don't know its exact location for your model, but you can usualy find it, because at its location it looks like a little black or dark red window in front of it.
The sensor and its related circuitry are servicable. To find the exact fault will require using a DVM and an oscilloscope to trace down where the signal is stopping from the sensor. The sensor feeds the main uPC controler via a number of components on the circuit board. An experienced service tech should be able to troubleshoot this for you, and replace the defective parts. On rare occasions the fault can be with the uPC itself.
It is also possible that there is a cold solder connection on the circuit board that is stopping the remote sensor from getting the remote signals to the uPC.
Jerry G.
Posted on Apr 12, 2008
Bose sound dock portable got wet - still works just fine. Why doesn't the remote control it anymore?
The remote is only 1/2 of the system; it (probably) uses infra-red to transmit and the sound bar uses a IR detector to receive the the signal.
Make sure the the remote is putting out IR by aiming it at (most) cameras and pressing a button.
You should see light visible to the camera but not to our eyes.
PS: iPhones have IR filters and will not work but the majority of cameras will.
If the remote is working, then the receiver in the sound bar is either still wet or permanently damaged.
Jul 05, 2015 | Bose Audio Players & Recorders
My tv [vizio vf550m] won't respond to a remote.
Vizio is famous for having main board issues. If you have replaced the IR board the only two other items it could be is a broken wire from the IR to main or the main board has an issue. Nothing else can stop the remote from working provided the remote is working properly.
Nov 02, 2012 | Vizio VF550M 55 in. LCD HDTV
My toshiba t.v...model#mw20fm3 doesnot work on the remote . i think the electric eye is not functioning. how can i get this repaired with a minimum cost, and close to where I live (San carlos, san...
There is a quick test you can do to figure out if the IR transmitter on the remote is broken or if the TV's IR sensor is at fault. Using a digital camera (cell phone works too) set up a picture of your remote's IR transmitter. DO NOT TAKE A PICTURE. Simply look at the sensor through the camera's screen. Now while looking at the screen press a few buttons on the remote. If you (through the camera's screen) see a red light coming from the remote, then the remote is fine. As far as getting it repaired, you can look for a TV repair shop in your local yellow pages. Call a few and ask for a quote.
Jul 18, 2011 | Toshiba CT-90157 Remote Control
Replaced batteries in remote dosent work might need program
Also try these simple trick to find out your remote control working or not....
Point the remote control towards the Camera of a Mobile Camera phone,with the camera on. While pressing remote, we can see a light (Infra Red) coming from its IR LED through the Mobile Camera if the Remote is working.
ifremote is working fine....lets go for programming
1. Manually turn on the TV
2. Press and hold the TV button The illuminated ON•OFF key turns on and remains on.
3. While holding the component key down, press and hold the ON•OFF key. The illuminated ON•OFF key turns off.
4. After holding down both keys for three seconds, the illuminated ON•OFF key turns back on.
5. Release both keys. The illuminated ON•OFF key remains on. TIP: Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently programming the remote to control.
6. Press and release the ON•OFF key repeatedly until your component turns off. Each time you press the ON•OFF key, the illuminated ON•OFF key blinks, and the next
code in the list is sent. This process continues until all of the codes in the Code Lists have been searched. If your component turns off, you have found the correct code.
TIP: Because there are so many codes, you may have to press the ON•OFF key many times-possibly up to 200 times.
7. Once you have found the correct code, you must save the new code by pressing and releasing the STOP key. The illuminated ON•OFF key turns off. You must press the STOP key to save the code or the correct code will not be stored!
8. To confirm that the component key is programmed with the correct code for maximum functionality, test the component. Attempt to control a variety of the component's functions with the remote. If some of the features of your components do not work, try programming the remote with a different code in the list until you find the code that allows the remote to control the majority of your component's functions. Different codes can provide different levels of functionality.
Feb 17, 2011 | RCA RCR311B Remote Control
LG 42LC2D not responded to remote
The IR sensor is in fact a "plug in device" .
The TV will have to be disassembled to replace the sensor.
You should make sure the remote is functioning before you do anything as drastic as taking your tv apart.
I am sure you have tried fresh batteries so the next step would be to hold down any button on the remote, the led light should have a faint pulse, it may be hard to see and you may have to go in a dark room but the led will pulse if the remote is good.
If you have a universal remote, program it for your tv and test functionality.
An RCA universal remote will work with your tv, if the codes don't work do a search with the remote.
If you decide to replace the sensor you should be able to find one at http://www.shopjimmy.com or http://partstore.com.
Let me know if I can be of further assistance.
Please rate this solution, the only compensation I receive is a good rating from you.
Lone99star
Apr 29, 2009 | LG 42LC2D 42 in. LCD HDTV
TV/DVD unit locked in Standby mode
Did you check the casing for a reset button (sometime it an itty ***** hole)
Hope this helps
Trap
Jan 25, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
Panasonic PV-8400 Remote sensor not working?
This is indeed a faulty IR sensor. If it's just the sensor, swap with your good one to check. From memory they are plug in - a little device behing d the smoked translucent facia (display panel). I have come across this several times with Panasonic VCRs. Check whether the remote works at night time with all fluorescent lights in the room switched off. If so, the IR filter circuitry is faulty. Same solution - replace IR sensor on VCR.
Jul 21, 2008 | Panasonic PV-8400 VHS VCR
Remote is inop
A universal remote is not a reliable way to test a remote control. If you can have an original remote this is the best way to test the remote function of the set. Or, if you have another set that is the same model as yours to test a universal remote, then the test would be acceptable.
If the remote has failed on the TV side, this can be from a number of problems in the set. It can be the remote IR sensor module itself, or one of the buffer amplifier stages on the way to the uPC, or the uPC itself. In some models the buffer amp is built in to the IR sensor module.
Without properly troubleshooting this fault, there is no possible way to actualy determine the point of failure. More than 90% of the time, the failure is the remote. Remotes get dropped, and abused often, and therefore they are subject to a high degree of failure.
Did you try unplugging the set from the AC mains for at least 15 to 20 seconds? This will cause a reset to occure for the uPC. If the fault is still there the set and the remote control will need a proper follow-up to service it.
Jerry G.
Apr 19, 2008 | Toshiba 32A43 32" TV
Bush freeview
The code you need is 888888
it`s a default code.
Terry.
Oct 15, 2007 | Televison & Video
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
Electro Med Services...
