Tasco 3-9x32 .22 Riflescope W/ Rings, Black Matte Logo
Posted on Aug 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tasco Silver Antler .22 3-9X32 while shooting rifle, scope jumped off, remounted scope, now can not adjust cross hairs, can I fix this myself?
Anonymous
Level 3:
President:
  • Master 2,702 Answers
  • Posted on Aug 27, 2010
Anonymous
Master
Level 3:
President:
Answers
2702
Questions
Helped
910905
Points
7895
If the scope tok a hard smck when it jumped off the rail i would say its broke the adjusters in the scope,,they can jump off there mountings if hit hard getting it fixed will cost more that the scope is worth,, if it was my scope i would just bin it and but a new scope,,and not a tasco one!
2helpful
Cross hairs wont move when trying to ajust
The cross hairs don't actually move when you adjust a scope, instead, they are contained within what is called the erector tube. When you adjust your scope you are actually moving this tube, thus the cross hairs do not move around in your field of view
1helpful
Hi..I would like to ask if i can use TASCO 3-9x40E for 308 Winchester.. Thank you With sincerely Peter
You can use any scope with any rifle as long as you can find a ring/mount combination the fits.
I have a 3-12 by 40 rifle scope made by tasco i dont have thewaranty paper work any more and the cross hairs wont adjust any more what do i do
i dont realy understand what you mean by "the cross hairs wont adjust" is it you have ran out of adjustment on the turrets? if so try packing the scope out with 35mm film under the body of the scope and reclamping it,,,or do you mean it just wont adjust?
the tesco rifle scope is a realy cheep scope its a throw away kind of thing if it brakes,,,,there only £50 or so,,,,if it was a £1500 scope its worth fixing
I have a tasco 4x32 rifle scope and the cross hairs spin inside how can this be fixed
you dont fix a tasco scope there so cheep you just throw them away,, and buy a new one,,,sorry but thats the way it is with tasco
Nov 13, 2009 • Optics
1helpful
2answers
Not a problem but need operation instruction for my scope.Its a tasco pronghorn 3x9x40 with adjustable yardage and has two elavation cross hairs,I have had it for many years and it works perfect,but I have...
I believe the second cross hair in your scope relates to an 18 inch dimension, or that of a deer. When you adj the wire to the body of a deer, it will be the distance, I'm not sure if you have to do the math, or the scope does it for you. Some scopes, you had to figure the hold over by the distance in the scope. others would be set to shoot at that distance. I would ave to look that one for you to be sure, but that is the idea. Hope this helps.
29helpful
3answers
PARTS FOR A TASCO RIFLE SCOPE
Hi, I think they can be found on amazon. here: Amazon com tasco rifle scope parts I hope this was helpful. cheers
1helpful
2answers
Tasco propoint PDP2 scope
Are you looking set the eye relief or the focus ring?
For eye relief you need to loosen the scope in the rings, mount the rifle to your shoulder with your standard hold and cheek weld. At this point, slide the scope back and forth in the rings until you obtain a full field of view. Tighten one of the rings slightly, dismount and remount the rifle several times to ensure correct adjustment. Level scope and tighten rings a final time.
For focus adjustment (remember that you are using the eyepiece to focus on the cross hair, not your target!) loosen the lock ring and turn the eyepiece until the cross hair is focused. It is best if you check it several times by closing and opening your eye several times. The crosshair should be instantly in focus. If your eye must adjust, then you need to refocus until the focus is instant.
The two dials on the scope are for adjusting the bullet point of impact. They will typically move POI 1/4 inch at 100 yards.
Nov 08, 2007 • Optics
Top Tasco Optics Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Tasco Optic Expert? Answer questions, earn points and help others
