Question about Smeg 24 in. DWF1 2 Free-standing Dishwasher
I have a SMEG DWF 1-2,that after pressing the start button,it runs for a couple of minutes,beeps and then stops,can anyone advise?
4 Suggested Answers
SOURCE: smeg dishwasher dwf 44 ss 1
http://www.smegtech.com/site/smeg/pdf_libretti/19590066100-GB.pdf
Posted on Feb 15, 2009
  • 3741 Answers
SOURCE: E9 error on a smeg dwf 66 dishwasher. Can't find
http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewtopic&t=45951 click the link directly also click this link directly to get the exact picture http://www.ukwhitegoods.co.uk/modules.php?name=Content&pa=showpage&pid=102 --------------- also try this open the door, switch it off, switch it on and immediately press the program button 4 times within 3 seconds. (Don't wait for any lights when you switch it on, just quickly press the button 4 times).
The two end lights should light up. Press the program button and one of the lights should go off.
Switch it off for about 20 seconds, switch it on, switch it off for about 20 seconds, switch it on and it should be reset.
If resetting doesn't cure it, check that the base isn't flooded and the anti flood device activated.
If you're getting any other error code don't do the reset, just post the lights that are flashing, 1 being left and 5 being right.
------------- Check for water in the base of the machine, not the tub.
Drain the water from the base, if there is any, and the machine will reset itself.
If there's no water follow the reset procedure as previously described.
You must get the two end lights lit first before you can carry out the rest of the reset procedure.
If you can't get the two end lights lit then it's possibly a faulty pcb.
----------- if by chance its faulty pcb then Faulty PCB.ne pcb costs £120 + VAT + call out charge so not worth doing
Posted on Aug 30, 2009
jonniewalker
  • 1031 Answers
SOURCE: Detergent dispenser on SMEG DWF 44SS1 doesn't open
this is Usually caused by a tablet sticking in the Detergent Dispenser. This will stop the Detergent Dispenser from opening at the correct time on the wash cycle.
Posted on Oct 18, 2009
Bosch dryer beeps
Two Beeps on my Bosch WTE84100au Condensing Dryer means a thermal overload but also means one of the thermal sensors is faulty .... as if it is always on.
Open the door, pull out the lint catcher and clean around the silver probe (it's like a shiny 1/8" nail sticking into the cavity below the lint catcher). If it still doesn't work (and still 2 beeps), just flick it lightly a couple of times. If it still doesn't work, flick again from the other direction.
Mar 24, 2014 | Dryers
Our smeg oven has stopped working, we have power and gas but the oven does not work. can anyone advise please
A couple of possibilities; oven thermocouple failure or the igniter is dead. If the latter has failed preventing the initial ignition, the thermocouple will shut down the gas supply quite rapidly.
Aug 08, 2011 | Smeg A1A.1 Gas Kitchen Range
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 | Watches
Smeg Dishwasher ST 663 sometimes won't work
My dish washer stops after i5 minutes, don't know what the problem is, water is going in but just suddenly stops, i changed the hose but still the same. Any help welcome
Feb 22, 2009 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
I have Fridigaire double oven part# PLEB27T8ACA with F8 code prob
wow, that is so weird...i was just getting ready to write the exact same thing. this last time mine beeped, i just kept letting it beep for several minutes. if kept on. i then went in and pressed all the buttons except for cancel and nothing happened. then i pressed the oven light button. the beeping stopped. not sure if it's coincidence or if that was what i was supposed to press. i will keep messing with the buttons and let you know if i figure it out. i will dread if it beeps all night long.
Feb 14, 2009 | Frigidaire PLEB27T9DC Electric Double Oven
Whirlpool DWF B00 W
Hunca, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Hunca), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 24, 2017 | Whirlpool Duet GHW9150P Front Load Washer
My Smeg dishwasher DWF 64 SSE won't go onto rinse or dry
Easy one first try this to see if it helps
Water pre-heating
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Jan 29, 2008 | Smeg 24 in. DWF612WH Free-standing...
Please help
try dropping power to the unit for a minute and see if it will reset itself. if not, you have a logic board failure. that or a door switch. check the manual for an indication on the warning alarm.
good luck
mark
Nov 18, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Hotpoint Ultima dishwasher dwf70
Press and hold the start and the on/off buttons together. It should come out of demo mode.
Aug 25, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Whirlpool DWF B00 W
Raise temperature of your water supply. Open door and press hi-temp srub,then energy saver, then reapeat this within 3 seconds. Close door and hit cancell.
Jun 02, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Smeg 24 in. DWF1 2 Free-standing Dishwasher Logo
82 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
