Need diagram for motherboard model m805lr. my extra usb has 4 wires plug on motherboard has 5 which ones do they plud into?
jisfy
  • 53 Answers
SOURCE: JP3 USB header
Dear friend here your solution
all usb jumper setting on mother board
http://www.geocities.com/jisfy/USB.JPG
If it helpfull please rate me. thanks sumon (jisfy@yahoo.com)
Posted on Mar 25, 2009
leecom72
  • 4806 Answers
SOURCE: The USB 2 & 3 have 10 posts each and my USB plugs have 4 openings
The USB pinout is as follows >>>>>>
Good luck.
Posted on Jul 01, 2009
  • 252 Answers
SOURCE: Connection diagram plug the USB ports to the EliteGroup P4S5A/DX+
Here is a link to the manual for your motherboard. It should show you how to connect your usb cables.
Hope this helps.
http://www.ecsusa.com/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=39&DetailName=Manual&DetailDesc=&CategoryID=1&MenuID=6&LanID=9
Posted on Nov 09, 2009
albertperamb
  • 148 Answers
SOURCE: need wiring diagram for acer motherboard
Goto acer website locate your model download service manual for your board.
Posted on Jul 27, 2010
Wiring Diagram For Usb flashdrive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually ((red white green black)) make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
or
PRODUCT NAME
FRONTX USB Type A Internal
PRODUCT CODE
CPX101-2
BAY USAGE
Half of large bay
CONNECTORS
USB type A female
1x5 header connector female
CABLE
USB cable (UL 2725)
Length - 2.5 feet (762 mm)
WIRE ASSIGNMENTS
Red: + 5V / Voltage + / VCC
White: D - / Data - / USB -
Green: D + / Data + / USB +
Black: GND / Voltage - / Ground
Black: S-GND / Over Current / Shielding
The S-GND wire is fatter and can be easily recognized. The connection of S-GND wire to the header pin is optional.
HEADER CONNECTION GUIDES
Diagram 1: On most motherboards, the USB header/pin-out consists of 9 pins arranged in 2 rows, which allows for 2 USB connections (i.e. USB1 and USB2). Normally, the pins for USB1 and USB2 are in seperate rows.
Diagram 2: Simply plug the connector onto the 5-pins row, and make sure that the pin assignments and wire assignments are matched correctly.
Diagram 3: Alternatively, you can plug the connector onto the 4-pins row, and leave the S-GND wire unconnected.
You might have to rearrange the wires to match with the pin assignments, or change the header connector if necessary, depending on the layout of the USB header.
On some motherboards, there is a NC pin in the USB header. You can connect the S-GND wire onto this pin. NC simply means "no connection" and NC pin is an "empty" pin.
2X5 PINS HEADER
Refer to the diagram below, for 2x5 pins header, simply plug the connector onto one row of the pins, and always make sure that pin assignments and wire assignments are matched correctly. You might have to rearrange the wires if necessary.
2X4 PINS HEADER
Refer to the diagram below, for 2x4 pins header, simply plug the connector onto one row of the pins. Please note that there is no S-GND pin in this header. You can leave the S-GND wire unconnected. You might have to rearrange the wires if necessary, in such that the wire assignments and pins assignments are matched correctly.
ACTIVE PINS NOT IN THE SAME ROW
On some motherboards, the 4 active pins are not located in the same row, as shown in the example below:
To connect to this type of USB header, you need to change the header connector to 2x5. Simply rearrange the wires within the 2x5 connector to match with the pin assignments. If the green wire is connected to the USB2+ pin, the white wire must be connected to the USB2- pin. The red wire can be connected to any +5V pin, and the black (GND) wire to any GND pin. If there is no S-GND pin provided, you can leave the S-GND wire unconnected.
hope it helps
Sep 23, 2012 | Lexar Media Echo ZX 32 GB Flash Drive
I don't know how to plug in the wires for the ASUS a8n sli deluxe motherboard
Here is the manual for your motherboard (since describing a diagram probably isn't very useful...)
http://dlcdnet.asus.com/pub/ASUS/mb/socket939/A8N-SLI/e2024_a8n-sli.pdf
You want to look at pages 27-35, they describe what you need to plug into the motherboard. Basically make sure you have connected:
1) 24-pin power cable (from power supply)
2) 4-pin power cable (for CPU from power supply)
3) Any case fans with 3/4 pin connectors.
3) hard drives (SATA or IDE)
4) USB front panel ports
5) Audio front panel ports
6) Case plugs (power LED, hdd LED, power switch, and reset switch).
Apr 19, 2011 | ASUS A8N-SLI Deluxe Motherboard
I am replacing a motherboard with a G31-M7 TE and find that my existing power supply has a 20 pin plug consistant with the old motherboard but the new one has a 24 pin socket. Why is this and do I need to...
New motherboards have a 24-pin power connector. Here is a diagram of both plugs:
You can see that the two are almost identical. The extra 4 pins on the 24-pin connector provide extra connection points for a few voltages. Newer boards and processors need more current, and the extra pins were added to prevent overloading.
Adapter cables are available to go from your 20-pin power supply plug to the 24-pin motherboard connector. Here's one from TigerDirect, and other vendors have them as well. If you're not making other changes than replacing the motherboard, you shouldn't need more than this adapter.
If you are upgrading your processor along with the motherboard, you should probably replace the power supply too. Older power supplies are often in the 300-watt range, and this is too low for reliable operation with new processors, motherboards and video cards. A new 500 or 600-watt supply is not expensive, and would give you the 24-pin power connection the motherboard needs.
Hope this has helped. Thanks for using Fixya!
Nov 20, 2010 | Biostar G31-M7 TE Motherboard
I've got a new Gigabyte Ga-M68Mt-D3 mobo paired with a cooler master 460 watt power supple. Cpu is Amd phenom II 3.2 ghz with 4 gig of DDR3 ram. I powered up the supply attached to my ATX power supply...
Most motherboards now have a 24-pin power supply connector. If you haven't already found a diagram showing the pinouts of the 20- and 24-pin power plugs, here's one borrowed from a handy site:
The two plugs are essentially the same, but the 24-pin version duplicates some voltages on the extra pins. The extra pins in the larger connector were meant to provide extra current paths for voltages that see heavy loads from newer processors and motherboard circuitry. Depending on how a motherboard is designed, it might work with a 20-pin plug connected (leaving pins 11, 12, 23 and 24 empty). But typically if the board has a 24-pin connector it needs the 24-pin power supply plug.
Most power supplies have a 20-pin plug with a separate 4-pin section that fastens to it for connection to a 24-pin mobo connector. It typically has one side designed to slide onto the end of the 20-pin plug, essentially turning it into the 24-pin version. This added plug does not have a retaining clamp on its side, so you can tell it from the the 4-pin CPU power plug. The wire colors are also different. For reference, here is the processor power plug, from the same website:
New motherboard specs call for the separate processor power connector for the same reason the extra pins were added to the power supply connector: to handle the high currents needed by increasingly faster CPUs.
When the motherboard has these connectors, you need to use them all to get everything working. Hope this helps. Thanks to smspowersupply.com for the diagrams, and thank you for using Fixya.
Nov 19, 2010 | Computers & Internet
I would like to get wiring diagram so I can hook up usb
The USB connectors are clearly marked on the motherboard.
There should be an extra set of pins that are not used and you can plug in the USB connector there.
The connector will have pins that look like this:
..... (1,2,3,4,5)
.... (1,2,3,4)
You don't use pin #5 on the top row.
Pin #4 on each row is ground.
VCC+ goes on pin #1 on each row.
Jun 20, 2010 | MSI 848P Neo-V Motherboard
How do I connect the front usb wires to my fic c51g motherboard header?
How to Install Front USB by Connecting Front USB Ports to a Motherboard?In order to have front mounted USB you must have 3 things.
  1. A case with USB ports in the front of it.
  2. A motherboard that supports front USB (usually)
  3. Appropriate wiring between the USB port and the motherboard
A case can support front USB in two ways: via a pass thru connection, or via a port to header connection. The former, pass thru connection, is compatible with all motherboards that have USB ports. Pass thru front USB Pass thru front USB works by having the ports on the front of the case connect to either a standard USB cable, or a fairly small rounded cable. The cable goes from the front of the case to a special slot cover with either a hole (for the standard USB cable) or a special connector for the rounded cable. If the pass thru USB had a standard cable, then you would simply plug the standard cable into one of your back USB ports. If it had a rounded cable, then you have a secondary attachment with something that looks like an old style SCSI connector. The attachment plugs into both the slot cover, and the back USB ports. The draw back of pass thru front USB is that you lose the ports in the back.
Many 3rd party devices that add front USB to a system use the pass thru system. A good example is this now discontinued Front IO panel
directron_1721_2292726
Front USB via a Port to Header connection In order to hook up a Port to Header connection you have to make sure that the wires from your port will connect to your motherboard's header. To do this you need to know what header you have, and what type of connector you have on the wires. You'll find information on both below.
Almost all motherboards these days have a USB header. Due to size and cost restraints many motherboards only have 2 USB ports on their back panel, but often they can actually support more then 2 USB ports. They will typically support additional ports via the use of a USB header. A USB header is either a single or double row of header pins on the motherboard that can be used to add additional USB ports to a computer via the use of an appropriate set of header connectors, wires, and a USB port. Each pin on the header corresponds to a wire inside a USB cable. These pins must be clearly marked so that you can hook them up to the wiring correctly. There are 2 common layouts for a USB header.
Intel Standard USB header Layout: (used by over 90% of motherboards)
Gigabyte Style USB header Layout: (used most commonly on Gigabyte brand motherboards)
instusb2b
Now that we know the types of headers we have to take a moment to understand the USB wiring. Understanding the wires First off: All USB cables have 5 wires. 4 of these wires are actively used. Here's a reference from the official USB standard.
instusb3
On a front mounted USB port you'll have either the first 4 wires connected to properly colored wires (red for power, white/orange d-, green/yellow d+, black for ground) or all five wires attached to the port (same as the former, but one extra black wire). Now where it gets tricky is how to attach each of those wires to corresponding pins on the motherboard.
The wires are "tailed" (attached to a header connector) using any one of a number of different types of connectors. Below you'll find a list of the common ones.
Common USB case header connectors 4 joined pins + 1 extra ground.
usbheader
Compatibility: Compatible with both header arrangements because of the extra ground. May not work with some odd arrangements To hook up carefully match each pin. For the Intel hookup you'll have the extra ground wire not attached to anything. For the Gigabyte hookup you'll have the extra ground hooked to ground pin on the motherboard, and the standard ground jumper will be over the missing pin on the header.
All pins separated
instusb6
Compatibility: Compatible with every header. If all the pins are separated the only real issue is lining up the pins with the appropriate places on your header. It should be compatible with all headers. Just make sure you read the writing on each individual connector. Please check the troubleshooting info at the end of the article for important information on this configuration
Power and Ground separate, d-, d+ joined Lian-Li style
Compatibility: Compatible with all common headers. This sort of arrangement is common to almost all Lian-Li cases. Make sure that you get the wires connected to your header in the proper order. If you find that the port does not function the most common cause is accidental reverse of the d-,d+. Try switching it.
All pins joined Intel style easy connector
usbinst4
making the Connection Once you know what type of header you have, and what type of connector you have on the wiring, you need to connect the two of them. In order to do this, you must first figure out what pin goes with what part of the connector. To do this, you should first consult your motherboard manual. Below you'll find an excerpt from a fairly recent motherboard manual for the Asus A7M266 motherboard. It's typical of a motherboard manual for a board using the Intel standard USB header.
instusb5
The first thing you'll probably notice is that the wiring from your case and the names of the pins might not quite match up name wise. This is a common problem. Motherboard makers and case makers really haven't decided on what to call each pin. Here's a rough list of names.
Power may be called: P, VCC, USB Power, Power, and PUSB. On wiring it's always red. Ground may be called: G, GND, Ground, and GUSB. D- may be called: USB-, USBP-, D-, or just -. D+ may be called: USB+, USBP+, D+, or just +.
To complicate things a bit more you'll probably notice that there's a number before each one. Take a look at the picture above from the USB hookup diagram for the A7M266.
You'll see that Asus decided to number the middle pins. On the first row (starting with pin 1, and marked with a 1) you'll find that they list D- as USBP2-, and D+ as USBP2+. The number 2 tells you a few things. First off: It's the 3rd USB port on the motherboard (they started numbering at 0), second it tells you that that D- and D+ must be used for the same port. Case manufacturers are just as likely to number their ports differently.
Take a look once again at the 4-pin joined picture: usbheader
Notice that you're D-'s have either a 1 or a 2 on them. These also tell you that they are part of the same USB port. (Remember, 1 port has 4 required wires). The numbering on the connector and the numbering on the header doesn't have to match.
To connect everything grab the following connectors: a same number D pair, (D-, D+), 1 power, and one ground. If your power and ground are numbered make sure all 4 are the same number.
Tip: Most cases that use all separated pins will bundle these together for you to make it easier.
Now, take your Power, D-, D+, and Ground and line the connector up with the appropriate 4 header pins on your motherboard. The header pins will be in a row under the Intel style, and in the Gigabyte style it will either be a row of 1 pin, a gap, and then 3 pins, or 3 pins, a gap, and then 1 pin. Press the connector down over the header pin and make sure it's firmly attached. Once you have done this go back and grab another set of connector wires (Power, D-, D+, Ground), and hook up your second front USB port. If your case has more then 2 front USB ports, and your motherboard has more then one front USB headers, then repeat the above as necessary.
Example: If you were hooking up the front USB on a A7M266, on a case with the pictured 4-pin joined connector type then: VCC lines up with USB Power, USBP2- lines up with USB1-, USBP2+ lines up with USB1+, and GND lines up with GND. For port 2, VCC lines up with USB Power, USBP3- lines up with USB2-, USBP3+ lines up with USB2+, and GND lines up with GND.
May 21, 2010 | Computers & Internet
Searching for a wiring diagram for my E machine....
Industry Standard Architecture exists here.
The pin arrangements for USB are standard, some usb headers are attached to the boards in the opposite direction but the pin arrangement is the same.
USB headers consist of 9 pins, arranged as 4 pins and one missing, and 5 pins like this:
x x x x o
x x x x x
these are marked as:
vcc1 usb 0- usb 0+ n/c
vcc2 usb 1- usb 2+ n/c
colours are:
red, white green black
Note: some motherboards have these connectors back to front but the connection sare as per the diagram
the audio header is arranged as follows:
X X X O X
X X X X X
top row = gnd, vcc5, mic2,n/c line
bottom row = mic1,mic r, line out,front spk r, lin out L
The cable colours may differ but the preformed plug will only fit in one place /direction
Oct 27, 2008 | E-Machines (308714) Motherboard
Front usb connections
I finally found a solution, on a dead page in google cache only:
http://www.pcclub.com/forum/messageview.cfm?catid=27%26threadid=16567
The solution was posted by JontyBonkers.
The pins go like this:
1 2 3 4 5
_ 6 7 _ 8
1 = ground
2 = ground
3 = D1-
4 = ground
5 = D1+
6 = D2-
7 = D2+
8 = +5V
It seems that the case for those Packard-Bells had a small circuit board that divided the 5V line to both sockets.
D- are usually white, D+ - green, 5V - red, ground - black
Jun 11, 2008 | Packard Bell Computers & Internet
Havimg prob with the 2 usb ports located in front
Hi manky, Normally front USB ports have a pair of 4 wire cable with connectors marked red wire is vcc; white wire is -D; green wire is +D; and black wire is gnd. The motherboard would normally have two pairs of dual pin connectors that would be sitting side by side or in-line with uneven pins - 4 and 5 pins; then another 4 and 5 pins. Please refer to the attached simple diagram for your connection. For some reason I couldn't get hold of a manual from the Gigabyte site of your particular model GA-81KHXT. Nonetheless hopes this works for you. Pls post again how things turn up. Good luck and kind regards.
Jun 01, 2007 | Intel Motherboard
Computers & Internet Logo
168 people viewed this question
David Payne
David Payne
